Old May 14, 2011, 09:05 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Its been said before that the charge rate is the same and so it would take almost forever to charge the lipo.
I gave up after several hours charging mine and simply put in on my regular charger. The amount of time its going to need to be recharged I don't mind doing it this way BUT the mod above is looking interesting.
Looks almost factory built.
freechip is offline Find More Posts by freechip
Chip Geek is offline
Find More Posts by Chip Geek
Silicon/poker/chocolate chips
Chip Geek's Avatar
Austin, TX
Joined Sep 2008
Originally Posted by cayars View Post
Does it charge Lipos at a faster rate then NiMH or at the same rate?
Post 6130 says same rate, 200mA.
Chip Geek is offline Find More Posts by Chip Geek
Old May 14, 2011, 09:09 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
200mA max.
With a LiPo charger (pretty much ANY good LiPo charger), the start of charge is current-limited to a max value. We use 200mA for ours. Once the current draw drops below that limit, the charger goes into constant-voltage mode (8.4V for 2S) and remains there until fully charged. In this mode, the current drops slowly to 0.
It's because of this slow dropping to 0 that the LiPo mode is charging for a longer time. You don't need to wait until the light goes out, as this long duration is only putting the last few percent into the pack.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old May 14, 2011, 10:50 AM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Anyone find a good 2 cell Lipo battery that fits the transmitter well? Wouldn't mind having a couple of them.
cayars is offline Find More Posts by cayars
Old May 14, 2011, 10:55 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Anyone find a good 2 cell Lipo battery that fits the transmitter well? ....
You mean OTHER then this one? http://www.horizonhobby.com/Products...D=SPMB4000LPTX
Old May 14, 2011, 10:57 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Don't go just by fit!
Our battery pack includes safety and balancing circuitry inside it. It's not just a 2S LiPo!
Andy
Site Sponsor
Old May 14, 2011, 11:18 AM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Originally Posted by AndyKunz View Post
Schu,
Sorry you don't like our built-in charger. It's not about to change.
The charger takes 12V bulk power, unregulated, and provides a 200mA max charge rate (which is a 1/10 C trickler for the stock 2000mAh NiMH pack). What you're asking for is not a charger; you need a direct connection to the cells, and you came up with a solution that meets your needs. I have to compliment you on your resourcefulness. You did a nice, clean modification.
Andy
Andy,
I am also an engineer for a living so I can usually come up with a decent solution to problems like this.
Anyway, what I'm asking for is either a direct connection *or* a charger that doesn't suck. The built in charger is a decent enough idea, and I would even tolerate the insanely slow charge rate, but I won't charge a battery inside of a device without peak detection nor will I trust my aircraft to a battery that is routinely abused.
Anyway, you didn't answer my first question, are there changes to later run DX8s that address the issues with dsm2 RXs? I have a AR6200 in a $1500 airplane that has been dead reliable with my X9303, now I have the DX8 and I want to trust it. Not because I hope it will work, or nothing bad has happened yet, but because of engineering fact that there was a problem, and it has been fixed.
schu
akschu is offline Find More Posts by akschu
Old May 14, 2011, 11:19 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Its a safe, balancing 4000mah 2s Lipo that last so long I lost count.
Old May 14, 2011, 11:23 AM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Huh? I'm not picking up what you are laying down.
Old May 14, 2011, 11:26 AM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
For those that don't want to use a lipo in their TX (I'm one of them) nor do they want to modify the radio like I did, here is a workable solution:
Charge the battery for 8 hours or so (I wouldn't do the full 10) then get a outlet timer deal for christmas lights or whatever and set it to run for 30 minutes a day. Leave the tx plugged into the charger.
It will keep the batteries topped off with minimal abuse so your tx will always be ready to go.
schu
Old May 14, 2011, 11:31 AM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
schu
That's what I have been doing. Works fine but it would be nice if the "worlds most advanced 8 ch radio" had a better internal charger that would shut off. Or, just have the lipo standard.
Harry
Harry H is offline Find More Posts by Harry H
Old May 14, 2011, 12:40 PM
Telrin is offline
Find More Posts by Telrin
Dallas, TX
Joined Jan 2010
Here you go ...
Still 200mA max. The first time I charged my DX8 pack it was 40 hours before the light went out. I've charged that radio 3 times now.
Andy
Telrin is offline Find More Posts by Telrin
Old May 14, 2011, 01:14 PM
guy hanson is offline
Find More Posts by guy hanson
guy hanson's Avatar
Joined Jan 2011
I simply can find no fault with the stock 2000ma NIMH setup - I have one DX8 using ENELOOPs (latest permutation) and the other using std cells - either will fly an entire weekend -
guy hanson is offline Find More Posts by guy hanson
Old May 14, 2011, 01:31 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
schu
Dont fly it with your DX8. It seems that Spektrum is on the "don't say anything" policy on this issue. I exchanged all my heli RXs with DSM-X RXs so I can fly without worrying. Either Spektrum solves this issue or they have to exchange my DSM2 RXs with DSMX-ones.
Mukenukem is offline Find More Posts by Mukenukem
Old May 14, 2011, 02:51 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
The only differences between the batches at the factory that I have any knowledge of are that they are shipping with 2.01. The only reason I know that is because I prepared the files. I'm not very close to the production side of things, so asking a question about a production thing in a totally separate area (RF) is way outside my sandbox.
Andy
Site Sponsor
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
