Old Sep 02, 2012, 12:28 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by keithy4129 View Post
easier to adjust them independently, subtrim, travel, etc. I dont use Y- harness's in anything I fly, just my preference.
The video shows one rudder servo being put on the aux channel and the Y-harness removed, so I'm at a loss to understand what you're not getting in terms of the functinality you want.
Gerry__ is offline Find More Posts by Gerry__
Old Sep 02, 2012, 12:34 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
And using them as air brakes also works with some down elevator to counteract climb
freechip is offline Find More Posts by freechip
Old Sep 02, 2012, 12:36 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Originally Posted by Gerry__ View Post
But that would make the DX8 a DX9, wouldn't it?
lol, no, on a parkzone stryker you are using the throttle, aileron, elevator and rudder channels. thats only four channels, however, when you select dual rudder on the wing type, it puts it on aux-2 or aux-3 (channel 7 or 8, I don't remember) it would work fine when using a 8 channel receiver, but that is over kill and wont fit in the plane, spektrum should give you the ability to assign the second rudder to either gear or aux-1 so you can use it with a 6 channel receiver, so if you have two rudders, aileron, elevator and throttle, that is a total of 5 channels, why do I gotta put a 8 channel receiver in there for it to work independently with out a mix ( i don't really care about the air brakes, I just want everything in its own channel.) may seem confusing but its not too bad.
keithy4129 is offline Find More Posts by keithy4129
Old Sep 02, 2012, 12:37 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Can the servo slower function be used to slow deployment, do you know?
Old Sep 02, 2012, 12:39 PM
Joined Aug 2010
that requires using mixing, this doesnt allow you to use subtrim, travel adjust, etc. independently.
Old Sep 02, 2012, 12:40 PM
Joined Aug 2010
yes, air brakes work good too, horizons specs were spot on for me
Old Sep 02, 2012, 12:43 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
That makes sense, logically, you should be able to use a 6 channel receiver.
idletime is offline Find More Posts by idletime
Old Sep 02, 2012, 12:45 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
For that you need to put your hand deeper in your pocket and get an Rx with more channels. Not that the Stryker really needs independent travel and subtrim on the rudder anyway.
Enjoy your popcorn.
Old Sep 02, 2012, 12:48 PM
Joined Aug 2010
Enjoy your popcorn.
lol, my goodness, your missing my point, i have a 8 channel rx, but i dont think it will fit without some modifying, if im not mistaking, other brands will let you assign channels the way you want them. the stryker is just an example, Im sure there are better examples out there. more popcorn for me then
Old Sep 02, 2012, 12:51 PM
Joined Aug 2010
thanks, at least someone understands, its not a big deal, just a conveniance thing, its just programming, thats all, other brands let you do it, why doesnt the best 8 channel radio in the whole wide world let you do it? lol Ill share my popcorn with you,
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Just add a miss if you want independent subtrim and travel adjustment.
It seems to me that everything is pretty much catered for.
Old Sep 02, 2012, 12:52 PM
Joined Aug 2010
thats a good idea, i never messed with it, ill check it out one day.
Old Sep 02, 2012, 12:53 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Which you've done yourself by adding a mix. What are you losing out on?
Old Sep 02, 2012, 12:55 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Yeah, slow deployment and fast retraction would be good.
Old Sep 02, 2012, 12:59 PM
Joined Aug 2010
perhaps im ignorant on the situation, but i didnt know you can set subtrim, travel adjust, servo reverse on a mix, isnt a mix just a copy of another channel with some modifications you can do to it? other brands let you put channels where you want them, the dx8 should as well. on a positive note, i have had this radio for like 1.5 years or so, and it continues to get better, thanks Andy!
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
