Old Apr 21, 2011, 07:46 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Make sure you plugged the servos and power in correctly - check the little emblem showing ground, power, and signal. Your symptoms are exactly the same as when I plug them in upside down.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Apr 22, 2011, 02:24 AM
jb0005 is offline
Find More Posts by jb0005
FLY HARD OR FLY HOME TO MUMMY
jb0005's Avatar
Joined Jan 2011
i had not changed anything from when i had flown the jet 1/2 hour before. everything plugged in the same way as the last dozen flights, my rx is secured with double sided tape so it can't move and so is the antennae and they are positioned more than 3 inches apart perpendicular to each other. as i said i've got more than a dozen flights on this jet and the rx and antennae have not been moved since the first flight. any other ideas? if its any help, when i tried to re bind, the lights on the antennae work then, which at least tells me the connection between them should be ok, but like i said , after rebinding the result is the same, steady orange light on the rx and none on the antennae
jb0005 is offline Find More Posts by jb0005
Old Apr 22, 2011, 03:32 AM
krazy2 is offline
Find More Posts by krazy2
Joined Jun 2008
Have you tried checking/cleaning the contacts of the lead that joins the rx with the remote?
krazy2 is offline Find More Posts by krazy2
Old Apr 22, 2011, 06:20 AM
egicar is offline
Find More Posts by egicar
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Hi Andy,
any idea about the date of publication of the next FW?
Thanks a lot and Happy Easter to you and your family!!!!
Ciao,
Egidio
egicar is offline Find More Posts by egicar
Old Apr 22, 2011, 06:33 AM
SEALen is offline
Find More Posts by SEALen
Sundsvall
Joined May 2009
Originally Posted by egicar View Post
Hi Andy,
Ciao,
Egidio
He probably have but he will most likely not say unless it's like a week away.
SEALen is offline Find More Posts by SEALen
Old Apr 22, 2011, 07:26 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Actually, I have no idea. I don't even know what all the new features will be.
Happy Easter to you and your family, Egidio.
Andy
Site Sponsor
Old Apr 22, 2011, 07:58 AM
jb0005 is offline
jb0005's Avatar
Joined Jan 2011
any other ideas on my problem Andy, i pulled apart the connectors between the rx and antennae and reconnected and they looked fine.like i said there is some connection there as when i insert the bind plug i get a light on the antennae as well, but when binding is finished the one on the antennae goes out and i'm left with just a solid one on the rx and no sounds from the esc
Old Apr 22, 2011, 08:04 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Is the remote receiver the one that came with the base? There are incompatibilities between DSM2 and DSMX remotes so that you need to keep them paired with the proper base rx type.
Have you tried replacing the wire between base and remote?
Andy
Site Sponsor
Old Apr 22, 2011, 09:32 AM
swashplates is offline
Find More Posts by swashplates
swashplates's Avatar
Schweiz, BE, Uttigen
Joined Mar 2011
Antenna Fades Question
On my DX8 with AR8000&TM1000 (everything was bundled and shopped together)
The fade counters are counting very quickly up to more than 250 just after i turn everything on RX & TX - is this normal?? I had neverer any Frameloss or Hold so far.
The RX is horizontal and the satellite vertical mounted. The fuselage is fiber, no carbon.
See my Video:
http://www.youtube.com/watch?v=G4EEkedA4Gc
swashplates is offline Find More Posts by swashplates
Old Apr 22, 2011, 10:05 AM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
See my Video:
Are you using DSMX mode? I think they said the fade count would be higher in that mode, which is normal. But wait for Andy to answer your question to be sure. Also, I think there was a bug in an earlier version that incorrectly reported the number of fades.
jhroof is offline Find More Posts by jhroof
Old Apr 22, 2011, 10:07 AM
Joined Mar 2011
Yes it's DSMX Mode
Yes it's DSMX Mode
Old Apr 22, 2011, 10:10 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
It's normal for it to be higher, but if you're a few meters away it shouldn't be like that.
I sent you a PM with some questions.
Andy
Site Sponsor
Old Apr 22, 2011, 11:05 AM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
I was testing out a wing that I have just repaired and added flaps to in the garage and got very high loss count as well until I realized the RX and TX were inches apart. Started over with with a 1 meter distance and no loss at all.
Harry
Harry H is offline Find More Posts by Harry H
Old Apr 22, 2011, 04:46 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
See my Video:
I have only about 20-30 fades after a flight with my T-Rex 550 with the AR8000....
Mukenukem is offline Find More Posts by Mukenukem
Old Apr 22, 2011, 05:05 PM
jb0005 is offline
jb0005's Avatar
Joined Jan 2011
yes, the remote reciever is the one that came with the base( and they both came packaged with my dx8 tx)
there is no way i can change the cable between the rx and the antennae(remote reciever) for at least a week and a half as i am going away on holidays as of monday.i was hoping it was something that could be resolved by programming but by the sounds of it its looking likely that the rx can't recognise that there is a remote antennae which means the remote is not working as it should , the cable is not 100% or the rx is just not working as it should. if no one can come up with a solution i guess i'll have to send it back under warranty
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
