Old Sep 17, 2012, 06:15 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
WOW this thread is HUGE!
Question if I have 31+ models, can I have all 30 internal memory slots full and can I access my other 1+ from the SD card? Or do I need at least 1 internal spot open and need to transfer the model from the SD card to internal memory?
BTW I did a search on SD card and models and came up with hundreds of posts, read though about 2 dozen before I decided to try and just ask.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Sep 17, 2012, 06:29 PM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
If you Save your Model Memories to your SD card, you can Reset an existing Model Memory, set it up for a new aircraft, Save it to your SD card, and then Swap it back in when necessary. These may not be the correct terms, but you get the meaning.
Buschbarber is offline Find More Posts by Buschbarber
Old Sep 17, 2012, 06:37 PM
bjaffee is online now
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
In other words, you cannot actually "run" a model off the sd card.
bjaffee is online now Find More Posts by bjaffee
Old Sep 17, 2012, 06:39 PM
freechip is online now
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
No, SD card is backup, Airware Updates & Telemetry logging.
freechip is online now Find More Posts by freechip
Old Sep 17, 2012, 07:10 PM
Luck is my skill
Joined Jun 2009
Thanks for all the quick replies.
Yeah my beloved DX7 is full now =( Time for a DX8.
There was a time when I thought 20 Models was a lot ... now even 30 models doen't seem like much.
I'm also assuming that any model copied from SD card would not have it's bind saved? Oh well it's not too much trouble to pull from memory into a saved open internal slot.
Old Sep 17, 2012, 07:18 PM
freechip's Avatar
Joined Aug 2008
You are correct, once you IMPORT a model to any memory position you like a BIND would be required.
Basicaly model memory or the amount of models is sort of a second priority now with the ability to export and import to & from SD card.
It's now a matter of how many models the radio can hold BEFORE you have to rebind models from SD card.
Old Sep 17, 2012, 08:23 PM
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
I wonder if this would be true if you imported it to the same position it was at before? Reason I ask that is that when I was setting up my radio, I had programmed and bound one of my planes, then later accidently copied over that setup with one from another plane. The receiver was still bound to that model though. After I had finished programming the same model again, I did not have to rebind.
Old Sep 17, 2012, 08:40 PM
freechip's Avatar
Joined Aug 2008
That's not the issue, the receiver is.
So if it's still the very same receiver and you import in the very same model position the yes it would work out the way you describe and you would not need to rebinb.
You would need to remember what memory it was.
Old Sep 17, 2012, 08:41 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
On the DX7s and DX8, the bind would still be valid. On the current version of the DX10t and DX18 it would be lost, unless the model uses a low-speed DSM2 receiver (AR6100, etc.).
You are always best to re-bind after importing a model.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Sep 17, 2012, 09:40 PM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
Thanks guys,
My problem came cuz the defaults were all take up, just needed to do an Inh on the aux channel to get geart to allow assignment.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Sep 17, 2012, 10:10 PM
freechip's Avatar
Joined Aug 2008
Originally Posted by AndyKunz View Post
... You are always best to re-bind after importing a model. Andy
People don't always do what's best for them Andy, some fly into trees.
Old Sep 17, 2012, 10:15 PM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
Don't feel bad Andy, I had a light pole jump out at me before.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Sep 18, 2012, 06:36 AM
Joined Jan 2011
For any of you R/C'ers that use X-plane ( http://www.x-plane.org/ ) as a simulator, I just posted a rendition of my 1/4 Scale EAA biplane. If you stand at the end of the runway and fly with that view, it acts like the model. What I posted is the Full size aircraft, not the dimensions of the 1/4 scale since most of the XP users fly full size.
KKKKFL
Old Sep 18, 2012, 09:23 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
I lost two planes to the SAME high-jump pole last winter, on the same night, making landing approaches! One was a Polecat so I guess it could be expected. And the P in P-51 stands for Pole, not Pursuit.
Andy
Site Sponsor
Old Sep 18, 2012, 10:51 AM
Mukenukem is online now
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Any obstacle nearby will be hit. That's a law
When flying in the gym, we also only hit the basketball baskets or the rings on the ceiling.
It's called obstacle-gravity. The smaller the obstacle, the larger the gravity. Like black holes.....
Mukenukem is online now Find More Posts by Mukenukem
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 05:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 06:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 01:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 08:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 11:43 PM
