Old Jan 27, 2013, 02:08 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Pretty sure that's been asked before and the response was to use a DSM2 sat.
freechip is offline Find More Posts by freechip
Old Jan 27, 2013, 02:39 PM
Xantrix is offline
Find More Posts by Xantrix
Germany, NDS, Uetze
Joined Jan 2013
Originally Posted by AndyKunz View Post
That'll provide trims for FBL pilots. What about the millions of non-FBL heli's out there?
Andy
Gas/Pitch trim hardware switch?
Frank
Xantrix is offline Find More Posts by Xantrix
Old Jan 27, 2013, 03:15 PM
wfield0455 is online now
Find More Posts by wfield0455
United States, MA, Holliston
Joined Aug 2008
Originally Posted by keithy4129 View Post
hey guys, can you use a dsmx satellite on a dsm 2 rx. the reason i am asking is because I think the Align 3gx flybarless system only supports dsm2 so im not sure if the dsmx satellites would still work in dsm2 mode.
I use 2 DSMX remotes my TREX 600 FBL with a 3GX, it works fine. The 3GX has no internal receiver so there is no mismatch as long as both remotes are the same. I have been told that the remotes will still bind in DSM2 mode. Since my JR 12X, while upgraded for DSMX, doesn't provide any feedback on whether it bound as DSM2 or DSMX I can't verify that. I guess I should bind it to my DX8 or DX18 so I can tell for sure.
wfield0455 is online now Find More Posts by wfield0455
Old Jan 27, 2013, 03:23 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Frank
There isn't one on the DX10t, hence the use of a mix from a slider.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 27, 2013, 04:08 PM
Xantrix is offline
Germany, NDS, Uetze
Joined Jan 2013
Andy
Sure there is a trim button for "throttle/pitch". That button could be optionally reconfigured for trimming the gyro sensity. Or P1-4 without mixer.
Frank
Old Jan 27, 2013, 07:37 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
thanks, i rather buy the dsmx satellites over the dsm2, it gives me options in the future, thanks again, your post is very helpful.
keithy4129 is offline Find More Posts by keithy4129
Old Jan 28, 2013, 11:57 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
How To Use DX8 AUX3 Knob For Flap Trim?
I'm using the DX8 Flap switch positions 1&2 for two flap deployment settings. I'm using the Gear and AUX1 receiver channels for 2 flap servos?
Is there a way to program a Mix using the AUX3 knob to trim flap positions with a DX8 when Flap switch 1&2 positions are activated?
Thanks!
itsme2 is offline Find More Posts by itsme2
Old Jan 28, 2013, 01:57 PM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
I just tested going into switch select and assigning the knob to FlpTrm, now that does work, however it trims the flap in all three switch positions, not exactly what you wanted.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Jan 28, 2013, 03:02 PM
Barry2020 is offline
Find More Posts by Barry2020
United States, CA, Camarillo
Joined Jul 2012
You could do that with a AX3 > RFL mix, but you'd need to use another switch for Flaps, as the DX8 doesn't support Flap switch with channel mixing..
Barry2020 is offline Find More Posts by Barry2020
Old Jan 28, 2013, 03:24 PM
itsme2 is offline
Joined Mar 2011
I have a DX8 with a 6 channel Orange receiver. Why does my plane's electric motor start up at about one third power when I turn the transmitter off with the plane's battery still plugged in? Everything else is working ok.
Thanks!
Old Jan 28, 2013, 03:27 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Because Failsafe is not set properly. REBIND and make sure throttle stick is in the lowest position if that receiver supports Failsafe.
Old Jan 28, 2013, 06:02 PM
DXStickman is offline
Find More Posts by DXStickman
AMA 42272, from the 1970's
DXStickman's Avatar
United States, AZ, Kingman
Joined Oct 2007
Might want to remove the prop for your tests.....
DXStickman is offline Find More Posts by DXStickman
Old Jan 28, 2013, 06:19 PM
itsme2 is offline
Joined Mar 2011
That took care of it.
Thanks!
Old Jan 29, 2013, 02:00 PM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
Hé Andy, tomorrow the toy fair in Nurnberg starts.
Can you share anything about what we'll see from spektrum?
struggleforlife is offline Find More Posts by struggleforlife
Old Jan 29, 2013, 02:13 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Sure! There will be several Horizon employees showing what we have, will have, and plan to have!
Andy
Site Sponsor
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
