Old May 02, 2012, 11:20 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
just given them a phone call to try to reach someone to send my radio back via EMS.. oh well.. my radio is already on its way back.. hope to get it before the weekend.
they told me they will send me an e-mail with the tracking number tomorrow but I doubt it. :/
so much for answering an e-maill fcs
pavcon is offline Find More Posts by pavcon
Old May 02, 2012, 12:59 PM
pavcon is offline
Joined Jan 2010
update..
I called them and I think I talked to Glenn directly but he never mentioned that.
He emailed me the fed ex tracking number
prob is .. if you track 518613389943 in fedex.com/uk it says it's been returned to shipper because they used my p.o. box address and not my physical address.
bummer I will give them a call tomorrow first thing in the morning and cover a 2 day shipping costs... I can't miss another weekend of flying..
I realised Im an addict..
My HK vampire is ready for maiden with an AR8000. my MB339 is ready for formation flying... comooon now FEDEX..
If I manage to get my radio before friday I'm taking everything back...
and then I will send in my DX6i I need a spare. :O
Old May 02, 2012, 01:06 PM
freechip is online now
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Why I kept my DX6i and why I will keep my DX8 if and or when I get a DX18.
freechip is online now Find More Posts by freechip
Old May 02, 2012, 03:54 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I will second that......Keeping my DX7 and my DX8 when I get my DX18. And still have a couple of models on my Futaba 9CAP and will keep using that one as well.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old May 03, 2012, 01:35 AM
pavcon is offline
Joined Jan 2010
that backlight mod is comming my way too on the dx6i.. but that's after I got it serviced
Old May 03, 2012, 12:00 PM
NwRcFlight is offline
Find More Posts by NwRcFlight
EDF Junkie
Pacific Northwest
Joined Oct 2007
Hello Andy,
I see that the UK is starting to receive the UMX Carbon Cub and several of the new owners are using DX8's. They are setting up their Cubs flaps with slowed flap travel and they also need elevator compensation. The flaps travel at the slowed speed but the elevator snaps to position. Is there a way to get the elevator servo to use the same travel speed as the flaps?
NwRcFlight is offline Find More Posts by NwRcFlight
Old May 03, 2012, 01:04 PM
freechip's Avatar
Joined Aug 2008
If they are using the flap menu and input elevator compensation in that menu the elevator should move per the speed set in the flap menu.
What airware version are they using?
Old May 03, 2012, 02:27 PM
EDF Junkie
Pacific Northwest
Joined Oct 2007
Sorry I don't know what version they are using but based on your answer I would have to assume it's an old one if it should be working. I'll suggest to them to update to 1.04. That's the latest, correct?
Old May 03, 2012, 02:30 PM
EDF Junkie
Pacific Northwest
Joined Oct 2007
I just remembered one more thing. The Carbon Cub has been set from the factory to activate the flaps on the gear channel so they are mixing gear and flaps so they can use the flaps switch for flaps. Maybe that makes the servo speed not work how they want it too.
Old May 03, 2012, 02:34 PM
EDF Junkie
Pacific Northwest
Joined Oct 2007
One other interesting item is that they are getting signal strength telemetry data from the Carbon Cub receiver. That's a Carbon Cub feature that I didn't realize was coming.
Old May 03, 2012, 02:41 PM
freechip's Avatar
Joined Aug 2008
2.04 is the latest version
Old May 03, 2012, 02:47 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
2.04 is current version
JC Spohr is offline Find More Posts by JC Spohr
Old May 03, 2012, 03:59 PM
EDF Junkie
Pacific Northwest
Joined Oct 2007
Carbon Cub Flaps/Elevator problem solved. One guy upgraded from 2.01 to 2.04 and it works they way he wants it too.
Old May 03, 2012, 04:31 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
Joined Jan 2007
Hello Andy,
The out of the box Carbon Cub comes with the flaps plugged into the gear channel. This is for the guys who have DX4e and DX5e to be able to fly the model as well. In order to get the slow flaps and elevator compensation to work at the same speed, the flaps must be plugged into the flap channel (Aux 1) for the flap and elevator compensation to work at the same speed. Basically that requires opening the fuselage, and swapping the ports of the flap servo.
However, there is another solution, but a bit more complex:
Set your wing type for the Carbon Cub to 1 Aileron, 1 Flap, and assign the flap channel to the flap switch in switch select. Also inhibit the gear as well. Now create a mix of FLP > GER, and set the mix to 100% for both sides.
Now you can go into the flap system and use the elevator compensation numbers as well as the normal numbers for setting the flaps. Essentially, you're inhibiting the gear switch from moving the flaps, then mixing it to the flap channel (which does nothing on the model since the ailerons are programmed to be y-harnessed).
Hope this helps!
Seth Arnold
Horizon Hobby
3D-Seth is offline Find More Posts by 3D-Seth
Old May 03, 2012, 04:36 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by 3D-Seth View Post
The out of the box Carbon Cub comes with the flaps plugged into the gear channel. In order to get the slow flaps and elevator compensation to work at the same speed, the flaps must be plugged into the flap channel (Aux 1) for the flap and elevator compensation to work at the same speed. Basically that requires opening the fuselage, and swapping the ports of the flap servo.
Hope this helps!
Seth
Perhaps an opportunity to post the seldom thought of SPM file?
flitelab is offline Find More Posts by flitelab
Site Sponsor
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 05:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 06:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 01:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 08:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 11:43 PM
