Old Oct 07, 2012, 08:04 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ Pavlos - sounds like everything is working. Have fun.
Like mentioned by Aerocal, the reason you can't choose flap switch in the switch menu is because that's not where you select it.
freechip is offline Find More Posts by freechip
Old Oct 07, 2012, 11:04 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Originally Posted by crvnation View Post
Since you took it upon yourself to scold me, is this not OT content as well? You're posting and perpetuating it. Pot, kettle.
Lol...skidder87, sertav, kokopelli, mhunter always used the term " pot kettle" see ther. I told you it was him again with a shill acct yet again. Jim g. Asked me to keep an eye out for this guy. He always pops up in your dx8 threads.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Oct 08, 2012, 02:07 AM
pavlos is offline
Find More Posts by pavlos
Joined Oct 2012
yes.. thank you guys..that makes sence...
as I said I needed fresh minds.. thanks for all the help again.. i think I'm ready for that maiden as soon as I find CG.. the first stumax at both of nicosia Fields..
pavlos is offline Find More Posts by pavlos
Reply With Quote  (Disabled)
Old Oct 08, 2012, 05:29 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by jj604 View Post
Honestly Andy, I know it's not your dept. but somebody at Spektrum needs to get biffed for the delay in getting a current sensor to the customers. It's not rocket science. Everybody else seems to be able to put an Allegro sensor in some heat shrink with a 1wire or I2c interface. And we even have people making their own.
The mAh used display on my FrSky stuff is the most useful bit of telemetry it has.
John
This is 100% truth. mAH used is by far the most important piece of info I want to see when flying my multirotors. I wish someone made an aftermarket one that would be compatible. I'm not up to building the circuit myself.
Sid3ways is offline Find More Posts by Sid3ways
Old Oct 08, 2012, 05:31 AM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by Mukenukem View Post
You don't want a 150A sensor withouth the capability of measuring mAh. You want this: http://rctronix.steinonline.de/wp/?p=18 (sorry, German. But if you are good with electronics just have a look at the schematics, it is a piece of cake)
A diy capacity sensor, using the Powerbox menu. Also, the JLog (logger for Kontronik ESCs) speaks spektrum telemetry.
Thanks for the info Mukenukem. I'm not sure I'll have the time to put something like this together myself but if worse comes to worse I'll try to make one. I wasn't aware the Spektrum current sensor didn't display mAH used, live mAH ratings are next to worthless except for bench testings.
Old Oct 08, 2012, 05:46 AM
pgoelz is offline
Find More Posts by pgoelz
pgoelz's Avatar
United States, MI, Rochester Hills
Joined Oct 2000
Out of curiosity, why is mAH used important to you? I can see why people might want to see it while flying, but honestly, I find that battery voltage is far more useful. Unless you are trying to predict remaining flying time more accurately than using a timer, having an alarm at an appropriate cell voltage threshold works great for me.
I still use a timer but if the timer has expired and I have not gotten a voltage alarm (at 3.5V/cell), I can continue flying. And if I do get the alarm, I can avoid further high throttle excursions and make it back to the field and land without stressing the cells.
Paul
pgoelz is offline Find More Posts by pgoelz
Old Oct 08, 2012, 05:53 AM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Paul
Because when flying multirotors, when hovering you are using minimal amps. Since you aren't pushing the battery hard the voltage doesn't generally sag much like it would if you were flying a plane and moving the throttle frequently. I could be 6500mah into a 8000 mah lipo and the lipo will still hang onto a decent voltage. When the copter is far away from me it helps me judge how quickly I need to get it back. I don't have the ability to "dead stick" in like an airplane does. My deadstick means I have 9K worth of equipment falling to Earth like a brick.
Entire pack voltage doesn't give me the whole story to help manage battery life. My flights can be 14-18 minutes so a timer doesn't generally give me an accurate flight time. If I'm trying to frame a shot then knowing if I can take an extra minute or two to try and get it right is all worth it.
When it comes to flying my standard airplanes, I agree, voltage monitoring is sufficient.
Old Oct 08, 2012, 06:10 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Agreed on multirotors I would much prefer mah used over voltage. Voltage is too flat with a quick dropoff so not easy to gauge remaining power. mah used gives a much better fuel level indication. Why Spektrum refuses to make such a sensor is strange but I've given up trying to figure out why they do anything.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Oct 08, 2012, 06:19 AM
pgoelz is offline
pgoelz's Avatar
Joined Oct 2000
I would imagine because deriving mAH consumed from a simple current sensor involves computation (ie., integration of current vs. time elapsed), which is more involved than sending a simple analog value.
I see how a multi rotor might be a different case. In the mean time, can you goose the throttle once in a while when you are getting near the end of the flight and see if that drives the pack below a reasonable voltage threshold? OK for sport flying, but maybe not if you are flying a photo mission?
Paul
Old Oct 08, 2012, 06:23 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Goosing the throttle isn't the best when trying to fly in a specific manner since on a multi all control is via motor control. You also have 4/6/8 motors pulling current so bursting the throttle causes a big pull on the lipo, not really a true indication compared to the power needed for hover and slow flight.
As for the complexity of a current sensor, just about every OSD around has this, it isn't that complex to do.
Site Sponsor
Old Oct 08, 2012, 06:38 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Paul, every microprocessor contains an accurate clock. mAh used is a trivial calculation. Multiply two numbers and add to the current value. And none of these current sensors send an analog signal, they all convert it to digital at the sensor.
Honestly it is simple to do with a Hall effect sensor. Quanum have had one that works just fine with their wireless LiPo cell voltage monitor for over a year for less than $20 from HobbyKing. The FrSky one also works well. I know there are several others, particularly from the European manufacturers.
I'm not a Spektrum basher but IMO they dropped the ball on this one.
John
Paul
jj604 is online now Find More Posts by jj604
Old Oct 08, 2012, 08:09 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
One of the small issues with mAh measurement is that with an ESC, power is delivered in pulses. To accurately measure current you need to be oversampling at a pretty good rate, much faster than the PWM frequency to your motor. Either that, or give up a little accuracy by having it averaged in hardware and then sampling at a lower rate.
The modelers who are most interested in this sort of thing are also the ones who are least interested in a device that goes inline in the power system due to the insertion losses. OTOH, a Hall-effect sensor is not nearly as accurate.
I've been down this path before I came to Spektrum.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 08, 2012, 12:04 PM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Andy
I've found that a simple RC LPF does a good enough job to filter the current sense voltage out of a modern high sided current sense amplifier IC. This is what most of the watt meters on the market appear to do too now. The accuracy is more than good enough for modelling use (where +/-5% accuracy or so doesn't really make too much of a difference). Also having a small enough current shunt (1mOhm) will keep insertion losses to a minimum that is negligible.
From experimenting with mAh on telemetry (with Hitec gear but it still applies to others) with my own current sensing PCBs, I never found it that useful. It's interesting to see how a pack is performing, but tbh your charger can tell you that already from mAh charged (if you discharge to the same flight pack voltage every time). Pack voltage is far more useful, as it really tells you how much life you have left and when your ESC is about to cut off.
The problem with a mAH reading is that the amount of energy you can pull from a pack varies depending on cell degradation and current draw. As everyone knows, as a pack gets older it won't have the capability to store as much energy as it used to. So the problem is that one packs empty is another packs 30% left or if your pulling really high current draws for a flight, you could get less mAh out of a pack than when flying around gently. Hence, with a alarm set to a mAh, it may not be triggered as the pack ages or depending how the flight was flown. Then without a flight pack voltage alarm, you could find yourself out of juice with no warnings.
To make a mAh reading useful, you need to track the discharge capacity and the charge capacity over time. Then you can then accurately estimate how much juice you have left during discharge and also tell if a pack isn't holding enough charge. Now its possible to note this down manually every you discharge and charge, but apart from a small percentage of modellers I can't imagine anyone could be bothered! You could automate this, as Laptop batteries do with their on board fuel gauge ICs - however for RC use this would push the cost of the pack up considerably and also require a standardised way of communicating with the onboard IC. Both not desirable. For an example of this, look at the replacement cost of a Laptop battery!
Where as voltage will tell you that your about to run out of juice. Remember your ESC will cut out on voltage, so you want to land before you hit this cut off!
mAh is a nice thing to look at, much like looking at a ground track from GPS telemetry. However once the novelty has worn off, its not something you look at again. I've found this with the flight current readings too. Once I had played around with it and seen that current drops off in flight, and that your under the ESC rating I never really looked at it again. The only useful time was to know when a motors bearings were on their way out and thus the current draw went up significantly. However I could tell this from shorter flight times.
mAh measurement is way overrated imo.
That's my two pence.
Cheers,
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Oct 08, 2012, 12:15 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Simon says...and I believe it!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Old Oct 08, 2012, 12:23 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Andy
That does sound hard. A properly calibrated DX8/10 voltage reading should be much easier and not have a 0.3V error said to be "within specs".
crvnation is offline Find More Posts by crvnation
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
