Old Apr 30, 2012, 09:34 PM
ClosedAccount is offline
Find More Posts by ClosedAccount
Closed Account
Joined Sep 2011
Originally Posted by AndyKunz View Post
A really bad card, I suppose. I wish you could have sent it to me, I'd love to see exactly what happened so I can prevent it from recurring.
Andy
I might still have the one that was doing it to me. I can send it to you if I find it.
ClosedAccount is offline Find More Posts by ClosedAccount
Old Apr 30, 2012, 09:36 PM
DXStickman is offline
Find More Posts by DXStickman
AMA 42272, from the 1970's
DXStickman's Avatar
United States, AZ, Kingman
Joined Oct 2007
Andy
PM sent.......
DXStickman is offline Find More Posts by DXStickman
Old Apr 30, 2012, 09:53 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Originally Posted by A Rdnek View Post
Flux capacitor?
Chronosynclastic infindibulum.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Apr 30, 2012, 11:52 PM
gjr. is offline
Find More Posts by gjr.
Glen
Nashville,TN
Joined Jan 2005
What are the shortcomings ,missing features, and any notable differences that apply to the dx10t versus the dx18? Thanks.
gjr. is offline Find More Posts by gjr.
Old May 01, 2012, 05:28 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
Battery question..................
Hooray, I finally received the Dx8 Lipo battery (not thrilled with the poor fit) so now I can return to my Plug-er-in-night before and not worry about cooking the NiMh pack. So, now I have this 4.8v Enloop pack that wasn't cheap, and the question becomes will it work as a flight pack for one of my Nitro planes?
How will this pack compare to the NiCads that I have been using? I suppose I can do some bench testing and see what the volt meter tells me, but I would sure like to here from an EE with a minor in Battery.
Thanks.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old May 01, 2012, 05:41 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Franco2fly View Post
...I finally received the Dx8 Lipo battery (not thrilled with the poor fit) ... Thanks. KKKKFL
Did you remove the bottom pad?
Did you replace the U shape NiMh side pad with the L shape Lipo pad?
freechip is offline Find More Posts by freechip
Old May 01, 2012, 05:45 AM
Telrin is offline
Find More Posts by Telrin
Dallas, TX
Joined Jan 2010
I mention this only because you wouldn't be the first person to miss it, but you do have to remove the foam at the back of the battery compartment, not just the 'U' shaped piece around the NiMH pack and then use the smaller 'L' shaped piece that shipped in the box with your radio.
Once you do that it is quite a neat and solid fit in the compartment.
...so now I can return to my Plug-er-in-night before and not worry about cooking the NiMh pack.
Perfectly safe to do that now from an 'overcharging' perspective, but do get in the habit of only doing it when the battery is getting low as the best way to ruin your new Lipo is to keep it fully charged all the time.
It depends a lot of what you need to power in the plane as while Eneloop cells are great for holding a charge long term in low current discharge devices, I would not use them as an rx pack if your servos are capable of a significant current demand.
I don't particularly like AA sized cells in general as an rx pack for anything other than a very light load and if they have to be AA then I'd prefer a 5 cell pack with Spektrum to stay well clear of the brownout voltage level.
Personally I'd use the pack on the bench for set-up duty as the long term charge holding is great for that sort of use.
Telrin is offline Find More Posts by Telrin
Old May 01, 2012, 06:24 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Thanks.
KKKKFL
Though the DX8 with AR8000 proved to be much more tollerant to low voltage drop (had mine dropped at 3.7v) I wouldn't take the risk.
pavcon is offline Find More Posts by pavcon
Old May 01, 2012, 06:32 AM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
Speaking of which, does any of you have any experience with:
http://www.hobbyking.com/hobbyking/s...dProduct=16223
Dave
struggleforlife is offline Find More Posts by struggleforlife
Old May 01, 2012, 06:35 AM
Closed Account
Joined Sep 2011
Dave
I would think it would work fine. It's just a capacitor, but it should help prevent short bursts of low voltage.
Old May 01, 2012, 06:56 AM
Joined Jan 2011
L shaped foam
Thanks for those thoughtful tips. I'll have to look in the DX8 box to see if the Lipo inserts are still there. I didn't see any additional foam on the battery, but I'll have to take a closer look. Since I could not get the door to close with the U shaped NiMh battery foam, I just left it out.
What Transmitter voltage should I see with a fully charged pack? I just dropped the pack in and it was reading 7.4volts. I didn't really charge it last nite, just changed the Systems settings to LiPo from NiMh.
KKKKFL
Old May 01, 2012, 07:04 AM
Greenland
Joined Mar 2012
KKKKFL
Go to youtube and search for the HH video on this! The "floor" of the compartment is a solid piece of foam, which should also be removed when using the lipo, though it exposes an opening to the circuit board! The video shows use of an exacto knife to lift it, but I used something like a small, slotted screwdriver.
Old May 01, 2012, 07:13 AM
pavcon is offline
Joined Jan 2010
I got those capacitors but never used one till now..
Old May 01, 2012, 07:17 AM
Joined Feb 2011
: ) I just put one in a few days ago. Thought maybe one of you had some hands one (testing) experience as to how effective this thingy is.
Greenland
Joined Mar 2012
Uh, where'd you wind up?
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
