Old Oct 08, 2012, 12:26 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
What voltage reading are you talking about?
Myself and other have reported our tx voltage display to be accurate.
My telemetry is a little off but that could be where I am tapping in for voltage connection.
freechip is offline Find More Posts by freechip
Old Oct 08, 2012, 12:31 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
TX batt
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Oct 08, 2012, 12:33 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Pretty sure you can send it in for service to have them calibrate it for you if this is something that is annoying to you that much.
Others simply adjust the alarm accordingly.
Old Oct 08, 2012, 12:36 PM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
I popped the HK LiPo in the back of mine... couldn't be happier. Charge once a month, reads 8.2 volts once the blue light goes out. At the field lasts all day, barely dropping.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Oct 08, 2012, 12:37 PM
Joined Sep 2012
I know. I was being facetious, hence the smiley.
And, no, they probably won't calibrate it. I actually asked a while back when I called about something else. They said it would be most likely be sent straight back with the work order saying nothing was adjusted and the TX was within specs (+/- 0.3V).
Old Oct 08, 2012, 12:42 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Like I said, if it is something that is bugging the owner of a radio that is showing a high voltage difference. Pretty sure they could have it serviced...
Originally Posted by AndyKunz View Post
... If you ever send your radio in, such as for an annual checkup, you should put in a note asking them to be sure to calibrate the battery voltage for you. They have the tools to do it properly and with no danger to the modelers.
Andy
But like I also said, many just opt to adjust the alarm setting and are ok or don't care what the actual numbers are displayed.
Old Oct 08, 2012, 12:45 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Picked up a DX-8 over the weekend, hopefully I haven't made a mistake
Is there any way to enable seperate flight mode trims (rudder / aileron / elevator) activated by the flap switch rather than the flight mode switch? On first and second glances this does not seem to be possible, I know I can move the flap switch functions to the F mode switch and get the seperate trims but I'd rather keep the switchology the same way I have on all my other radio's which is flap on the second in switch above the throttle stick with seperate trims for each flap position. I fly complex flap equiped planes pretty much exclusively...
Chris True is offline Find More Posts by Chris True
Old Oct 08, 2012, 12:49 PM
Joined Sep 2012
Regarding your quote from Andy, how about getting it right from the start? Also, that still does not invalidate what I was told about it being sent back unadjusted. Would someone send it in for that issue and not include a note in the work order they'd have to fill out anyway? Of course someone not, so that goes without saying.
Old Oct 08, 2012, 01:06 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Spektrum certainly doesn't seem to care what the numbers show. I'd hate for them to be making precision instruments when they can't be bothered to even properly adjust these before they are sold.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Oct 08, 2012, 01:08 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by crvnation View Post
That does sound hard. A properly calibrated DX8/10 voltage reading should be much easier and not have a 0.3V error said to be "within specs".
Yes if Spektrum can't even show accurate voltage, god knows what mess they would make of mah. It seems bizarre how they market the radios as these high end devices then make excises when things don;t work as expected. Bit more effort into QC and less into marketing perhaps.
Site Sponsor
Old Oct 08, 2012, 01:15 PM
Joined Sep 2012
That's what I don't get about these higher end TXs in their line-up. I've had some pretty cheapo TXs over the years with digital voltage readings (including a junk Spektrum RTF kit TX) and they read dead on when fully charged. Read right on with new disposable AA batteries, too.
Old Oct 08, 2012, 01:25 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
My DX8 & DX18 all read 8.4v when the blue light goes out indicating fully charge. If yours does not, send it to HH for service and have it calibrated. If one tech told you differently then speak to another until you get one that says they will do the work. When you do send it the radio include a note as to why you sent the radio for service.
Posting here won't get it calibrated any better or faster.
Old Oct 08, 2012, 01:32 PM
Joined Sep 2012
Why should one be out the money, packing/shipping time and their TX for who knows how long for something they should (and obviously can) have gotten right from the beginning? I don't know about you, but I don't consider the DX8 to be a junk TX and little things like this do nothing to help Spektrum's reputation, either. It only adds to the much larger issues that anyone can read about virtually anywhere on related forums.
Old Oct 08, 2012, 01:34 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I'm just glad my company isn't into making tx, we have a 8-10% tolerance for errors.
Old Oct 08, 2012, 01:36 PM
Joined Sep 2012
So I can avoid it...what company and what do you make?
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
