Old Jan 10, 2013, 12:33 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
We neither confirm nor deny any potential future products or features.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 10, 2013, 12:37 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
And, please accept our least sincere, most ambiguous apologies: stronger letter to follow!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Jan 10, 2013, 12:44 PM
Xantrix is offline
Find More Posts by Xantrix
Germany, NDS, Uetze
Joined Jan 2013
Andy
Thank you very much again.
May be it would be a good idea to leave this one way road again ASAP. I switched from another brand to the Dx10t thinking it will have a functional and useful flight pack sensor last week, but fortunately it is within the trying period from my dealer.
Regards,
Frank
Xantrix is offline Find More Posts by Xantrix
Old Jan 10, 2013, 09:16 PM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
It never ceases to amaze me that people buy expensive products without researching if it will fit their needs/expectations.
Fig Jam is offline Find More Posts by Fig Jam
Old Jan 10, 2013, 10:03 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
WOw..guess Im crazy..I did not use a Micrscope to Research the Dx10..but did read a bit about them...LIKED the servo Speed option..so I bought it....And I LOVE it still...does everything I want..and seems it can do MANY things I dont even know about!!
+ 1 for my DX10 radio
Weed89 is offline Find More Posts by Weed89
Old Jan 11, 2013, 12:30 AM
Xantrix is offline
Germany, NDS, Uetze
Joined Jan 2013
Normally you are right, but I'v never expected that the spma9590 could be soooo useless.
Frank
Old Jan 11, 2013, 01:11 AM
HeliSchorsch is offline
Find More Posts by HeliSchorsch
Joined Oct 2008
http://www.rctronix.de/wp/?p=18 may help. A version with additionaly capacity-alarm will come end of this month.
Schorsch
HeliSchorsch is offline Find More Posts by HeliSchorsch
Old Jan 11, 2013, 01:21 AM
Fig Jam is offline
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Frank
Yes, a lost opportunity for sure.
Old Jan 11, 2013, 04:15 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
The current sensor is far from useless if you use it as it was designed.It is a current sensor.The most important limitation for LiPo use IMO is not its capacity but is the voltage level it reaches as its capacity is being consumed.It seems like many expect a no brain solution to a complex issue.It is an unreal expectation to attempt to use the entire rated capacity of a pack if you are drawing its voltage below safe levels during the process.Its not about capacity as much as it is about usable capacity based on a number of variable factors.If the pack simply is not capable of delivering the expected amount of current for its entire rated capacity without dropping below safe voltage levels then reliance on capacity as the main indicator of when to end its use is useless if not dangerous information.It seems that there are many who believe they need to use capacity as a primary indicator and ignore the low voltage when it seems to activate the alarm prematurely.IMO this is a huge mistake in thinking.While I will admit that it(capacity) may be valuable information to have it will never be valuable as primary information.The important primary information to keep a cell/pack within its operating parameters is that you do not exceed minimum voltage levels under load regardless of how many mah you have consumed.Its resting voltage after the load has been removed means very little.Its minimum voltage under load is what is important.
aerocal is offline Find More Posts by aerocal
Old Jan 11, 2013, 04:18 AM
Kambalunga is offline
Find More Posts by Kambalunga
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
Originally Posted by emodell View Post
That's not so easy with a voltmeter. I measured the following voltages at a remot output of a receiver:
Left pin (red wire) to center pin (black wire) = 0.0 volts
Left pin (red wire) to the right pin (gray wire) = 3.39 volts
middle pin (black wire) to the right pin (gray wire) = 3.39 volts
1. Which pin is ground?
2. I think, plus and minus cables for each satellite receiver are required and can be connected together. Only the wire for the PPM signal must be extra. Is that correct?
GND (schwarz,black)-
3,3V (orange)+
TX-Spektrum(grau,grey)
2. It's not PPM it's a digital stream.
Kambalunga is offline Find More Posts by Kambalunga
Old Jan 11, 2013, 04:26 AM
Kambalunga's Avatar
Joined Jan 2009
Old Jan 11, 2013, 04:56 AM
Xantrix is offline
Germany, NDS, Uetze
Joined Jan 2013
Fully agree, but per cell and NOT total. Which sensor I should use for that in your opinion? And unless that is available the capacity would be the better indicator if you use it in the right way.
Sorry, the DX10t is a very cool and good receiver, but there are a lot of gaps in the sensor portfolio yet.
Frank
Old Jan 11, 2013, 05:48 AM
egicar is offline
Find More Posts by egicar
egicar's Avatar
Nuvolera (Italy)
Joined Jul 2007
Frank
Me too I fully agree with Aerocal.
Your question is very interesting, but has a great number of variables, like the number of cells you want to control. The sum of the serial connection of the cells gives the total voltage and I don't know if it is possible to make under control every sinlge cell: the TM1000 has a "voltmeter" for the main pack and a "voltmeter" for the ESC/Rx pack ...
The number of cells that each model (airplane, helicopter, glider, multirotore ...) can use is unpredictable (from 1 to X cells ...). So, as is it possible to realize a sensor that can cope with this variable?
Assuming that it is feasible, what is the added value of knowing that you have a cell in bad conditions or which cell of your pack is less powerful?
IMO, the main important useful information is that your LiPo/LiFe pack can let fly your model for a predictable time and that, in any case, you have the possibility to land if the total voltage falls below the value set by you.
You can analyze in advance your battey packs with specific tools, possibly on bench.
Only my 2 cents
Egidio
egicar is offline Find More Posts by egicar
Old Jan 11, 2013, 06:28 AM
Xantrix is offline
Germany, NDS, Uetze
Joined Jan 2013
In short: I would like to know the voltage of the worse cell with max current during flight. That's the only voltage I need. Then the capacity would be only for comfort reasons.
Frank
Old Jan 11, 2013, 06:40 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Frank
The capacity is critical for guys that fly multirotors. When the battery gets low we can't float home on servo power, it turns into a 12 pound brick. Max current is worthless to us in the air for a normal flight. Flying FPV, the capacity used in the battery can be critical to know when it is time to turn around so you have enough juice to get back home.
Sid3ways is offline Find More Posts by Sid3ways
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
