Old Sep 07, 2012, 08:41 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by michil View Post
Hello,
I installed V2.05 on my DX8. I'm using an electric heli an programmed the throttle channel to a switch (using gov mode of ESC). I set the log trigger to Throttle and set the value to 10%. When I start the motor, the logging is not started. When moving g the pitch stick a little bit upward the logging seems to start (I can hear a click from the beeper).
So it seems that log trigger is not really on throttle channel, it seems it is fixed to pitch stick (which is normally connected to throttle for nitro heli).
Is this a bug or a feature?
Kind regards
Michael
Use Throttle Out instead.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Sep 07, 2012, 10:36 AM
michil is offline
Find More Posts by michil
Joined Apr 2008
Andy
Thanks. Is there a description of the log feature available?
Michael
michil is offline Find More Posts by michil
Old Sep 07, 2012, 01:29 PM
AeroKen is online now
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
On the subject of fades, frames, and holds...
With a single antenna reciever (like the AR600 despite it's two wires, apparently), I would expect fades on A to be the same number as F (frames). And almost all the time it is, but once I noticed the two numbers were 1 off - can't remember which way now.
Why might A and F be different on an AR600?
AeroKen is online now Find More Posts by AeroKen
Old Sep 07, 2012, 01:36 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Fades and Frames ARE NOT THE SAME THING.
freechip is offline Find More Posts by freechip
Old Sep 07, 2012, 03:28 PM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
@aeroken
I'll try and word your question differently... An ANTENNA FADE represents loss of a bit of information on an antenna, while a FRAME LOSS represents a simultaneous antenna fade on all attached receivers. How can there be FRAME LOSSES of a different number than ANTENNA FADES if there is only ONE receiver?
Is this what you were trying to ask?
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Sep 07, 2012, 03:52 PM
LizardMan is offline
Find More Posts by LizardMan
Joined Sep 2010
Consider the AR6255 (designed for carbon fuse models)
One receiver circuit, two antennas and no sat/remotes.
This RX rapidly switches between two extended lead antennas. I think it alternates between sampling Ant1 and Ant2 on a frame by frame basis, using each antenna 22.5 times per second.
Telemetry data contains only one antenna fade counter, yet there are actually two antennas.
This RX typically has fairly high fade counts (1000+), because one antenna is frequently shielded from the TX by carbon fiber fuse or wings, used in DSMX mode, and long flights in sailplanes flying higher and further down range than helis and typical planes. 2000 ft up and 3/4 of a mile away for over an hour is common place. I've seen the fade counter exceed 5000 without any holds.
LizardMan is offline Find More Posts by LizardMan
Old Sep 07, 2012, 04:20 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Throtle tension
I have adjusted the tension on my throttle and its not enough. Can I flip the metal bracket over for more tension?
stgdz is offline Find More Posts by stgdz
Old Sep 07, 2012, 04:27 PM
United States, MA
Joined Jul 2012
Originally Posted by Mugen4Lfe View Post
@aeroken
Bingo - that's it exactly.
Old Sep 09, 2012, 04:05 AM
bjaffee is online now
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Just got a DX8, updated it to Airware 2.05, and found what I assume is a bug. On one of my planes I have the rudder servo direction set to reverse. I needed to adjust the travel a different amount on either side of neutral, so I went into the servo adjust menu, selected the appropriate channel, selected the travel option, and held the stick over to the side I wanted to adjust (the right side), high lighting the number on the right side of the screen. The thing is, nothing was happening with the control throw. However...I moved the stick to the left, and saw that the control throw had changed on the left side.
So it appeared that if the servo was reversed, changing the travel amount on the right side number actually changes the travel for moving the surface to the left, and vice versa.
Has anyone else seen this?
bjaffee is online now Find More Posts by bjaffee
Old Sep 09, 2012, 04:16 AM
netdudeuk is offline
Find More Posts by netdudeuk
England
Joined Nov 2005
Yes, exactly that situation.
netdudeuk is offline Find More Posts by netdudeuk
Old Sep 09, 2012, 08:13 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Yes, it's a current reversing travel issue. The work around is move the stick in the other direction then go back and check.
Or go back to previous version.
Next update will fix this.
Old Sep 09, 2012, 11:18 AM
DXStickman is offline
Find More Posts by DXStickman
AMA 42272, from the 1970's
DXStickman's Avatar
United States, AZ, Kingman
Joined Oct 2007
How is that accomplished? The same file name, spmtx.sax, is used for all updates. Will reinstalling an older version erase the newest update?
DXStickman is offline Find More Posts by DXStickman
Old Sep 09, 2012, 12:01 PM
England
Joined Nov 2005
Yes. The filename will always the same because the software in the DX8 will always look for that file in order to determine if there's an update to install.
Old Sep 09, 2012, 01:29 PM
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Ah, okay, I wasn't sure what the nature of the "reversing travel" issue was at this point (I figured it completely reversed the servo on a model). I can live with it for the moment.
Old Sep 11, 2012, 03:20 PM
nippaero is offline
Find More Posts by nippaero
nippaero's Avatar
United States, ID, Nampa
Joined Oct 2009
Can the Trainer/Bind button or Mix/Hold switch be used for a channel on a DX8?
nippaero is offline Find More Posts by nippaero
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
