Old Apr 25, 2012, 02:11 PM
ClosedAccount is offline
Find More Posts by ClosedAccount
Closed Account
Joined Sep 2011
I wasn't trying to convince you of anything, I was just making conversation. You can believe in whatever you want.
ClosedAccount is offline Find More Posts by ClosedAccount
Old Apr 25, 2012, 02:20 PM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
I just like to be cautious. (and safe)
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Apr 25, 2012, 03:42 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Hey Andy,
Here's something I am pondering...
I see people who add heat shrink tubing to their antennas to hold them straight and in place.
Since heat shrink is an insulation with some dielectric strength, does it have a negative impact on reception?
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Apr 25, 2012, 03:52 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
So far it hasn't affected mine any. What about all the polymers in foam?
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Apr 25, 2012, 04:41 PM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
VP
Tin foil hat?
Sorry I couldnt resist.
aerocal is offline Find More Posts by aerocal
Old Apr 25, 2012, 04:47 PM
aerocal is offline
Central California
Joined Dec 2006
Originally Posted by JC Spohr View Post
Hey Andy,
JC
I have heat shrink on some of mine still.Did a bit of testing with and without.
No difference whatsoever in Flightlog data so Id say its RF transparent.I was always afraid to put enough heat on it to make is stay on well enough and had a few fall off over time.I now mostly prefer Robart air line.
Old Apr 25, 2012, 05:36 PM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
Originally Posted by freechip View Post
What AirWare version are you using? 2.04 is the most current version.
This was implemented in 2.03, you maybe still running on 2.02 or earlier.
I havent a clue.......not looked into any updates for the tx. Kinda forgot that was even a possibility.
Now.....how do i do it?
socommk23 is offline Find More Posts by socommk23
Old Apr 25, 2012, 06:00 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Thank you!
Does the robart line push on and stay on?
JC
Old Apr 25, 2012, 06:08 PM
grumpy42 is offline
Find More Posts by grumpy42
grumpy42's Avatar
Canada
Joined Aug 2004
Originally Posted by AndyKunz View Post
The range is not a huge decrease, even though the power is only half. That's because power is related to the cube of the distance - think of it as the volume of space filled with signal. The range is still way farther than you can see a model.
Andy
Actually, radio signals are attenuated with the square of the distance (i.e. doubling the range requires 4x the power). Think of it as the surface of an expanding sphere (the signal does not "fill" the sphere").
grumpy42 is offline Find More Posts by grumpy42
Old Apr 25, 2012, 06:09 PM
grumpy42 is offline
grumpy42's Avatar
Canada
Joined Aug 2004
The version number is displayed on the third page of the system settings.
Hold down the scroll wheel while turning on the radio and scroll down to "system settings".
Ooops... I just thought the poster wanted to know how to check their current firmware version. What freechip said below.
Old Apr 25, 2012, 06:13 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
go here https://community.spektrumrc.com/ and register your radio. Then download update onto SD card and update radio. Then you will be able to adjust the rx bar graph.
freechip is offline Find More Posts by freechip
MartinT is online now
Find More Posts by MartinT
MartinT's Avatar
Joined Mar 2006
...I see people who add heat shrink tubing to their antennas to hold them straight and in place....
That makes no sense to me, I thought that due to the radiation pattern of the antenna you don't want to be "pointing" it to the receiver, (cause out of the top of the antenna is where the least signal strength is coming from) but with a straight antenna that's just what you are doing... (that is if your body is following the movement of the plane.) (unless like some of the "youthful" guys who seem to have made a silent agreement to hold the TX vertical against the body with the antenna pointing straight down... )
So what's the verdict on that then? (the way I point my antennas is 90 degrees to the side how's that?
MartinT is online now Find More Posts by MartinT
Old Apr 25, 2012, 06:14 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
What ever way works for you as long as you are not pointing directly at the model.
Old Apr 25, 2012, 06:26 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Works for me
My thought was that he was referring to the receiver antenna wires in this case, though I do believe I've heard of some folks using heat shrink tubing to fix a broken knuckle joint on the transmitter.
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Apr 25, 2012, 06:44 PM
MartinT's Avatar
Joined Mar 2006
Originally Posted by pilotpete2 View Post
Works for me
Pete
Hmm, yeah he probably IS talking about the receiver antennae, Since he's referring to reception range... I thought it had something to do with a broken knuckle (like the movable joint) of the antenna as well...my bad...
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
