Buy from HH.
If you buy from LHS, then you're looking for a radio with Airware 2.02 indicating its a recent radio. |
Latest blog entry: Get Help by posting your SPM File
Central California
Joined Dec 2006
Im going to assume a DX8 and at least 7ch Rx. You are going to want to set it up as Flaperon wing 2ele-2rud tail.Plug everything in as labeled on the Monitor screen and go from there. Its hard to tell exactly what you are wanting beyond basic setup. elevon or vtail? This isnt your model configuration. You want the ailerons to also work as flaps I assume? You want the elevators to work as ailerons also on a switch? ele-flap? I dont quite understand exactly what behavior you are wanting. Is this a kit thing? Do you have an idea of how much throw you are going to put on the surfaces? Start at a basic setup and go from there. Like Franco said.Keep it simple to start. |
Thank you Tatonka , I'll give it a shot.
Mugen4Lfe; I hadn't thought about the cooler temperatures. That might explain the longer glide due to the denser air. Thanks If anyone would let me know if I can setup spoilerons with this setup I would appreciate it. I'm currently only using 4 channels of the AR6210. DX8 AR 6210 DSMX Wing type Dual ailerons, normal tail |
USA, FL, Tampa
Joined Mar 2010
Eugene, Oregon
Joined Feb 2011
flaperon
Have a Multiplex TwinstarII bound to the DX8. 6 chnl Rx
wing configuration is flaperon. two aileron servos, ral into ail channel, lal into aux1 flaps to the flap switch. when I go to flap1 or flap2 the lal goes down and the ral goes up. how do I reverse the lal servo when the flap switch is in 1 or 2? flap switch at 0 the ailerons work correctly |
USA, FL, Tampa
Joined Mar 2010
The lack of information will only provide you with guesses.
The way the flap system works it should work if your ailerons work in the first place. If you say the ailerons work with flap position 0, then it should work for the other positions. If you export your model file setup, we could look and see what is going on. |
Joined Sep 2012
Would you have to send an older DSM2 marked AR8000 in for the DSMX firmware update? The earlier DSM2 DX8s had to be manually updated via firmware, but the user could do that at home themselves via download/SD card. They had the DSMX hardware, but you needed to "awaken" DSMX with the new firmware.
| Thread Tools | |
| Question Receivers that work with Spektrum Radios that are not made by Spektrum | BD Flyer | Radios | 29 | Sep 26, 2010 04:09 AM |
| Discussion Spektrum AR6100E or Spektrum AR6100? | LaurenceGough | Off-road Cars | 23 | Aug 06, 2009 05:33 AM |
| For Sale Parkzone 5ch DX10 w/Receiver ch54 | CarlHill | Aircraft - General - Radio Equipment (FS/W) | 7 | Jul 10, 2009 12:07 PM |
| Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? | Bigmaxy | Radios | 1 | Jan 19, 2008 07:57 PM |
| Sold GeForce 8400Gs PCIx DX10 video card | GFBurke | Non R/C Items (FS/W) | 6 | Sep 05, 2007 10:43 PM |
