Old May 01, 2012, 10:11 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
I learn something new every day, My boss can hardly wait for tomorrow.
Thanks Sir.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old May 01, 2012, 10:13 AM
struggleforlife is online now
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
Originally Posted by pavcon View Post
just add two life batts :/
...one cannot simply plug in a spare battery in the Rx, can you?! I heard someone mention something about a extra thingy that is required for this.... (when using a Bec of ESC bec).
Can you elaborate?
struggleforlife is online now Find More Posts by struggleforlife
Old May 01, 2012, 10:45 AM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
Can you elaborate?
Spectrum PowerSafe Rx's have two Rx battery leads. Most receivers allow you to connect the Rx battery to any Servo port, as well as the Batt port. It is not uncommon for pilots to connect Redundant Rx batteries that way.
Buschbarber is offline Find More Posts by Buschbarber
Old May 01, 2012, 11:06 AM
Telrin is offline
Find More Posts by Telrin
Dallas, TX
Joined Jan 2010
All that is great as long as you are only using batteries as your power source, what struggleforlife is asking about is mixing a battery with a BEC and that is when you have to take more care as not all are happy with another voltage source in the mix.
Telrin is offline Find More Posts by Telrin
Old May 01, 2012, 12:42 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
That's a no no - ALL power inputs must have same voltages
FWIW eliminate any devices not absolutely necessary
for example - you may see a reg and a batt as a great way to go - however if you can utilize a battery which does the job without a reg in the circuit - you are one step closer to eliminating another potential failure point.
a few years back the LiIon and a reg and possibly a fan to cool the reg ,was a Kool setup-
with the advent of 2.4 and really power hogging servos - it's just a disaster waiting to happen
regulators -if you must have em - should be switching types which don't heat as did the linear types .
I was given a big ol power supply with heat sinks etc.. I was using it to supply a charger for some 5000 ma 5 cell packs . the thing shut down and was hot enough to fry eggs -even tho the charger was "only"doing 5 amps output and the power supply was rated at 10 continuous amps -at 13 volts.
The power supply is now doing duty for the little packs --
(the charger was suppling 5 amps at 20 volts which is 100 watts- my 15 amp switching type supply does the same job without a whimper.
richard hanson is online now Find More Posts by richard hanson
Old May 01, 2012, 02:10 PM
Telrin is offline
Dallas, TX
Joined Jan 2010
Good as a general rule, but for example, Kontronik recommend the use of a buffer pack with the BEC in their Jive ESC in some circumstances.
The buffer pack will not be at the same voltage as the BEC, but over time it will tend to move towards it.
Only use a buffer pack if the manufacturer of the BEC approves of that configuration though.
Old May 01, 2012, 02:24 PM
Joined Feb 2011
wow... the plot thickens....!
Yes. No. Maybe. Only if. etc.
I am not a engineer (obviously), so I am not able to make heads or tails of this.
I have a AR8000, a plush 80, seperate turnigy 5-7.5A sbec and a 4s 4000mah.
Can it be done?
Old May 01, 2012, 02:25 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
yeap
pavcon is offline Find More Posts by pavcon
Old May 01, 2012, 03:50 PM
Joined Oct 2007
Can it be done?
The thing to watch for is the servo LOAD and motor voltage vs internal BEC voltage
The motor voltage vs the ESC output voltage is well within limits and that Turnigy should say " switching type ESC "
I run a 5 cell Lipo using ESC with internal BEC on my old Kadet Senior -servo load is hardly worth mentioning
I also have 80 amp ESC (running 38 volts) and tho the ESC/bec is rated for the use with servos I have - I will stick with a seperate power supply to the radio (A123 direct). much more durable setup.
ANY ESC worth using today ,which is over 30 amps, /3 cell-will have a switching BEC
Old May 02, 2012, 09:25 AM
Joined Jan 2011
LiPo question WRT the DX8 transmitter. I finally received my LiPo pack, (removed the rubber floor so it fits nice now) and put it on a 30 minute charge. Removing the charge cord and powering up I noticed it read 7.6 volts. Next day I put it on charge when I got home, and an hour later the Lights on the Dx8 were still on. Are they supposed to go out once full charge is reached? Checking the voltage on power up, it started at 7.8v and bounced to 7.9v which I am guessing is normal. I just would like to see the lights go out on full charge.
What's everybody else see?
KKKKFL
Old May 02, 2012, 09:28 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The blue light stays on until the battery is fully charged. It takes a LONG time usually.
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old May 02, 2012, 09:31 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ Franco2fly
When charging the optional SPMB4000LPTX, a full charge can take up to 30hrs depending on the initial charge state of the battery. When charging a LiPo, the blue light will turn off when the charge cycle is complete
freechip is offline Find More Posts by freechip
Old May 02, 2012, 09:32 AM
Joined Apr 2004
KKKKFL
I charged my DX8 LiPo pack, the first time, just after I received it. I just charged it again, after using it for a couple of months. The Blue Light came on, on the front of the Tx, and went out when the charge was complete. It read 8.5v.
Old May 02, 2012, 10:13 AM
pavcon is offline
Joined Jan 2010
ok I didn't want to post this.. but I am going to.. HH UK SUCK... they never answer emails unless Andy calls them.. they really suck.. Ive got my radio there asking them to send it via EMS but what the heck.. they won' t answer.. they weren't even answering when I wanted to send the radio in and Andy had to call them to get a reply on an email. I don't trust HH uk any more. I just hope to get my radio back and hope that I will never need them again
Old May 02, 2012, 10:17 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Seems to be a more common comment these days.
Here in the U.S., there are now scads of trustworthy, cheap sellers, so "we" do owe them, that!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
