Old Dec 06, 2012, 09:46 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Originally Posted by AndyKunz View Post
Since you're on 2.04, it's super easy.
Just let it do it automatically all the time.
Andy
Thanks!
DamonH is offline Find More Posts by DamonH
Old Dec 06, 2012, 09:51 AM
CiprianGugu is offline
Find More Posts by CiprianGugu
Look Up
CiprianGugu's Avatar
United States, TN, Jamestown
Joined Nov 2003
Originally Posted by itsme2 View Post
After two days of being hooked up to the factory charger for the initial charge I got the 5.5V reading, is this correct or should I be concerned?
If you left it on the charger for 2 days, you might have cooked the battery. The way to charge the stock NiMH battery on the stock charger is to feel it from time to time, and if it gets warm it is charged.
Just take the battery out and look at it for any signs of leakage or something else unusual.
CiprianGugu is offline Find More Posts by CiprianGugu
Old Dec 06, 2012, 10:08 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
itsme2,
CiprianGugu is correct, I cooked mine overnight... Do yourself a REALLY big favor and order this:
http://www.hobbyking.com/hobbyking/s...dProduct=19481
I charge the transmitter every other week if that... sometimes I go the whole month.. AND I have turned the back light on to continuous..
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Dec 06, 2012, 10:46 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
The initial charging instructions I received with the DX8 said it could take up to 30 hours on the iniitail charge, I didin't have it on the charger much over that and the pack was warm when I took it off the charger. Pack is not leaking or bulged. What is the correct voltage for a fully charged DX8 pack, is 5.5V within the correct range?
Thank you.
itsme2 is offline Find More Posts by itsme2
Old Dec 06, 2012, 11:06 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
The 30 hrs is for the lipo I believe.
The charging instructions you got with your radio (manual) are.
Originally Posted by DX8 Manual
You should plug the included 12-volt AC to DC power supply in for 10 to 12 hours to fully charge the battery.
The 30hrs is for the lipo
When charging the optional SPMB4000LPTX, a full charge can take up to 30hrs depending on the initial charge state of the battery.
freechip is offline Find More Posts by freechip
Old Dec 06, 2012, 11:07 AM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Thank you.
The 30 hours are only valid for the LiPo. Since it is a 4000mAh one and is charged with 200mA (maximum, at the end less), it can take this long. The NiMH is full after maximum 14hrs (200mA charging current, 2000mAh battery).
Normally NiMH should stand overcharging with 1/10c. They get warm. But you better keep an eye on them.
Mukenukem is offline Find More Posts by Mukenukem
Old Dec 06, 2012, 11:47 AM
Look Up
Joined Nov 2003
Thank you.
I am not at home, but I will see what mine says. I think that mine shows a bit more than that when fully charged.
Old Dec 06, 2012, 12:21 PM
GBRellic is offline
Find More Posts by GBRellic
GBRellic's Avatar
Canada, BC, Vernon
Joined Mar 2009
Thank you.
5.5V is the average full charge reading I get, sometimes 5.6, sometimes 5.3, depending on my morning before flying charge time. I fly weekly year round and multiple times during the week in warmer months (above 0)
I have been using this original NMH since Dec 2010 and consistently charge for one to two hours on flying day mornings.
Plug TX in, walk the Dog, load the truck, make a samich to go, grab TX and I'm outa here.
Brian T.
GBRellic is offline Find More Posts by GBRellic
Old Dec 06, 2012, 12:48 PM
itsme2 is offline
Joined Mar 2011
Thanks Brian, good to know I apparently did not overcharge mine.
Old Dec 06, 2012, 02:57 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Does anyone know what would cause "Internal error----none" when I try to import a model into my DX8? I just completed the v2.06 update and was trying to transfer a Habu 32 file that I downloaded from the Spektrum website. Thanks.
Old Dec 06, 2012, 03:04 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Open the file with WordPad and make sure it's all readable.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Dec 06, 2012, 03:11 PM
swashplates is offline
Find More Posts by swashplates
swashplates's Avatar
Schweiz, BE, Uttigen
Joined Mar 2011
My cold weather problem part 2:
I did some investigation and it seem that every requiremet for a faultless operation is given.
But what i have found is, that my telemetry works even when the rx shows no reaction. On the telemetry screen for antenna fades, following is immediately displayed after powering on the heli.
Name: ImageUploadedByTapatalk HD1354828249.406817.jpg
Description: (null)
swashplates is offline Find More Posts by swashplates
Old Dec 06, 2012, 03:12 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Andy
It is...all the way to the bottom where it says *EOF* which I assume means end of file?
Old Dec 07, 2012, 05:36 AM
Joined Jan 2011
itsme2,
You will need to really pay close attention to that battery. Just because the volts reading is nominal, it is possible that the battery capacity has been degraded. When I cooked mine I got the 5.5v reading off the charger, but flight time at the field was significantly less than what I got on the day I opened the box. Be very careful....
KKKKFL
Old Dec 07, 2012, 06:47 AM
itsme2 is offline
Joined Mar 2011
Originally Posted by Franco2fly View Post
itsme2,
KKKKFL
It's too bad that the charging circuit doesn't have an automatric cutoff for the nimh battery.
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
