Old Oct 09, 2012, 10:27 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Originally Posted by onewire View Post
Mine tried to drink a beer one night.
Mine tried to BASE jump from the desk one night, but it wasn't because of the vibe alarm. My fault.
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Oct 09, 2012, 11:10 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
"Sviking" His DX8 also tried to do a Kamikaze last month
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Oct 10, 2012, 05:53 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
Were it me, I would purchase 4 double A cells get the soldering iron out, and make a "stand-alone" battery pack. You just need a spare connector, Red is positive goes in the center, Black is negative goes to the outside, you don't use the Yellow, signal lead.
You really need a power source that is NOT coming in on the throttle channel. Insert the
bind plug in the Bind/Data port, plug in your power source, ( I usually use the Aux1 channel) pay attention to the flashing light, it should be nice and bright. Only use one servo, on Elevator or Rudder, or Aileron. This is the cleanest set up and it will help you
isolate where the problem is coming from. You might have a bad servo that is drawing down the current to where the bind is not taking place, so be ready to try different servos.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Oct 10, 2012, 06:50 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Or one of these 2$ holder with a servo lead soldered to it.
freechip is offline Find More Posts by freechip
Old Oct 10, 2012, 08:51 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Don't put spring contacts in an airplane!
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 10, 2012, 09:02 AM
Zeeb is online now
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Hmmm.......
freechip; haven't we been through this battery holder business before with a similar answer from Andy ????
Zeeb is online now Find More Posts by Zeeb
Old Oct 10, 2012, 09:08 AM
Joined Jan 2011
I concur with Andy on the spring comment. Besides, it only takes 5 minutes or so to solder up a pack. cut 3 short wires about a half inch, and strip each end.
Tin these wires and cut them a little shorter( use some nail clippers).
Tin the positive and negative sides of the battery. Here the
key is to have a heavy duty and very hot iron. You want to QUICKLY create a small
solder nub. I have some ELECTRICAL rosin that makes the solder flow easily. DO NOT
use ACID core solder. Finally, connect Positives to negative bottoms of middle batteries
and finish up with your servo lead. Red goes to positive (the nub end of the battery), black to the base of the end battery. You can get Heat shrink but I usually just do a
wrap with black electrical tape, just don't skimp.
Takes less time to do that it did for me to type these directions.
KKKKFL
Old Oct 10, 2012, 09:14 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Zeeb View Post
Hmmm....... freechip; haven't we been through this battery holder business before with a similar answer from Andy ????
Weren't we talking about making a 4.8v pack for BINDING purposes instead of using an ESC/BEC.
I was sure that's what we were talking about, having binding issues and using an esc it was recommended to use a seperate 4.8v-6.0v pack inserted directly in the RX for binding purposes.
If you think this is wrong to do then by all means post your comment.
The previous discussion with Andy on the subject of AA cell holders was about radio use and of course as a RX pack in a plane would also apply.
Trust me after that conversation I fully understand the reason behind using or in this case not using these spring loaded holders in radio and or aircraft even if MANY radios (air) still use lose cell holders.
Nothing wrong with my post suggesting to use them for a pack to use during BINDING.
You can correct me if I'm wrong.
Old Oct 10, 2012, 09:19 AM
Joined Jan 2011
True enough...
We were talking about Bench set up... So your comments are spot on, and you really could just use double A's. I just go the extra mile and use NiCads, which allows me to charge and come closer to the actual flight pack.
KKKKFL
Old Oct 10, 2012, 09:23 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ Franco2fly - Infact I use my now replaced with lipo Stock OEM 4.8V NiMh pack from my DX8 as a power source for setting up my radio systems. Just made a small adapter and secured it using heat shring. The adapter is home made using a 3" small servo extension and having removed the shroud around the end with the pins, the pin spacing is the correct format for the stock tx pack connector.
In the pic it is gettting ready to be charged, being an older pic I just reused you don't see the now heatshrink connection making it a semi permanent connection.
Zero soldering involve but a little bit of plastic removal.
PS: For those that are wondering why in may not be recommended to use a AA Cell Holder for flight pack, it's because some believe that the vibrations could cause a cell to come lose out of the holder and you then lose all power.
Old Oct 10, 2012, 09:34 AM
Joined Jan 2011
Nice pic... (worth a thousand words)
And I'll re-state for folks following the thread. A clean power source not relying on the
BEC is not only nice, it can really eliminate problems that revolve around throttle conditions for the initial stages of setting an electric model up. Not bad for Nitro either.
KKKKFL
Old Oct 10, 2012, 09:42 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Anytime I happened to use a ESC/BEC to power a system for what ever reasons other then flying. I just plug it in any channel since the bec will power the system regardless of the throttle.
The whole idea is to ensure you have a basic setup (k.i.s.s) as to avoid the least amount of possible failure when trying to figure out a problem.
Just using a direct power source just makes sense when trying to figure out what could be wrong.
Old Oct 10, 2012, 09:45 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
I'm sure many of the folks in the is thread are electric only flyers, so I would add a tip that having a 4 cell battery on hand for any bench setup work is a good idea, in addition to binding the receiver. Messing around programming an electric powered model using the main battery and BEC is not a good plan, unless you're actually ready to test the motor
If you have friends that fly nitro, you can always scrounge an older 4 cell pack off them, or as Freechip suggested, use a 4 cell holder for bench testing.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Oct 10, 2012, 09:53 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Pete
also scrounge a good in line volt meter
You will eventually find (if you do this enough) that a failure to bind is simply momentary battery depression on an old battery.
I use a partially depleted 4 cell pack and a in line meter to check out a new plane servo setups -( I do these for others so I don't want any surprises)
When you run into a binding/dragging/-stalling servo - the meter quickly drops . Well worth any extra effort.
richard hanson is online now Find More Posts by richard hanson
Old Oct 10, 2012, 10:08 AM
Joined Jan 2011
Past few responses are all on the money, now lets get back at the OP's problem "Failure to Bind" but just for the AR6200. I have seen this on several occasions. Early on, I was not sensitive to having the transmitter several feet away during the process. However, I have seen it once or twice when I was cognizant of the transmitter distance. Last time, I just turned everything off and started over. Cleanest of clean
would be trying to bind using a brand new ACRO slot, eliminating any previous model
mismatches.
Lets all put our 3000 mile long screwdrivers down and see what the OP has to say now that we've given him the best test environment.
KKKKFL
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
