Old Jan 31, 2013, 02:41 PM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Is there a way to have two different switches control one item? I have an air valve with two air outputs. One I want to go to my air retracts and the other to air brakes. I have it plugged in to Aux2 on an AR8000 and using a DX8. I have one output setup and working on gear switch for retracts...when I flip to gear 1 it operates valve on port "B". When I go back to gear 0 gear will come down as they are air up/spring down. When gear switch is on gear 0 the valve isn't activated neither port gets air. So now what I want to do it be able to move the valve to the other port with a different switch, say maybe the knob. This will give me the ability to apply the brakes when the gear is down. The valve works kinda like a servo in that it goes from -100 to +100 with port "B" is activated on the + side and port "A" on the negative side. I've tried a mix but couldnt get it to work. I'm fairly sur eit can be done but for some reason I'm just missing something. Any help would be appreciated. Thanks.
DamonH is online now Find More Posts by DamonH
Old Jan 31, 2013, 02:50 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
How do you need the channel to move?
Gear Sw.Pos.1 -100% gear channel
Gear Sw.Pos 0 0% gear channel
X Sw.Pos# -100%
freechip is offline Find More Posts by freechip
Old Jan 31, 2013, 02:55 PM
harryhenderson - crvnation is offline
Find More Posts by harryhenderson - crvnation
Joined Dec 2012
Something else to be aware of with the DX8, if it hasn't been mentioned before... Check the PID that's actually in the system settings menu and compare it to the PID on the sticker in the battery compartment. Some radios don't match. The sticker PID on my TX is good to go for no recalls, but the PID in the TX itself isn't.
harryhenderson - crvnation is offline Find More Posts by harryhenderson - crvnation
Reply With Quote  (Disabled)
Old Jan 31, 2013, 02:58 PM
DamonH's Avatar
Joined Oct 2011
X Sw.Pos# -100%
When I flip gear switch to pos 1 it goes to the positive side on the monitor screen and opens port "B" on valve. I can hook retracts to that and it will work fine. I would assume that I then need to be able to get the aux2 channel to go to the negative side on the monitor screen using a different switch (could even be the hold switch) to activate port "A" on the valve. So yes, I believe your sample is correct.
Old Jan 31, 2013, 03:04 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
They are not related....
Old Jan 31, 2013, 03:08 PM
Joined Dec 2012
How so? They are exactly the same except for the second letter.
Maybe Andy, a real Spektrum expert, could chime in on this?
Old Jan 31, 2013, 03:11 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ DamonH - Try this and let me know if it works or whats happening.
Mix1
GER>GER
Rate:-100%
Rate:0%
Offeset:0%
Trim:Inh
Sw:On
Mix2
GER>GER
Rate:+100%
Rate:0%
Offeset:0%
Trim:Inh
Sw:Mix1
In order to have the channel in the positive direction for what you described I reversed the Gear channel from a blank model.
The result for me using blank model is the following
With the Gear Sw in Pos.0 the gear channel is centered.
With the Gear Sw in Pos.1 the gear channel is positive 100%
While in this position the Mix Sw does nothing.
When Gear Sw in Pos.0 and gear channel is centered, the Mix Sw when in Pos.1 will move the gear channel to negative -100% for brakes.
Old Jan 31, 2013, 03:13 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
They did couple years ago when the bulletin where issued and ask users to confirm the PID# sticker in the Batt compartment and explain why it appeared on screen to be a PID and also said it was not related.
Yes I am no spektrum expert BUT I have been here long enough to remember these things.
PS: You should know better then this CRVNATION, couple months and back at it I see.
Old Jan 31, 2013, 03:19 PM
Joined Dec 2012
What are you talking about?
DamonH's Avatar
Joined Oct 2011
Mix1
GER>GER
Rate:-100%
Rate:0%
Offeset:0%
Trim:Inh
Sw:On
Mix2
GER>GER
Rate:+100%
Rate:0%
Offeset:0%
Trim:Inh
Sw:Mix1
Will these mixes work with flaps? I have flaps on the gear channel and gear (this valve to control gear on aux 2). Would I just need to try your recommendation but use aux2 to aux2 in the mixes?
Old Jan 31, 2013, 03:28 PM
DamonH's Avatar
Joined Oct 2011
Freechip, I just tried your setup but using Aux2>Aux2 and it seems to be working perfectly. Thanks for the help!
Oh, and you've been an expert on all my questions and many many others in this forum.
Old Jan 31, 2013, 03:32 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I forgot to mention to change Gear from my example to your channel used for the Valve.
Any time.
Old Jan 31, 2013, 03:35 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Im shocked he was able to stay away from you and andy for a month...gotta love his new name,,Gee i wonder if there is a pun in that ?? lol
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Jan 31, 2013, 04:00 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Throttle Cut & Timer?
I have a DX8 with Throttle Cut working fine on the Gear 1 switch & Timer set to Start: Throttle. When I activate the Gear 1 switch it kills the throttle but the timer keeps running. Is there a way to have the Timer stop when the throttle is killed with the Throttle Cut switch?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Jan 31, 2013, 04:06 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Set Timer to Throttle Out
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
