I've only had my DX8 for a few weeks with a few days worth of flying time. Call it a hunch, but I honestly don't think it's a power issue. I base this "guess" on the fact of using different quality ESC and also the separate battery pack. Also the fact that these same combos never caused problems with other transmitters. At this time all I have done is try with different ESCs (quality units) like the Airboss and ICE controllers and also with fully charged battery pack with no ubec powering the radios. No logging has been done at this time. I do believe the ICE controllers can do logging but I haven't gotten that far yet. One of my buds does have an Eagle Tree Logger that I'm sure he would let me borrow. Getting some logging data to check power issues is something I'm planning on doing but have yet to do. While I don't think it's a power issue I do want to rule this out in a controller manner. Quote:
I'm not a nay-sayer, a spectrum basher or anything like that. I love this platform but I'm concerned right now. While HH is known for it's customer support it "feels" like we are being let down with this issue. All we ever hear/or read is that things were tested and sent back. This might be one of those odd situations where lab/bench testing isn't going to find a problem easily. I know I'd feel a lot better about the situation if I knew HH was actively trying to pinpoint the said issue by flying some of the problematic returned receiver/transmitters as apposed to just bench checking them. Carlo |
Since the weather isn't cooperating here in Jersey for at least a few more days I'm trying to get a cheap plane setup to record as much of this info as possible and see if I can shed more light on the situation. If anyone has any suggestions for me please let me know! Carlo |
I don't know if this has anything to do with it but since someone just shared this with me I thought I would pass it on here.
From here: DX8 to AR6100 issue resolved - need to bind correctly! http://174.133.212.163/showthread.php?t=267842 This person discovered something that is slightly different then the manual suggests. The DX8 manual states the following procedure: Binding You must bind the receiver to the transmitter before the receiver will operate. Binding teaches the receiver the specific code of the transmitter, so it will only connect to that transmitter. 1. To bind an AR8000 to a DSM2 transmitter, insert the bind plug in the BATT/ BIND port on the receiver. Note: To bind an aircraft with an electronic speed controller that powers the receiver through the throttle channel (ESC/BEC), insert the bind plug into the BATT/BIND port in the receiver and the throttle lead into the throttle (THRO) port. Proceed to Step #2. 2. Power the receiver. The LED on the receiver will be flashing, indicating the receiver is ready to be bound to the transmitter. 3. Move the sticks and switches on the transmitter to the desired failsafe positions (low throttle and neutral control positions). 4. Press and hold the trainer button while powering on transmitter. 5. The system will connect within a few seconds. Once connected, the LED on the receiver will go solid indicating connection. 6. Remove the bind plug from the BATT/BND port on the receiver. Power off the transmitter and store the bind plug in a convenient place. From this thread this person does step 4/5 differently. Instead of letting go of the button once the bind light is established the button is held until the DX8 resets. I've never done this but I'm going to rebind all my planes in this fashion and see if this makes any difference with the 6200s I have. Worth a shot I guess. Carlo |
Champlin, MN
Joined Feb 2010
Potential DX8 Issue
Reading through the debate on the potential issue with DX8/AR6200 - has anyone taken specific note on if there were other transmitters/potential interference? What about heat? I've only flown my dx8/ar6200 twice (it's still too dang cold here), but haven't had any issue. I know they're not trying to punish DX8 owners by mentioning a ban, and I'm sure mentioning one is meant to get Spektrum to take note of the issue.
I hate the whole mindset people seem to have now days where one mistake messes something up for everyone or an issue gets blown way out of proportion. Last time I checked I still lived in America... Spektrum does need to own up to a potential issue - no argument there, but Toyota has lost millions and there hasn't been 1 shred of scientific proof there's anything wrong with their throttles. HH may be one of the biggest guns out there in the RC industry, but I doubt they could recover from something like Toyota has gone through. The problem is if they admit to potential issues everyone gets all "sue happy". I would sure hope they are aware of the issue even if they're not admitting it. If you've got an issue with yours let's try to rule out variables and be scientifically minded here - rule out every other possibility. Send them your equipment for inspection, bombard them with scientific data (a couple guys mentioned a great idea of getting flight logger systems). Bottom line - let's try to be part of the solution not the problem.
Joined Nov 2009
If you search the DX8 Threads there is an unusually high number of DX8 6100/6200 combos that all exhibit themselves in the same manner ( worked with DX 6/7). I am not convinced there is a flaw in the DX8, but believe there is something unique in the DX8 AR6100/6200 combos. I had a 6100 in a REX450 that was flying level at 30Yrds and did a hard left dive into the ground. It is also interesting that in almost every case the failure results in a left Ail and down Elev movement. My 6X00 rcrvs are now retired.Only running 7000 and 8000 series.
I've flown my DX8 only with AR8000, AR500 and AR600's and so far have not converted over any of my aircraft equipped with AR6200's. No problems exhibited by the receivers I have used. Hope the "hold bind button till reboot" solves the issue. Please keep us informed
Joined Jan 2006
on a 6200 equipped 500 size heli before winter. Never had any issues. Nor, with close to 100 flights on a 6100 equipped 250 heli indoors. No problems either with a 6100 equipped electric 47" Yak flown beyond what most would consider "park-flyer range". If there is an intrinsic problem with compatibility between the DX8 and the 6200 or 6100 rx's, I think I should have experienced it, and I just haven't. |
Just for the record, I'd have to agree with the previous two posters - over 100 flights with the DX8 and mostly 6100/6110-series receivers in a variety of planes and not a single problem. Most of my planes are fast, performance models and any problem would have been very noticeable.
From this, I would suspect individual set-ups before I would an inherent DX8 problem. |
Pacific Northwest
Joined Oct 2007
Why used he not a TM1000 telemetry TX and looks what's going on? I fly a Polaris* with the AR6110 now 10 hours with the DX8 and a Jepe Mirage with AR6200 has 1:30 on the clock. Then a Rafale with AR6255 1h. My two Shockys has 5 and 6 hours on the clock with the AR6100 and DX8. *Without the TM1000 I never discover that the 3A SBEC in the Polaris had some power drops to 2.7V. |
Pacific Northwest
Joined Oct 2007
| Thread Tools | |
| Question Receivers that work with Spektrum Radios that are not made by Spektrum | BD Flyer | Radios | 29 | Sep 26, 2010 04:09 AM |
| Discussion Spektrum AR6100E or Spektrum AR6100? | LaurenceGough | Off-road Cars | 23 | Aug 06, 2009 05:33 AM |
| For Sale Parkzone 5ch DX10 w/Receiver ch54 | CarlHill | Aircraft - General - Radio Equipment (FS/W) | 7 | Jul 10, 2009 12:07 PM |
| Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? | Bigmaxy | Radios | 1 | Jan 19, 2008 07:57 PM |
| Sold GeForce 8400Gs PCIx DX10 video card | GFBurke | Non R/C Items (FS/W) | 6 | Sep 05, 2007 10:43 PM |
