Old Oct 03, 2012, 08:45 AM
DXStickman is offline
Find More Posts by DXStickman
AMA 42272, from the 1970's
DXStickman's Avatar
United States, AZ, Kingman
Joined Oct 2007
Originally Posted by WhalleyB0Y View Post
Crap! I don't believe it! The right stick on my Dx8 has lost tension on the elevator and it won't return to center.
This is the second report in a week about a broken pin on the gimbal and it's a bit disconcerting. How old is your radio? Has it been exposed to excessive heat or cold? Any idea what caused the plastic to break?
I sent my old DX-7 to HH for a problem when it was 4 years old. It was repaired and returned to me at no charge, so I am sure HH will take care of you. That was the main reason I bought a DX-8....good service will always make a difference when it comes to decisions on buying new products.
DXStickman is offline Find More Posts by DXStickman
Old Oct 03, 2012, 09:02 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
I know there are others out there that use a "y" connector on the Bind/data port, especially for Telemetry set ups. USUALLY, the insertion of the bind plug on one of the "Y" legs causes the TM1K and the receiver to start blinking when power is applied. One just proceeds with the bind process. I said usually, because in the last couple days, I was upgrading a plane to use the TM1K, the radio in the plane was an older AR6200 w/sat rx. For some reason putting the bind plug in the "Y" did not put the TM1K into bind. I tried several times with no luck. Finally, I had to resort to the stylus in the side of the TM1K while fumbling with the stubborn Anderson power connector. I got it all bound and it is working but I am wondering why the "Y" did not work?
Has anyone else experienced this?
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Oct 03, 2012, 09:05 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Data cable to tm unit problems???
freechip is offline Find More Posts by freechip
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
To use a Y with the AR6200, you need to disconnect the yellow lead going to the TM1000.
Is it possible you got the Y reversed?
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 03, 2012, 09:12 AM
Joined Jan 2011
Anything is possible considering my poor eyesight, but I think it was plugged in correctly since it worked when I used the stylus, and I haven't changed anything in the wiring, but currently have the TM1K working just fine. If its plugged in backwards, I've discovered a better way to have Telemetry, cuz I get good altitude, good speed (using a soda straw over the Pitot and puffing on the straw), I get excellent RPM (using the Optical pickup) Color codes and connector changes notwithstanding, and good voltage, both Rx and Flitepak...
I am wondering if I should stick with the DSM2 AR6200 or go to a newer Receiver for the DSMX capability, but I'm not doing contest work with this plane, so I'm reluctant to go through the hassle.
KKKKFL
Old Oct 03, 2012, 09:41 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
The difference between those two receivers is that the AR6210 will give you flight log data (fades/frames/holds) and the other won't.
Otherwise they're the same. Except for DSMX of course.
Andy
Site Sponsor
Old Oct 03, 2012, 11:23 AM
Piper J3 is online now
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
DX8 makes a noise once in a while...
Maybe it’s me, but on several occasions my DX8 has made a sound like a “Glunk”. I think it is the vibration motor making a very short pulse. I fly with telemetry warnings, but this doesn’t seem to be related to any events I’m monitoring. Seems like it happens when landing my 3 meter sailplane and I’m a couple hundred feet above the ground. I don’t have altitude warnings enabled. Any thoughts?
Piper J3 is online now Find More Posts by Piper J3
Old Oct 03, 2012, 11:54 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Only a quick vibe? No tone with it? Which one of your telemetry alarms fits that profile? Vibe only.
aerocal is offline Find More Posts by aerocal
Old Oct 03, 2012, 12:53 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Crap! I don't believe it! The right stick on my Dx8 has lost tension on the elevator and it won't return to center... removed the back cover and notice a small pin tumbling out.
BTW, without giving away people's info, I got unsolicited PMs from others who also had same problem, so the fact it hasn't perhaps been mentioned here a lot does not mean it is not happening in the field a lot. My intuition (and that's all it is!) is that this ranks pretty high on the list of things that go wrong with the DX8 -- if for no other reason than it's otherwise such a good and a reliable radio! Despite my own few (but relatively vocal) complaints, I really do love mine, and I often let new club members know that this is a terrific radio to use for our type of flying (park sized electrics at a local country park)
Thanks also to Spektrum for rushing out latest version of SW -- I had no problem with 2.05, but clearly a lot of people were confused, so the help automating the trim changeover process was obviously a very good idea.
tracknoob is offline Find More Posts by tracknoob
Old Oct 03, 2012, 12:55 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by Piper J3 View Post
Maybe itís me, but on several occasions my DX8 has made a sound like a ďGlunkĒ. I think it is the vibration motor making a very short pulse. I fly with telemetry warnings, but this doesnít seem to be related to any events Iím monitoring. Seems like it happens when landing my 3 meter sailplane and Iím a couple hundred feet above the ground. I donít have altitude warnings enabled. Any thoughts?
If you are using throttle position to enable/disable timer, that could be it. I actually use that tone as an indicator of exactly where my throttle is set when I am on approach, sometimes toggling up and down several times right around that setting (i.e. 17%).
Old Oct 03, 2012, 01:00 PM
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
No, I'm not touching the throttle (throttle at zero), and Aerocal, I don't have any of the warnings set for vib only. If it was a telemetry warning wouldn't I have to "clear" it? A real mystery... I have to pay better attention next time it happens. I enjoy flying with this radio a lot.
Old Oct 03, 2012, 01:06 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
No. If the condition goes away on its own, so does the alarm.
Andy
Site Sponsor
Old Oct 03, 2012, 01:07 PM
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Andy
Andy - you're back from lunch....
Old Oct 03, 2012, 02:01 PM
CiprianGugu is offline
Find More Posts by CiprianGugu
Look Up
CiprianGugu's Avatar
United States, TN, Jamestown
Joined Nov 2003
It might be related to the timer. At the 1 min mark you get some kind of short vibration, if I remember correctly.
CiprianGugu is offline Find More Posts by CiprianGugu
Old Oct 03, 2012, 02:13 PM
aerocal is offline
Central California
Joined Dec 2006
Yes.If you have the timer alert set for it.
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
