Old Dec 04, 2012, 10:01 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
That makes sense, also another thing to watch out for is when using telemetry with a NON Date Ready receiver. Some of these and some of the time will cause the TM unit to go into bind mode, it's recommended to remove the signal wire if this is the case.
freechip is offline Find More Posts by freechip
Old Dec 05, 2012, 11:32 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
What is the biggest SD card the DX8 will take, does it make any sense to go over 16GB?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Dec 05, 2012, 11:53 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Thank you!
The only way you'd fill a 16GB memory card is if you owned Tower Hobbies, Hobby King, and Horizon Hobby and programmed their entire inventories into your radio.
Sid3ways is offline Find More Posts by Sid3ways
Old Dec 05, 2012, 12:15 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
I don't think that would do it. At about 15k per model file, it would hold over a million models.
Although, if you are going to do telemetry and save the log files, it would make sense to get a big card.
jhroof is offline Find More Posts by jhroof
Old Dec 05, 2012, 12:20 PM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
Yea, but I do Record all telemetry data every time I fly. Have yet to look and see how big the files are. Might last another 5 years.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Dec 05, 2012, 01:37 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Thank you!
128M is plenty.
The advantage of the large cards (largest I've used is a 32g card) is that the larger allocation units are easier to keep up with when logging telemetry in a DX8.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Dec 05, 2012, 01:44 PM
jhroof is offline
Orlando, Fl
KKKKFL
I think it keeps re-writing over the file unless you change the name. It would be nice if the software would increment the file name each time you start a model.
Old Dec 05, 2012, 01:49 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
It just adds to the file. When you view it using the STI app all the flights are logged.
Old Dec 06, 2012, 08:40 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
All,
I'm going to be doing the 2.06 update and have a couple of questions. When I do the update I should say "yes" to all the converting? Once the update is complete, do I then need to go back and make corrections on the models that were converted? Thanks.
DamonH is offline Find More Posts by DamonH
Old Dec 06, 2012, 09:15 AM
itsme2 is offline
Joined Mar 2011
I have a DX8 with the Nimh battery pack which is indicating 5.5V fully charged, is 5.5V the correct fully charged number?
Thank you.
Old Dec 06, 2012, 09:29 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by DamonH View Post
All, I'm going to be doing the 2.06 update and have a couple of questions. When I do the update I should say "yes" to all the converting? Once the update is complete, do I then need to go back and make corrections on the models that were converted? Thanks.
If you are coming from 2.05 and made the corrections already you select "NO". if you are coming from an earlier version and or haven't made any corrections manualy then select "YES"
Old Dec 06, 2012, 09:31 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Thank you.
How do you know it's fully charged? 5.5V sounds about right considering there is an acceptable tolerance from the manufacturer on the voltage being displayed and the actual batt voltage.
Old Dec 06, 2012, 09:35 AM
itsme2 is offline
Joined Mar 2011
After two days of being hooked up to the factory charger for the initial charge I got the 5.5V reading, is this correct or should I be concerned?
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Thanks, I currently have 2.04. One more question, what do you mean when you say "haven't made any corrections manually"? Do you mean servo reversing or sub trim adjustments?
Old Dec 06, 2012, 09:41 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Since you're on 2.04, it's super easy.
Just let it do it automatically all the time.
Andy
Site Sponsor
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
