You can also mix flap back into left aileron if you want to move the whole TE at the same time in either same/opposite directions at will. Quote:
The radio is a little smart about how it sets up these dual tail configurations. Quote:
Andy |
South of Sweden
Joined Aug 2010
Andy,
Sorry if I was not really clear... My solution for the ailerons is through the AR9200 which provides 4 outputs on dual AIL and AUX1 channels. Still only 2 outputs from the tx logically. (The AR9200 has dual outputs for AIL, RUD and AUX1 channels) The servo sync (if needed) on the ailerons will be through direct programming of the servos. (the same goes for 2 rudder servos.) Also since its 4 separate ailerons the sync is not as supercritical as if they were 2 on the same surface. The two elevator servos will be syncd through the dual elevator function in the radio. Through the AR9200 I only have to use 5 channels on 8 servos. Leaves 3 channels for throttle, optical killswitch and smoke system. (Manual choke) Again thanx! |
South of Sweden
Joined Aug 2010
![]() (Seriously) Im referring to the first line, and how this works... //Patrick |
USA, CA, Merced
Joined Dec 2007
11ms frame rate is possible with any 2048 spektrum receiver
whenever they coded up their evolved receiver firmware for 2048, they probably had an eye to the future. there is no magical explanation, it's as simple as I stated it : a 2048 receiver is required for 11ms frame rate. this information is from back when the DX7SE launched, the only 11ms spektrum radio until the DX8 gets out there. |
It looks like you have a good setup then. Danny's explanation on the 2048 is correct. The 11ms and 2048 resolution go together. Higher-end modelers are going to want both features, not one or the other alone, so that's what we made. The guys in charge happen to be high-end modelers, so.... Andy |
Andy |
| Thread Tools | |
| Question Receivers that work with Spektrum Radios that are not made by Spektrum | BD Flyer | Radios | 29 | Sep 26, 2010 04:09 AM |
| Discussion Spektrum AR6100E or Spektrum AR6100? | LaurenceGough | Off-road Cars | 23 | Aug 06, 2009 05:33 AM |
| For Sale Parkzone 5ch DX10 w/Receiver ch54 | CarlHill | Aircraft - General - Radio Equipment (FS/W) | 7 | Jul 10, 2009 12:07 PM |
| Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? | Bigmaxy | Radios | 1 | Jan 19, 2008 07:57 PM |
| Sold GeForce 8400Gs PCIx DX10 video card | GFBurke | Non R/C Items (FS/W) | 6 | Sep 05, 2007 10:43 PM |
