Old Feb 09, 2011, 04:08 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
I found another (visual) bug: When selecting "DSM2" in frame rate menu, you see DSM2 besides the Model Name in main page. This works for me, except model memory 2, there I don't see "DSM2" (although I have selected DSM2 in frame rate menu). The other memories (at least up to 9) work as they should.
Mukenukem is offline Find More Posts by Mukenukem
Old Feb 09, 2011, 04:10 PM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Andy mentioned in another thread that if you dound those models prior to 1.04 then nothing will appear and you need to rebind
Originally Posted by AndyKunz View Post
No. All your bound models are still bound. If you bound them using 1.04, they will show up as DSM2 in the top right corner. If you bound them pre-1.04, the top right corner will be blank. If you have a DSMX rx, rebinding them will change that to DSMX.
Andy
This just prove to be more important want he said early on and that is anytime you make any changes you should rebind. That would appear to include updating Airware
freechip is offline Find More Posts by freechip
Old Feb 09, 2011, 10:10 PM
Danyal is offline
Find More Posts by Danyal
Canada, ON, Milton
Joined Feb 2010
Everytime I see the DX10t or read something new about it I just fall in love with it even more!
I had a few questions about it
Is it at all possible to use it with your thumbs????
Is there a button where your thumbs would go if you were thumb flying??
I fly strictly thumbs, whenever I try a different way it is difficult for me, but I still really want to get the DX10t, you guys made some huge appearance differences since last year, it looks 10x better!
When will more information be released abut the 10t?????? Don't say I have to wait till June just to find out what its really capable of
Danyal is offline Find More Posts by Danyal
Old Feb 09, 2011, 10:13 PM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Ontario, Canada
Joined Apr 2010
OK, my DX8 repair order has been sent in.
Freechip, wish me luck! I hope for a speedy return of my DX8 back to Canada!
philipa_240sx is offline Find More Posts by philipa_240sx
Old Feb 10, 2011, 12:47 AM
CH_Flyer is offline
Find More Posts by CH_Flyer
Joined Feb 2011
Andy, I am using a Kontronik Jazz ESC in my helicopter. I want to run it in the governor mode. How do I program the DX8: use a linear throttle curve (e.g. 85-85-85-85-85) in the throttle curve menu or use the governor menu? Thank you for the clarification.
CH_Flyer is offline Find More Posts by CH_Flyer
Old Feb 10, 2011, 12:52 AM
Kambalunga is offline
Find More Posts by Kambalunga
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
A little bug is the Airwave 2 i can't edit the % value of Gasknüppel.
Kambalunga is offline Find More Posts by Kambalunga
Old Feb 10, 2011, 01:25 AM
Vienna, Austria
Joined Oct 2010
Thanks ! That seems logical. The model no. 2 is the one I bound first. Will try rebinding
@CH Flyer: Just use a linear throttle curve. The governor menu is for nitro governors (with governor rx's). (The curve should be below 80%, otherwise the ESC does not have enough headroom for the governor)
Old Feb 10, 2011, 01:26 AM
faxxe is offline
Find More Posts by faxxe
Graz,Austria
Joined Aug 2007
I can confirm that bug. In the timermenue, its not possible to
change the % value of the throttlestick, where the timer will start.
Its always at 25% of throttle.
How can i inform the support team?
-faxxe
faxxe is offline Find More Posts by faxxe
Old Feb 10, 2011, 01:31 AM
Confuzshuz is offline
Find More Posts by Confuzshuz
Joined Dec 2010
another bug, not a huge deal, but sometimes the tones randomly change pitch when moving/pressing the roller. happened to me multiple times when setting telemetry values and scrolling the menu.
btw, where can I buy another telemetry stylus? mine disappeared.
Confuzshuz is offline Find More Posts by Confuzshuz
Old Feb 10, 2011, 01:54 AM
GoneFusion is offline
Find More Posts by GoneFusion
GoneFusion's Avatar
Australia
Joined Oct 2010
-faxxe
Andy from spektrum monitors this thread. Im sure he has noted it for you.
GoneFusion is offline Find More Posts by GoneFusion
Old Feb 10, 2011, 02:02 AM
Trevor Chadwick is offline
Find More Posts by Trevor Chadwick
Joined Nov 2010
Andy replied to me directly within thirty minutes of my question on the forum about whether or not this timer issue was a bug or not, to say that it had been fixed, and would be corrected in the next update. Most impressive.
Trevor
Trevor Chadwick is offline Find More Posts by Trevor Chadwick
Old Feb 10, 2011, 03:49 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
With mine the throttle % is still the same as it was set on existing models. However it can't be changed. Open model mem. are set at 25% & can't be changed.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Feb 10, 2011, 04:24 AM
faxxe is offline
Graz,Austria
Joined Aug 2007
Hm.....
v1.x need 3 Updates to become a stable v1.04.
I´m looking forward to v2.04
-faxxe
Old Feb 10, 2011, 05:56 AM
freechip is offline
freechip's Avatar
Joined Aug 2008
Hm.....
-faxxe
It all depends on what you would consider STABLE as 1.04 still had issues but you probably did not know this because you weren't using those features. Same goes for 2.00, its got issues but if you're not using them you wont know about it.
When they determined & resolved the uncommanded servo issue then it was stable atleast for me as the programming would not cause a CRASH .
You're timer issue could be a bug/issue BUT only for those using it and only for those using it with a different value then 25%.
Its had telemetry issues from the begining with Main Voltage and Temp sensor combined BUT you probably did not know this because you weren't using it. Its now fixed in 2.00 or so it noted as fixed I have yet to try it.
Old Feb 10, 2011, 06:17 AM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
so when can we expect airspeed sensors ? they were mentioned in the spectrum email i recived yesrerday.
hotdog1 is offline Find More Posts by hotdog1
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
