Old Jan 31, 2013, 04:10 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Originally Posted by freechip View Post
Set Timer to Throttle Out
I set it to Throttle Out and rebooted, does not work for me, timer keeps running?
itsme2 is offline Find More Posts by itsme2
Old Jan 31, 2013, 04:12 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
What is your Timer set to?
Throttle Out uses the channel output so if your Throttle Cut is properly set .
freechip is offline Find More Posts by freechip
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Here's a stupid-people-trick related to that throttle cut.
I have a Dx8, latest software. I probably used the wrong thing, but now I'm trying to fix this. i have a Multiplex Mentor (Electric powered, of course), and thought I should put a throttle safety on it while at the field. I went to the Throttle Cut page, and programmed it with a mix switch. Worked, except when 'off' of course the throttle was off, when I flipped the switch to fly, it makes the motor turn at low rpm even the the stick is full down. I can see the carat is up some from zero on the monitor page.
So I didn't like it and just put the Throttle Cut back to Inhibit, but now the throttle is still stuck up from zero a little bit, making the motor run. How do I get it back to zero? I didn't change any numbers on the Throttle Cut page when I tried it.
Help me make it go away! Thanks!
xmech2k is offline Find More Posts by xmech2k
Old Jan 31, 2013, 04:17 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
When you set Throttle Cut make sure if you have neutral trim on the throttle that you set Throttle Cut to 29% or the value needed so when you toggle the TC switch the throttle channel does not move.
Then Re-Calibrate your esc throttle setting.
PS: There was an article published in the Fall Edition of the ParkPilot mag where they mention this very issue they also happened to mention my name. 15 seconds of fame.
Old Jan 31, 2013, 04:18 PM
itsme2 is offline
Joined Mar 2011
Timer set to Countdown/10:00
Old Jan 31, 2013, 06:18 PM
wjs is offline
wjs
Find More Posts by wjs
wjs
William
United States, MI, Brighton
Joined Oct 2012
There is second way that may make more sense for some. Set your throttle trim all the way down. Set your TC to 0%. TC switch and low throttle will match. Rebind.
wjs is offline Find More Posts by wjs
Old Jan 31, 2013, 06:36 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by wjs View Post
There is second way that may make more sense for some. <snip>
Yes for some. I have no model using throttle trim. All neutral TC set to 29%.
Old Jan 31, 2013, 07:39 PM
xmech2k is offline
xmech2k's Avatar
Joined Jun 2007
Thx Freechip & WJS! I'll check it out when I get home. Once again work interferes with the important things in life...
Old Jan 31, 2013, 07:45 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Itsme....The throttle On/Off timer WILL work...but only if you have enough receiver space??? On my 3 ch. models it works like a charm...On my FunCub..it WILL not work..perhaps due to flaps...anyway, thought it might keep you from going crazy trying...if this is why you cant get it setup and working....as it is very easy IF your setup will allow it.
Weed89 is offline Find More Posts by Weed89
Old Jan 31, 2013, 07:47 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ Weed89 - ??? One is based on the Throttle stick itself while the other is based on the throttle output of the radio. Has nothing to do with receiver being used.
Old Jan 31, 2013, 07:50 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
@ Freechip- All I know is I have it setup and working just fine...BUT it will not function on my funcub...I have tried MANY times useing the same setup as the 1 that is working...No go tho'....So it Does have somthing to do with somthing...Ill mess with it 1 more time tho'
Old Jan 31, 2013, 08:00 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Weed89 View Post
@ Freechip- <snip> ....So it Does have somthing to do with somthing...Ill mess with it 1 more time tho'
Yes it does, a radio setting un-related to receiver and or aircraft used.
You don't have to have the receiver and or plane powered on to see if your timer works or doesn't. It's all good, if you ever do play with it and find what's happening let me/us know about it.
Old Jan 31, 2013, 09:03 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
Found it !! the roller seems to skip around..ANYWAY...when used with Throttle...and set to 2%..it works like a champ!!
I did not realize there were 3 throttle options..only thought ther were 2...after trying to dial slower On the bottom of the roller...I Finally saw Plain Old "Throttle" and it works perfect.
Again Thanks
Old Jan 31, 2013, 09:08 PM
harryhenderson - crvnation is offline
Find More Posts by harryhenderson - crvnation
Joined Dec 2012
Again Thanks
Yes, the throttle out option is a good choice. Really good for heli guys who don't want their timers to stop every time they hit full negative collective/100% throttle in idle-up 2.
harryhenderson - crvnation is offline Find More Posts by harryhenderson - crvnation
Reply With Quote  (Disabled)
Old Jan 31, 2013, 09:37 PM
itsme2 is offline
Joined Mar 2011
Again Thanks
Yes, but it does not stop the Timer if the throttle is advanced past 2%, at least it my case. It does stop the Timer if the Throttle is below 2%. Small thing I can live with.
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
