Old May 01, 2012, 07:21 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Originally Posted by pavcon View Post
I got those capacitors but never used one till now..
If anyone can demonstrate that a little capacitor -such as the one shown- can help prevent a low corrent/voltage condition to the rx, please step forward.
If is question about this, contact HH services and ask them if these can help cure a low voltage condition.
richard hanson is online now Find More Posts by richard hanson
Old May 01, 2012, 07:27 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Oh, sorry, I thought he meant the flux capacitor!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old May 01, 2012, 07:57 AM
Joined Oct 2007
Set a course for wishful thinking land--full warp speed -
Old May 01, 2012, 08:02 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I was able to kind of simulate what they do... I added the capacitor on my servo tester (it has 3 servo outputs)
I had battery on the input and one servo + the capacitor on the out put and set the movement to auto so that the tester would automatically move the servo back and forth.
without the cap when you unplug the battery the servo stops.. normally...
however with the cap when you unplug the battery the servo continue moving for a couple of degrees more. ..
the capacitor also being a battery will be able to normalise the voltage..
for the computer guys... it acts like a UPS on the computer.
pavcon is offline Find More Posts by pavcon
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by gjr. View Post
What are the shortcomings ,missing features, and any notable differences that apply to the dx10t versus the dx18? Thanks.
The DX10t does not include the sequencer, nor a few other "secret" features that won't be announced until the DX18 ships.
In the current version the DX10t does not give access to Aux6 and Aux7 on a 12-channel receiver.
The DX18 does not include Auto-Trim, plus anything else related to the mechanical features (i.e., number of switches and pots).
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old May 01, 2012, 08:23 AM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
It would be nice if there was something like a 100 mah battery for this purpose, which you could just plug in the receiver...
struggleforlife is offline Find More Posts by struggleforlife
Old May 01, 2012, 08:54 AM
Joined Oct 2007
There is simply no substiute for a proper , low impedance battery supply - - No quick fixes such as an additional small battery or a capacitor -even a BIG one .
Buy borrow or steal a good voltmeter which reads in tenths of volts and stick it in the rx - then try various batteries/ caps/ whatever and with servos providing a realistic load for YOUR application - run the system and watch the voltage depressions.
Batteries with high impedance or regs with poor power handling will cause problems.
Caps are not a fix.
Old May 01, 2012, 09:23 AM
pavcon is offline
Joined Jan 2010
just add two life batts :/
Old May 01, 2012, 09:25 AM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Could you explain that a little please?
thanks
Ron
A Rdnek is offline Find More Posts by A Rdnek
Old May 01, 2012, 09:26 AM
Greenland
Joined Mar 2012
Or, use a wattmeter and carefully design your power system!
Old May 01, 2012, 09:29 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
How do LiFe batteries compare to NiCad(Sanyo) and NiMh(Eneloop) batteries? Say I have 3 airborne rx packs with AA size cells (4 soldered together) and lets make them all 1800Mah in capacity. What would you expect from each type battery pack?
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old May 01, 2012, 09:40 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by JohnathanSwift View Post
Go to youtube and search for the HH video on this! The "floor" of the compartment is a solid piece of foam, which should also be removed when using the lipo, though it exposes an opening to the circuit board! The video shows use of an exacto knife to lift it, but I used something like a small, slotted screwdriver.
I realized the floor foam probably ought to come out for the Lipo, but then, I felt it's 'give' and just played around with smooshing it a bit to see how much give it would take to close the door, and if it would be too tight.
After a few minutes of pressure, and playing with the door, it all fit nicely (though snugly!) with no bulging or excessive pressure, and I figured that since I will be charging on-board, the Lipo will be in there for a good long time, that would be a good set up for me, nice and firm, no movement possible.
tracknoob is offline Find More Posts by tracknoob
Old May 01, 2012, 09:42 AM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
KKKKFL
LiFe are 3.3v per cell. The maintain a flat 3.3v per cell throughout the discharge. The hold their charge for months just like LiPos. They make excellent Tx and Rx batteries. They are the same as A123 cells. They charge quickly so you are never inconvenienced.
Buschbarber is offline Find More Posts by Buschbarber
Old May 01, 2012, 09:51 AM
Joined Jan 2011
Sounds like an Airborne pack would require 2 batteries soldered together 6.6 (my NiCad's usually measure 5.2 off the wall wart charger overnight) Are LiFe expensive by comparison to the typical AA NiCad cell that I can purchase at the Best buy (I see 2000Mah Batteries all the time)
KKKKFL
Old May 01, 2012, 10:05 AM
Joined Apr 2004
KKKKFL
They come in presolderd packs. Not many people solder their own. They most often have Balancing Taps with leads to each cell. Balancing Lithium chargers like the FMA 4S and 10S balance the charge to each cell and read out the individual cell voltages. Hobbico sells the green and white LiFe brand. Thery are available at your LHS. These are flat packs. I have used those as well as EPbuddy packs which are smaller and round.
I use 2500mah packs that cost me $25 for a 2cell pack
After using NiCad and NiMh for years, charging for hours, dealing with False Peaks (NiMh) and self discharging over time (except for Eneloop), I much prefer the convenience of Lithium batteries.
My DX8 had the option for a 4000mah Tx battery, which I have been using. The newer JR DMSS XG series transmitters come with LiFe batteries as well as some of the newer Futaba transmitters.
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
