Old Sep 30, 2010, 07:18 PM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Version 1.02 on mine and it does the same???? Is this something that HH/SPK are aware of??? Seams that what ever the slave is then the stick for that channel does nothing when mix is active.
Spektrum DX8 mixing issue with fw v.1.02 (2 min 32 sec)
freechip is offline Find More Posts by freechip
Old Sep 30, 2010, 07:23 PM
freechip is offline
freechip's Avatar
Joined Aug 2008
Then the other thing is that the DX8 is supposed to have 8 MIXES, 2 pre determine and 6 user but depending on wing type EXEMPLE basic you only get 1 pre determine and 6 user for total of 7, where's the 8th?
I guess you lose a mix if you're not using flaps... the missing mix is ELEV to FLAP mix.
Old Sep 30, 2010, 07:48 PM
freechip is offline
freechip's Avatar
Joined Aug 2008
Anyway to revert back to older version. The older version bugs did not affect me. But now the latest version does.
Old Sep 30, 2010, 08:50 PM
Svensson is online now
Find More Posts by Svensson
Medium Rare
Svensson's Avatar
Sweden
Joined Jun 2010
I'm trying to mix 2 flaps together and it has just been a pain in the as, the dx6i took 2min to do it on, on the dx8 i don't understand a thing. I'm using the AR6255 and it has a GEAR and a AX1 channel and the mixing in the radio is making me angry. Thought it would be a easy radio to program but no. If i cant mix the servos together i will send the radio back....
Svensson is online now Find More Posts by Svensson
Old Sep 30, 2010, 09:09 PM
sabbysynco is offline
Find More Posts by sabbysynco
Joined Apr 2010
luks like Zs review iz right & i'll stay away frm dx8 4 a while. n hoenst review is gud ck http://z8rc.blogspot.com/
sabbysynco is offline Find More Posts by sabbysynco
Old Sep 30, 2010, 10:17 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
What are you trying to do with them?
On the DX8, select a wing type with 2 flaps (Flaperon, 1 Ail 2 Flaps, 2 Ail 2 Flaps).
Go to the Flap System screen to define their basic behavior (controlling switch, positions, and elevator compensation).
Now what do you want the mix(es) to do?
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Sep 30, 2010, 10:23 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
More tedious self promotion?
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Sep 30, 2010, 10:25 PM
Medium Rare
Svensson's Avatar
Sweden
Joined Jun 2010
i have two air brakes on my sailplane and need them to work at the same time and the same way. On the AR6255 you have aux1 and gear to plug them into.
Old Sep 30, 2010, 10:32 PM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
Assuming you want to mix rather than use a built-in wing type:
How about: Master -> slave 100%, 100%, offset of zero?
If they go the opposite way because of the geometry, then -100% -100% ?
I haven't played with a DX6 in a while but I think the only difference is that the DX8 adds an offset parameter but for something like this, just leave it at zero.
Dave H. is offline Find More Posts by Dave H.
Old Sep 30, 2010, 10:33 PM
Medium Rare
Svensson's Avatar
Sweden
Joined Jun 2010
battery died.....will try tomorrow.
Old Sep 30, 2010, 10:34 PM
Dave H. is offline
Joined Feb 2008
Minor UI annoyance: The Back button doesn't work in the file browser.
Old Sep 30, 2010, 10:39 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Hopefully I'm understanding you correctly.
Use a single-flap setup. That will put flaps on Aux1.
Go into the Switch Setup screen and make sure you don't have any switches assigned to the Gear channel.
If you want Gear to have the same function as Flap, mix Flap to Gear at 100/100/On.
Andy
Site Sponsor
Old Sep 30, 2010, 10:56 PM
Medium Rare
Svensson's Avatar
Sweden
Joined Jun 2010
Is it then possible to have the flaps working on the f-mode button?
Old Oct 01, 2010, 02:50 AM
Nader703 is offline
Find More Posts by Nader703
Joined Oct 2010
DX 8 signal problem
I tested the Dx8 on my trex450 Pro i put on it 10 flights with the new TX,
I think the problem is from the DX8 transmitter because I did not use any of the electronics that came with it in the box yet; I just bind the dx8 to my Trex 450pro and programmed it. (I only tested the transmitter)
The electronics on the 450pro are all the same that I have flown over 100 times with no problems using the DX6i and AR6100 receiver. (They are good and tested)
with the DX8 in 3 of the flights the heli did something I did not tell it to do. In the first time (I was doing tik-toks heli lost signal and hovered inverted for a second)
In the second time (heli is up in the air then lost power completely of motor, heli dropped on grass) "fresh battery pack 1min into flight time"
Final time (heli diving down then I give input to pull-up but lost signal and heli smashed into the grown)
I have a video posted on youtube (nader703) testing the dx8 but no problems occurred during that first flight.
Now the heli is broken in pieces
DX8 first test flight on the Trex 450 PRO (5 min 16 sec)
Nader703 is offline Find More Posts by Nader703
Old Oct 01, 2010, 03:48 AM
Telrin is offline
Find More Posts by Telrin
Dallas, TX
Joined Jan 2010
http://www.youtube.com/watch?v=anJTRdXomqo
Glad it is not just me then, but this needs to be fixed.
Not sure where is the best place to report bugs, hopefully they will pick it up from here.
Telrin is offline Find More Posts by Telrin
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 05:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 06:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 01:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 08:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 11:43 PM
