Old Jan 30, 2011, 12:16 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Originally Posted by The Don View Post
That shark is a lot bigger than I thought it was, I got 75 ,80 and 75 on those passes. The spacerunner looks to be in the 55 mph range. Is the lipo under a lot of load on full throttle, it appears to be dropping voltage/rpm when at full throttle which makes it harder to doppler.
Don
Thanks Don! Joe has gotten 96 out of his shark, so the airframe has the ability to go faster. I'm running the motor/ fan/ ESC we discussed by email and 30c 2200 packs that you had recommended for the Evader. You had recommended going with the Wicked rather than the Wicked Plus on this one, do you think it should have been the Wicked Plus after all?
Regarding Spacerunner, it pulls 12.5a and I'm running 20c 910 TP packs, they should be good for the load but who knows. I have some 30c 850 TP packs that I bought to try in it, but when they arrived I was annoyed to find the dimensions are bigger than advertised and they won't fit in the battery compartment
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 30, 2011, 12:28 PM
mihah is online now
Find More Posts by mihah
mihah's Avatar
Slovenia, Kamnik, Komenda
Joined Dec 2002
Here is my AMX on 3S 1000 mAh 25C Turnigy cells and 2610 5000kV EDF on 6 blade.
Nano jet 1 (0 min 9 sec)
Nano jet 2 (0 min 12 sec)
Nano jet 3 (0 min 11 sec)
My guess is around 70 mph.
mihah is online now Find More Posts by mihah
Old Jan 30, 2011, 12:57 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
What was the temperature?
The Don is offline Find More Posts by The Don
Old Jan 30, 2011, 01:23 PM
mihah is online now
mihah's Avatar
Joined Dec 2002
Sorry about that, around 35F.
Old Jan 30, 2011, 01:29 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
My guess will be about 85mph.
Old Jan 30, 2011, 01:31 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
First pass, 87mph, last pass, I got 90 mph.
Don
Old Jan 30, 2011, 01:34 PM
mihah is online now
mihah's Avatar
Joined Dec 2002
Thanks Don! :-)
Old Jan 30, 2011, 02:24 PM
Forney, TX
Joined Mar 2002
Would like a response on this. I could move the shark's setup over to my HL Sabre and put a new setup on the shark... if it's worthwhile.
Old Jan 30, 2011, 03:04 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
What setup is in the other one, I though I was the the 60mm fan and the Wicked4400+ so that has a higher efflux due to the smaller fan size.
Don
Old Jan 30, 2011, 04:21 PM
Forney, TX
Joined Mar 2002
Which other one, do you mean Joe's? I don't know what he's running, I think it's a 60mm. I'd rather stick with 64mm because it's an easy drop-in. I don't have any more room in the nose, so 30c 2200's is as big as I can run. Is this the "hottest" setup given that pack?
Old Jan 30, 2011, 04:27 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The Wicked 4000+ will give more rpm and a little more watts than what you have now as the motor is physically larger. The max power I have is the Wicked 4400+ in the AF64 fan which is like 750-800 watts.
Old Jan 31, 2011, 08:31 AM
T0RN4D0 is offline
Find More Posts by T0RN4D0
Fail Warrior
T0RN4D0's Avatar
Slovenia
Joined Mar 2010
Hello.
Could you doppler this little wing for me please? Last time i tried to doppler something i allmost broke my neck with all the trial programms and file types and everything.
Here are the vids of two (hopefully) good passes.
http://www.youtube.com/watch?v=He-sQmRgPXk
http://www.youtube.com/watch?v=wyd70OKepKg
Temperature was a bit below 0 C... Lets say 30F.
edit: i got a lot of studying to do... But thats boring, thats why i wen't ahead and did some measurements of my own.. Does 48 mph sound about right? I was guessing it was around 50 anyways, so i don't think its much off... But would still like to get a confirmation to see if im doing it right.
T0RN4D0 is offline Find More Posts by T0RN4D0
Old Jan 31, 2011, 03:15 PM
Forney, TX
Joined Mar 2002
Thank you for the info Don! Unfortunately I was flying the shark yesterday evening and had a total loss of all electronics in flight, lost power & servos both (it appears the fan came loose and "flew" forward and unplugged from the ESC). Damage was pretty substantial to the airframe. I'll probably get another, if I do I'll email you about ordering a different setup.
Old Feb 05, 2011, 04:43 PM
stook is offline
Find More Posts by stook
socal
Joined Mar 2009
Don, could you see how fast this baby cat is going. thanks
Baby Fly Cat dons wicked motor (2 min 44 sec)
stook is offline Find More Posts by stook
Old Feb 05, 2011, 06:47 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Originally Posted by stook View Post
I am getting 106-108 mph.
Don
Question could someone doppler this file for me please? pulsar110 Electric Ducted Fan Jet Talk 0 Nov 02, 2009 02:49 AM
Video Can someone Doppler this for me? Bugman Jeff Electric Plane Talk 5 Feb 04, 2008 09:18 PM
Discussion Can somone doppler this for me? CCDR Sabre metroidrc Foamy EDFs 6 Nov 02, 2007 10:28 PM
Video My 650 Watt TwinJet w/ 2X Mega 16/15/3's can someone doppler for me? MailOrderGuy Electric Plane Talk 9 Sep 20, 2007 09:21 AM
Discussion Can someone doppler this for me? Bugman Jeff High Performance 2 May 27, 2007 11:51 PM
