Old Dec 01, 2012, 12:28 PM
Barry2020 is offline
Find More Posts by Barry2020
United States, CA, Camarillo
Joined Jul 2012
According to this Spektrum table (DSMX Insert), AR8000 supports both DSMX and DSM2.
Why does the the Tx have the Frame Rate Menu option to support DSMX or DSM2? Or does that option mean DSM2 only? Why doesn't it just accomodate the type it's binding with?
Barry
Barry2020 is offline Find More Posts by Barry2020
Old Dec 01, 2012, 12:30 PM
GBRellic is offline
Find More Posts by GBRellic
GBRellic's Avatar
Canada, BC, Vernon
Joined Mar 2009
Helps a lot, thank you both.
Am I correct in also stating that the AR8000 will NOT function without the satellite?
GBRellic is offline Find More Posts by GBRellic
Old Dec 01, 2012, 12:34 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The remote receiver is mandatory, yes.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Dec 01, 2012, 12:36 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Barry
http://www.rcgroups.com/forums/showt...2#post17524191
http://www.rcgroups.com/forums/showt...2#post18822668
http://www.rcgroups.com/forums/showt...2#post18850343
http://www.rcgroups.com/forums/showt...2#post21919464
Andy
Site Sponsor
Old Dec 01, 2012, 12:44 PM
Joined Jul 2012
So, the Frame Rate Menu is confusing on the DX8.
What the "DSMX" option means is "DXMX or DSM2", while the "DSM2" option means "DSM2 only".
Old Dec 01, 2012, 12:53 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
And as noted in those threads above, Frame Rate is symmetrical with DSM2/DSMX.
If you set it to 11ms, then in practice it means "Allow 11ms if the rx can do it" or "Force 22ms because my servos need it."
Andy
Site Sponsor
Old Dec 02, 2012, 09:03 AM
swashplates is offline
Find More Posts by swashplates
swashplates's Avatar
Schweiz, BE, Uttigen
Joined Mar 2011
Usage in cold temperatures
Hi, yesterday i went to the field at low outside temps little above 0 Celsius (32Fahrenheit)
I took my heli out of the warm car, pluged in the battery and did a 12 Min flight.
Then i changed the battery and the rx (AR8000) did not initialize.
Back home inside i tried again and it worked as usual. So i guess it has something to do with the cold outside temperature.
Today tried again outside...no luck!
Is there a temperature sensor inside the RX who avoids flying in cold temperatures?
swashplates is offline Find More Posts by swashplates
Old Dec 02, 2012, 10:09 AM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
I fly in temps colder than that and the AR8000 works fine. Perhaps you can try another Rx.
Buschbarber is offline Find More Posts by Buschbarber
Old Dec 02, 2012, 10:14 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
May NOT be the RX- cold batts don't work -and sometimes connectivity is affected which is a very bad problem and should be carefully checked -looking, tugging, pushing, pulling, all the connections
richard hanson is offline Find More Posts by richard hanson
Old Dec 02, 2012, 01:26 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Do you use a FBL system ? It is a good idea to let the heli cool down to ambient temperature. Of course not the battery.
But there is nothing that prevents the RX from working at low temperatures. Only your fingers
Mukenukem is offline Find More Posts by Mukenukem
Old Dec 03, 2012, 01:25 AM
Joined Mar 2011
Yes i have a MICROBEAST. But i thought when the BeastX is initalised it confirms it with a short up/ down with the Swashplate and it did. So i think it must be the RX because whatever it do on the TX, there is no reaction on the Heli. (Landing light etc.)
Old Dec 03, 2012, 09:06 AM
Vienna, Austria
Joined Oct 2010
Do the lights on the RXs go on ?
Maybe you have the radio too close to the RX ? Try it with 3m+ distance. If the radio is too close, the RX circuitry can be overdriven by the strong signal.
Btw, with a Microbeast you can have some temperature-related drift, if you have too much temperature change after initialization. But this has nothing to do with your RX problem. Do you have the latest Airware installed in your, well, which radio do you have ? DX8 ?
Old Dec 04, 2012, 02:34 AM
Joined Mar 2011
Hi, thanks for the answers
the rx lights are off. I will try that with the distance but why did it work when its warmer. Does the temperature infuluence the radio transmission efficiency?
Old Dec 04, 2012, 04:15 AM
Vienna, Austria
Joined Oct 2010
Spooky. No, RF is usually not influenced by the temperature (at least not +-20C). Also, the radio works internally with 3.3V, so this can also be no issue. Maybe you have another RX to crosscheck this beaviour.
Old Dec 04, 2012, 09:41 PM
AeroKen is offline
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
Some time ago I posted this as part of a larger rambling post:
Originally Posted by AeroKen View Post
Some rambling thoughts on telemetry...
At the field I always power the tx off between flights. Before a flight I power the tx up, then plug in the flight pack. I never ever have a problem with the receiver not connecting. However about 1/3 of the time the tx doesn't seem to end up seeing the telemetry. Irritating, but since telemetry is not that important to me I usually don't notice until after the flight if at all, and it doesn't bother me much. However it is clear that this is a problem that would need to be solved if I was actually going to rely on telemetry for anything.
I believe I've solved the telemetry not connecting problem by making sure the transmitter is farther away before plugging in the flight pack. I have the telemetry antenna going out a hole in the bottom of the fuse and tapped to the bottom running aft. At our club field we have pretty standard starting tables. My habit has been to put the tx on the side of the table behind the wing - easy to see when putting in the battery, etc. I'm guessing that's just a little too close to the telemetry antenna on bottom of the plane. I've found that if I put the tx behind the plane with the antenna oriented at right angles to the telemetry antenna it connects to the telemetry every time. Behind the plane with the antenna parallel to the telemetry antenna mostly but not always connects.
AeroKen is offline Find More Posts by AeroKen
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
