Old Oct 10, 2012, 11:20 AM
Tom Antlfinger is offline
Find More Posts by Tom Antlfinger
Joined Oct 2012
DX-18 Update 1.03
Been flying my UltraBandit now for 12 flawless flights with the DX-18 /1222 DSM2 combo. Minimal Fades compared to my 12X..... Full house with TM1000, GPS, JetCat Sensor, Altitude, Airspeed, and G meter----->STi.
Question is: What is the RF Binding update specifically adressing in the 1.03 update? Is there any need to re-bind after the update?
TA
Tom Antlfinger is offline Find More Posts by Tom Antlfinger
Old Oct 10, 2012, 11:28 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Dx18 Thread
http://www.rcgroups.com/forums/showt...585650&page=69
Improved RF binding performance
freechip is offline Find More Posts by freechip
Old Oct 10, 2012, 01:06 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Sounds great, Tom!
It addresses the need that some guys (not all) had that meant they needed to hold the tx against the rx antenna, usually on the ultra-micro models. You don't need to re-bind after updating.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Oct 10, 2012, 01:16 PM
Joined Oct 2012
Thanks Andy......and Freechip......:>)
Old Oct 10, 2012, 02:13 PM
emodell is offline
Find More Posts by emodell
Joined Oct 2012
Hi Andy,
I am an avid model airplane pilot from Germany. Since 4 years I fly with the spektrum systems without problems. In February 2012 I bought a DX10t with software version 1.02. Even so I was always very happy. 4 weeks ago I made a software update to 1.04 and have many interferences and holds about 250 meters at different gliders. The radio was posted to the service, and completely changed. I was very happy about the new DX10t, but now there are some more problems.
1. 4 models with AR6255, AR9000 with 2 satellites and AR7000 with 1 satellite have many problems with the range. 5 to 10 holds for a 10 minute flight. This is too much! With my first DX10t with airware 1.02 I have not this problems.
2. This receivers you can bind only after 3 to 5 attempts. When binding, there are too many failed attempts.
3. An AR 5000 receivers can not be bound.
But the model can be flown without problems!
4. For receivers which were bound with DSM2, you can not see the transmission method DSM2 or DSMX in the left tupper corner, why?
Can you help me? The service advises me to a renewed Update 1.04 from the community site. I have already 1.04 in the DX10t. What can I do?
Sorry for my bad english!
Bernd
emodell is offline Find More Posts by emodell
Old Oct 10, 2012, 02:46 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
1) One hold is too many!
2) What happens if the transmitter antenna is against the receiver antenna? Can you contact Horizon DE about this?
3) This is because the radio transmits DSM2 when it thinks it is un-bound. It has to transmit something, and DSM2 22ms/1024 is the lowest it supports, so that is what it sends.
4) I have never seen this. I suspect this is the same as 2 and 3, though, based on your other comments.
Andy
Site Sponsor
Old Oct 10, 2012, 05:53 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
I've ran into a little problem using my new DX8 in place of my DM8 module and 9C.
With the module I didn't have model match, nice feature to have but it's causing an inconvenience when using using a satellite and Copter control board.
I use the copter control board W/ satellite on a micro quad and Tri copter, switching between the two is simply unhooking the ESC leads removing 3 nuts and mounting the module on the tri or quad. I then flash the board with the correct configuration and fly... well I use to without model match!
Now that I'm using the DX8, model match is requiring me to rebind the satellite each time I switch between the two copters, is there any way to turn off model match? Is it possible to have 2 model memories using the same reveiver ID? I tried copying the quad memory to another slot thinking the bind data would transfer with it...nope.
Rebinding each time is not really a big deal... just a step I'm not use to doing when switching between these two small multi's.
John
shultz is offline Find More Posts by shultz
Old Oct 10, 2012, 05:58 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Receiver not only learns the radio coding but also the memory location. So each time you change model memory using the same receiver you will need to rebind.
No way to turn off model match.
Old Oct 10, 2012, 06:04 PM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Model Match is based on the Tx Id and the model memory position.You may be able to defeat it by binding the Board and Remote to say Model 1.Then after you swap and reflash the board Copy the other model file to the position the Rx is bound to.Im not sure this would work but you can try it.
The best thing to do is probably to rebind when you swap.Less chance of a mistake/accident.
aerocal is offline Find More Posts by aerocal
Old Oct 10, 2012, 06:06 PM
shultz is offline
Joined Sep 2009
bummer, in this case anyway. thanks for the info.
John
Old Oct 10, 2012, 06:19 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
You can bind two Rx simultaneously to a DX8 if it is in DSM2 not DSMX mode. Not sure if this will get around the problem.???
John
jj604 is offline Find More Posts by jj604
Old Oct 10, 2012, 06:21 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
His problem is that he's using one receiver for two rc and changes model programming.
Old Oct 11, 2012, 01:39 AM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
Ah, thanks. More difficult problem.
Old Oct 11, 2012, 05:49 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Not diffucult at all, all he needs to do is have extensions in the bind port and carry a bind plug with him.
For what ever reasons one would want to only use one receiver for multiple rc then with model match one needs to BIND when changing model memory.
Old Oct 11, 2012, 05:53 AM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
OK, you win. What I should have said is "More difficult solution"
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
