Old Apr 04, 2012, 03:39 PM
seefest is offline
Find More Posts by seefest
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
Originally Posted by richard hanson View Post
To add a little bit:
The DX8 uses vey little current - so - teh readout is fine for it's purpose IF used as intended
also and this has to do with NIMH-
The present generation, needs to "form" -call it breaking in if you will-
use low current stock setup is fine - and first time around - IF the batt read say 4.8 - check it at about 5 hours -then at the recommended 12.
It will get a bit warm NOT hot!!!!
afer it is down again to say 4.6- recharge for 12 hrs- -it again should be a bit warm
The meter on the tx will likely read a bit higher second time around
Beause the amp demand is low the absolute state of charge vs voltage read is not worth worrying about .
If it were a A123 battery - different ballgame - those are really flat curve types and require a different approach.
If you are a long time user of nimh in old PCM radios - the Dx8 setup will seem strange as those old types needed charging for every flying session.
In this case - the drain (power used) is far lower and the batteries are better and have typically more capacity An old X347 had a 600 ma pack!
That actually makes sense, the forming charge.
The DX8 charger is a 1/10C charger(200 mA), so it really shouldn't be smoking the battery pack even when left overnight starting with a partial charge.
seefest is offline Find More Posts by seefest
Old Apr 04, 2012, 03:49 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
How would you as an admitted OC personality know what rational people like?
As for gas pumps--If you own both diesel and gasoline cars who holds your hand at the filling station?
The hoses will fit in either vehicle
richard hanson is offline Find More Posts by richard hanson
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Originally Posted by seefest View Post
Thats what EVERY rational person wants. Its available with other transmitters.
If a company invented a battery technology that could be "set and forget"(without fear of fire or ruin) on a charger and had the same energy density(and price point) of Lipos, don't you think EVERYONE would jump on the bandwagon? Of course they would.
All except you Gerry. You're content with your 1970's charger and gas pumps that don't shut off by themselves! LOL. Get real.
Actually, my 1970's Kraft sets could be left on their chargers almost indefinately, so that was a bad example.
So, try plugging in your A 9 for a few days and see what happens! Remember, if you burn the fuse, it goes home for a fix!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Apr 04, 2012, 03:50 PM
Greenland
Joined Mar 2012
Yes, indeed, not to mention....
Old Apr 04, 2012, 03:51 PM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Andy,
Got my DX8 back from repair, gimbals are WAY better. I think that was my problem all along. I'm happy with my DX8 now.
akschu is offline Find More Posts by akschu
Old Apr 04, 2012, 03:54 PM
Greenland
Joined Mar 2012
Originally Posted by akschu View Post
Andy,
Yes, but would you use your 24 volt, well-designed server power supply to fill up the....oh, never mind!
Old Apr 04, 2012, 03:57 PM
seefest is offline
seefest's Avatar
Joined Sep 2009
I don't own both, all gasoline for me. Keeps it simple, remember, I'm a simpleton.
And if I remember correctly, a diesel pump nozzle will NOT fit in a gasoline powered truck/car fill tube.
Old Apr 04, 2012, 04:06 PM
seefest is offline
seefest's Avatar
Joined Sep 2009
Now why would I do that? I'm in my shop every day to check things out and tinker anyways. 12-15 hours is plenty of time, with no ill effects and I charge every time I fly. No babysitting necessary.
Remember it's only an 80 mA trickle.
Old Apr 04, 2012, 04:21 PM
jtgmig is offline
Find More Posts by jtgmig
United States, IL, Chicago
Joined Aug 2011
Andy,
Got mine back a couple of months back. It's been perfect ever since.
jtgmig is offline Find More Posts by jtgmig
Old Apr 04, 2012, 04:35 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Mine has been perfect from day one - I love my DX8.
But then again, I read the manual and understand the radios pro's and con's.
No problem with it as is and any future enhancements are just icing on the cake to me.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Apr 04, 2012, 04:53 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Mine was perfect for months as well, then I noticed I have glitch when the vibration alarm goes off plus wonky trims. Great radio but quality control is a bit on the poor side and it seems to have had its share of issues since launch.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Apr 04, 2012, 04:56 PM
magee8578 is online now
Find More Posts by magee8578
United States, CO, Evergreen
Joined Jul 2007
Im back with these annoying DX8 glider questions. I found the following in the DX18 thread. Is it reading too much into this to expect glider software for the DX8 one day?
Originally Posted by 3d Marky View Post
2) Does this now mean the poor man's DX8 will wither away with limited firmware support as the team concentrate on the flagship models?
Actually the contrary. It gives us more tested features to integrate into the lower channel radios.
Andy
magee8578 is online now Find More Posts by magee8578
Old Apr 04, 2012, 05:24 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Who knows? Oh ya someone knows but he can't confirm nor deny. It's not a matter of it being annoying questions, it's just that you bought it knowing what it could or could not do.
This was and is a Airplane and Heli radio, if a glider model type did come along in the future then we would have to endure the complaints about it not having sliders.
Some owners may never be happy with it.
freechip is offline Find More Posts by freechip
Old Apr 04, 2012, 05:42 PM
Joined Oct 2007
No - they will fit
I have both gasoline and diesel cars inc classic cars -
Old Apr 04, 2012, 05:51 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Diesel nozel does not fit in gasoline here in Canada. At least on recent cars.
Question Receivers that work with Spektrum Radios that are not made by Spektrum BD Flyer Radios 29 Sep 26, 2010 04:09 AM
Discussion Spektrum AR6100E or Spektrum AR6100? LaurenceGough Off-road Cars 23 Aug 06, 2009 05:33 AM
For Sale Parkzone 5ch DX10 w/Receiver ch54 CarlHill Aircraft - General - Radio Equipment (FS/W) 7 Jul 10, 2009 12:07 PM
Discussion Can I use a Spektrum Air RX with a Spektrum Surface TX? Bigmaxy Radios 1 Jan 19, 2008 07:57 PM
Sold GeForce 8400Gs PCIx DX10 video card GFBurke Non R/C Items (FS/W) 6 Sep 05, 2007 10:43 PM
