Old Jan 10, 2011, 11:29 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Both sections of the video have about the same top speed, right about 85-86mph.
Don
The Don is offline Find More Posts by The Don
Old Jan 11, 2011, 12:29 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
thanks don so, slower than at 4,000 asl. hmm.....thats about what it did on my first outing to the basin with the electrolyte. these little fans sure are sensitive to weather. either that, or the passes jon put in the video were from further into the flight. thanks again
corsair nut is offline Find More Posts by corsair nut
Old Jan 11, 2011, 06:47 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The other passes were like 80-82 mph but, the two fastest were like 85 mph, and I checked in multiple doppler software as well.
Old Jan 18, 2011, 07:50 AM
Molon labe
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Originally Posted by The Don View Post
The first two passes were the best, they averaged to 67mph (61mph upwind and 73mph downwind).
Don
Originally Posted by habitforming View Post
Thanks! Not quite what I was hoping for but not shabby either. Btw it was about 40 degrees out, not sure what impact that has?
I think I need to get a newer/higher C battery. Maybe that'll get me into the 70's.
Well I got a watt meter recently and come to find out the battery voltage is dropping to 8.9 under load! I guess that explains where those extra MPH's are!
Any particular batteries you like using with the Wicked Jr? I'm really tight on space so it's going to be fun finding a cell that meets the current requirement & yet still fits.
habitforming is online now Find More Posts by habitforming
Old Jan 20, 2011, 11:20 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The lipos Hobbypartz sells have all worked nice for me and they are low cost as well. 8.9 volts is way too low under load! you should be closer to 10.8-11.0 under load. Watt meters can really help diagnose problems and are a great tool to have.
Don
Old Jan 21, 2011, 12:06 AM
Molon labe
USA, KY, Hebron
Joined Dec 2005
Don
I'm definitely a believer in watt meters now.
Are you referring to the Blue Lipo or another one they carry?
Old Jan 21, 2011, 03:56 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I have used the Blue lipo no problem, have not tried the others so not sure.
Old Jan 29, 2011, 02:10 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
ever wonder how fast a 375W 40mm edf would be???? me too....
http://www.rcgroups.com/forums/showt...0#post17249789
new power plant in the electrolyte....
Old Jan 29, 2011, 08:57 PM
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Don, can you please doppler the first 3 passes in this clip:
http://treswright.vervehosting.com/M...001-29-11.m2ts
Unfortunately my wife was filming and the jet is rarely in the clip, LOL! The sound samples should be adequate though. After the first 3 passes the rest is all partial throttle stuff. Passes were all cross-wind, so just let me know what the fastest pass was. This is the Wicked-equipped Flying Shark.
EDIT TO ADD- oops, I just realized you need the temp and I never checked it, argh! I think it was in the 55-60 range, not sure how much of a difference that makes in speed. I asked the wife and she thinks it was around 60.
Edit #2- wow that file is big. It's high def, I'm trying to figure out how to save it down to a smaller file size.
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 29, 2011, 09:30 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I got 119, 119, 118, 114, 112 mph.
Don
Old Jan 29, 2011, 09:36 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
My computer will not play the file, it just freezes every few seconds during playback.
Don
Old Jan 30, 2011, 01:01 AM
Forney, TX
Joined Mar 2002
Don
See if this one works, it's smaller and a different format:
http://treswright.vervehosting.com/M...%201%20720.wmv
First 3 passes are all you need to review, the rest is partial throttle.
And could you also please check this clip, there are two full throttle passes beginning at 26 seconds and at 44 seconds, the rest is all partial throttle flying. This is the "Spacerunner", a small jet running twin EDF40's with 5800 kv Feigaos. It's not real fast or anything, but I'd like to know what it's doing out of curiosity This was taken the same time as the shark clip, so around 60 degrees.
http://treswright.vervehosting.com/M...unner%20MD.wmv
Thanks!
Old Jan 30, 2011, 01:02 AM
Forney, TX
Joined Mar 2002
Don
Congrats to Brent, those are some smokin' numbers for a 40mm jet
Old Jan 30, 2011, 08:56 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That shark is a lot bigger than I thought it was, I got 75 ,80 and 75 on those passes. The spacerunner looks to be in the 55 mph range. Is the lipo under a lot of load on full throttle, it appears to be dropping voltage/rpm when at full throttle which makes it harder to doppler.
Don
Old Jan 30, 2011, 09:18 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
thanks don!!!!!!!!!!!!!!!!!!!
Don
Question could someone doppler this file for me please? pulsar110 Electric Ducted Fan Jet Talk 0 Nov 02, 2009 02:49 AM
Video Can someone Doppler this for me? Bugman Jeff Electric Plane Talk 5 Feb 04, 2008 09:18 PM
Discussion Can somone doppler this for me? CCDR Sabre metroidrc Foamy EDFs 6 Nov 02, 2007 10:28 PM
Video My 650 Watt TwinJet w/ 2X Mega 16/15/3's can someone doppler for me? MailOrderGuy Electric Plane Talk 9 Sep 20, 2007 09:21 AM
Discussion Can someone doppler this for me? Bugman Jeff High Performance 2 May 27, 2007 11:51 PM
