Hope I get a T shirt with mine
Latest blog entry: For motor builders
Some notes: Initially I tried this at 0% and the timer ran with the throttle hold either on or off. After playing with the % some more, I found that the timer stop/start worked as desired at 4% or above. Below 4% it would just run with the switch in either position. I have the throttle travel at 108% on the low end however (throwback to DX6i/Castle Creations esc setup), so this may have been why it didnt work before at 0%. I'm not sure though. But for those who ran though it like I did the first time...it will work, just try a higher %
As for models requiring adjustment, the answer is no (at least with this update). The changes these updates make affect the user interface more than anything else. You should always verify that your model still "works" on the ground before attempting to fly it - the monitor screen will help you there, but there's no substitute for checking the control surface response during your regular preflight. We do recommend that you always Export All Models before upgrading. This is just common sense, such as making a complete backup before upgrading your PC's version of Windows or Linux. If we ever make an update that would intentionally erase your existing models, for instance, we will make that very plain on the download instructions (the readme file). Andy |
Russellton, PA
Joined Oct 2002
WOW - nice that the updates came out so fast! GREAT SERVICE!
BTW, I've 2 buds visiting me tonight at my house to do their updates to their 8's. SO simple question, do you need to perform the 1.01 first then do 1.02? So each upgrade is independent? Or by doing 1.02 you capture both upgrades at the same time? Sorry - I've not logged into the site yet so I can't see the info via TX registration and serial numbers. Just trying to get a jump on tonights bench work. Thanks for the input. Regards, GMRO |
Orlando, Fl
What about the bug Raydee reported? That is the one that worries me the most.
http://www.rcgroups.com/forums/showp...postcount=1435 |
I dont think its a bug but more a manufacturing defect ON HIS unit as HE COULD NOT reproduce it on other DX8. Something about the vibrations could be shaking something lose on a connection or something.
Himself said it only does it on that UNIT. |
Latest blog entry: Get Help by posting your SPM File
If its one unit your not going to get a report unless the owner of the unit sends or posts a copy of it.
I never got reports when DX6i owner sent their units for service. But when it was the POT recall then we did. IF the vibration issues turns out to be one radio related WE WONT HEAR ABOUT IT. Just setup a blank heli model and set the timer to vibrate and check the servo monitor screen to see what happens. |
| Thread Tools | |
| Question Receivers that work with Spektrum Radios that are not made by Spektrum | BD Flyer | Radios | 29 | Sep 26, 2010 04:09 AM |
| Discussion Spektrum AR6100E or Spektrum AR6100? | LaurenceGough | Off-road Cars | 23 | Aug 06, 2009 05:33 AM |
| For Sale Parkzone 5ch DX10 w/Receiver ch54 | CarlHill | Aircraft - General - Radio Equipment (FS/W) | 7 | Jul 10, 2009 12:07 PM |
| Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? | Bigmaxy | Radios | 1 | Jan 19, 2008 07:57 PM |
| Sold GeForce 8400Gs PCIx DX10 video card | GFBurke | Non R/C Items (FS/W) | 6 | Sep 05, 2007 10:43 PM |
