Old Oct 30, 2012, 10:37 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
When I fly the DX10t (not very often), the biggest thing for me to remember is to flip out the antenna. I've gotten so used to not pulling an antenna out (like we all had to do for 72) that it's very easy to forget.
The first Preflight Checklist default item for a DX10t is to pull out the antenna.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Oct 30, 2012, 11:32 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
hey guys whats the problem with using the telemetry module with opto isolated esc's? my guess is it is no longer isolated.
keithy4129 is offline Find More Posts by keithy4129
Old Oct 30, 2012, 11:33 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Correct. If you do a little googling you can find the explanations about exactly why.
Andy
Site Sponsor
Old Oct 30, 2012, 12:02 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
Andy
Didn't find on a search. I am using a CC160 HV and an AR12120 with the TM1000. Does the flight pack sensor create a problem?
Harry
Harry H is offline Find More Posts by Harry H
Old Oct 31, 2012, 08:00 AM
Sid3ways is online now
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by Skidman View Post
This is what I would do, and actual do with all of my radio setups:
Use a TM1000 and monitor the signal quality: first with the normal range test procedure and then in ordinary flight. If you see too many fades put it down.
Paul
Ok I have picked up a TM1000 and will put that to use. If I have any issues I'll come back and post my results.
Andy - Certainly feels weird pulling the antenna out each and every time, I certainly have forgotten to do so and will add that to the check list for sure.
Sid3ways is online now Find More Posts by Sid3ways
Old Oct 31, 2012, 09:29 AM
Joined Aug 2010
Andy
is there a way around the "issue"?
Old Oct 31, 2012, 09:33 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Why do you need it isolated? If your answer is "RF noise issues" that were a valid reason on 72MHz, then with all likelihood there is no issue.
The big thing to watch is to make sure you don't exceed the 12S input and to make sure you don't have any other places where they are connected (such as using the BL RPM sensor) at different potentials.
Andy
Site Sponsor
Old Oct 31, 2012, 10:44 AM
Joined Aug 2010
Andy
gotcha, i wasnt worried about rf noise, didnt know if there were any other issues.
Old Oct 31, 2012, 02:29 PM
swashplates is offline
Find More Posts by swashplates
swashplates's Avatar
Schweiz, BE, Uttigen
Joined Mar 2011
innoflyer
Thanks Guys
I have a swiss produkt called innoflyer...
http://2010.innoflyer.ch/A2-Serie-Be...g-Air:::2.html
It is in German but you can use Google translate. it's a very solid and scalable product
Originally Posted by freechip View Post
What light kit do you have?
Like I mentioned to you NOT every light kit is On/Off receiver switchable.....
The light kit I got on my SC has nav lights and tail beacon/strobes come On when power is applied to the plane BUT the Taxi lights and Landings light are recevier Switchable On/Off. The light kit receiver wire connector as 3 wires, Blk/Red for power along with White for signal for On/Off
Some less expensive kits only have Blk/Red and this is an easy sign it's NOT switchable.
All the kit requires is to see the switching channel go from -100% to +100%
Post a link to your light kit.
swashplates is offline Find More Posts by swashplates
Old Oct 31, 2012, 03:58 PM
Skidman is online now
Find More Posts by Skidman
USA, FL, Oviedo
Joined Jan 2010
Since you are flying very expensive aircraft I think that you will grow to appreciate the telemetry.
Skidman is online now Find More Posts by Skidman
Old Oct 31, 2012, 04:05 PM
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Ive had multiple Aurora 9s to take advantage of the Telemetry and a Futaba 8FG with the Quanum telemetry system attached. I needed at least 12-14 channels or more so the DX10 seemed like the right solution since it had telemetry. I'm a little worries though if range is going to be an issue!
Old Oct 31, 2012, 05:01 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
I dont fly what you guys would consider "expensive planes" my Queen is a durafly 1100mm A-1 skyraider.....with that said, Is there any telemetry stuff ( As My Dx8 came with the module) That a Mear mortal like me would really have any use of?
Weed89 is offline Find More Posts by Weed89
Old Oct 31, 2012, 05:14 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Yes, like how fast you are going, how high you are flying, knowing when your battery is depleted... All depends on you.
Harry
Old Oct 31, 2012, 06:11 PM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
Hobbies aren't about "use of", they're about want.
Dave H. is offline Find More Posts by Dave H.
Old Oct 31, 2012, 06:16 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Once you connect the TM1000 to the receiver you will instantly have rx voltage. Depending on the receiver used you may have Flight Log info. Then you can monitor the main flight pack voltage with the voltage sensor and on in-runner motors you can monitor there temps or install the temp sensor like I did on the ESC.
Once you start using the main flight pack voltage you will really start to understand why telemetry is becoming more and more popular with many looking for it as a must have for there new radio purchase.
freechip is offline Find More Posts by freechip
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
