Old Dec 24, 2012, 01:50 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Flap System includes INDEPENDENT control of flaps and elevator.
So if you lied to your transmitter and told it you had flaps, then it would allow you to use the Flap System's elevator control to do what you want. Just leave the Flap settings 0.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Dec 24, 2012, 01:51 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by itsme2 View Post
Don't understand what you mean? I was referring to planes without flaps and all my planes have Y'd ailerons.
Thank you!
You ask for something on a switch to aid in landing and gave up elevator as an example.
Use the Flap Menu to provide to Elevator compensation you are looking for and put it on a switch.
freechip is offline Find More Posts by freechip
Old Dec 24, 2012, 01:54 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Thank you!
"Crow" is typically a combination of flaps down and ailerons up. What I'm saying is that you can still do the ailerons up part even though you dont have flaps. The issue is that you cant have y'd ailerons because they both wont go up when they are y'd. You would have to seperate them and put one on aileron channel and the other on aux1. You would need to select dual aileron as wing type, which renames aileron channel as RAL and aux1 as LAL. Then you just use a mix tied to a switch that when activated both ailerons move up an equal amount but still act as normal ailerons as well.
DamonH is offline Find More Posts by DamonH
Old Dec 24, 2012, 02:02 PM
wjs is offline
wjs
Find More Posts by wjs
wjs
William
United States, MI, Brighton
Joined Oct 2012
Thank you!
If you wanted to use spoilerons and only have L&R ailerons, then you would have to seperate aileron servos (i.e. ditch the Y). My second is on Aux ch, but depends on rx. Set your wing type to flaperon or which ever is most appropriate for your model. IIRC, you then set the % direction (+-, spoileron vs flaperons) in the Flag System in function list and can also mix in some elev there if wanted. If you can't seperate the Y (i.e. you don't have a spare ch), then not sure much you can do.
wjs is offline Find More Posts by wjs
Old Dec 24, 2012, 02:29 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
How common and/or usefull is using a flaperon/elevator mix like in the various scenarios described above and do they apply to sport planes?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Dec 24, 2012, 02:31 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Depends on the plane and how big the ailerons are. Small ailerons are the very wing tip generally do not benefit from Flaperons.
You can always try and start with some % used and try it a couple mistakes high and see if you like what the plane is doing.
Old Dec 24, 2012, 02:39 PM
wjs is offline
wjs
wjs
William
Joined Oct 2012
Thank you!
I tried it my epp reno racer as it comes in fairly hot. Just to play and see how it worked on my dx8 and how it felt on the plane. Spoilerons seemed to work pretty good and still seemed to have good roll authority. Did not get a chance yet to aggressively test different % (maybe 25%). Be conservative at first and experiment. Not sure I would try it on my PZ Corsair as would be affraid of resulting crash. Think some like it on their pz T-28, but have not tried that yet either on mine. Have fun.
Old Dec 24, 2012, 02:46 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by wjs View Post
... Not sure I would try it on my PZ Corsair as would be affraid of resulting crash. ...
That's the plane I "was" using Flaperons, in the end I found myself belly landing more & more without the use of flaperon.
I can get it to come in slow enough and almost land exactly where I want to.
Old Dec 24, 2012, 03:04 PM
wjs is offline
wjs
wjs
William
Joined Oct 2012
Corsair has a tip stall at slow speed. Did not the flaperons exagerate that tendancy?
Old Dec 24, 2012, 03:11 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I was using low % of flaperons, in the end it was programmed it if I wanted to show delayed flaps/flaperon programming on the radio but found I was not using that feature anymore.
Old Dec 24, 2012, 03:14 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
"Normally" flaperons are not good when ailerons extend to wing tips.
Old Dec 24, 2012, 03:24 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Yep that's what I said earlier
Old Dec 24, 2012, 03:28 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Ahhhhhhhh....lol. I missed that!
Old Dec 24, 2012, 03:41 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
If you reflex the ailerons upward, you can (need to) hold a higher angle of attack. It will help you come down (vertically) faster at lower forward airspeed. You'll need lots of elevator.
Try it sometime - start high, though!
Andy
Site Sponsor
Old Dec 24, 2012, 03:43 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I will thanks for the advice, it will help when I come down from 1530+ft using my Spektrum radio gear. LOL little promo..
No Flaperons or Reflex use for landing.
Happy Holidays everyone.
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
