Old Dec 23, 2010, 01:40 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Don, can you please try to pull speeds off the following clip:
http://treswright.vervehosting.com/M...r-12-23-10.MOV
The speed runs don't start until after the 1 minute mark and I announce just before each pass which direction it is. Right-to-left runs were with the wind and will be a bit faster than the left-to-right. Temperature was 46. Sorry about the large file size, this was taken with my phone and it is terrible on video file size.
Thanks!
Tres Wright is offline Find More Posts by Tres Wright
Old Dec 23, 2010, 07:20 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Here is what I get, upwind 54.4 downwind 66.8 so that is 60.6 mph average.
The Don is offline Find More Posts by The Don
Old Dec 23, 2010, 07:47 PM
Forney, TX
Joined Mar 2002
Ouch! I could tell it was dragging a bit, I guess due to the cold weather on the li-po's. That's slower than I thought though. Thanks Don!!
Old Dec 23, 2010, 08:12 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
That was the best pairl, it was the middle set of passes, the first ones and the ones after were a few mph slower.
Old Dec 24, 2010, 01:54 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
las t attempt at the edf 40 speed contest. unfortunately, i think my alttitude is hurting me with the edf 40. its so small. i dont think it hurts the larger fans as much. it almost seemed slower than before....but i guess dopler will tell....
thanks again Don! you freakin rock.
merry christmas!
temp 55 deg
http://www.rcgroups.com/forums/showt...4#post16910383
corsair nut is offline Find More Posts by corsair nut
Old Dec 24, 2010, 09:09 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Those are the most consistent set of passes I have ever seen!
The official speed is 90.5 mph
Don
Old Dec 24, 2010, 10:17 PM
tehachapi, CA
Joined Jan 2006
thanks a ton don!!!!!!! what were the best high's and lows?
i think it has another 5-10mph left in it at sea level like the first flights. still, 6mph increase isnt too bad, just not as much as i thought for a 20mph eflux increase over first flights at sea level.
thanks again for taking the time don!
Old Dec 24, 2010, 10:28 PM
tehachapi, CA
Joined Jan 2006
don, for 6 blades, what kind of rpm is this running? i dont even know what the kv is on this motor just got lucky i guess
not bad for a cut in half wattage blade
Old Dec 24, 2010, 10:37 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I got:
97
84
98
83
98
83
96
84
RPM: 55900
Old Dec 24, 2010, 10:55 PM
tehachapi, CA
Joined Jan 2006
great!!! thanks don!
56k. not bad means this motor isnt loaded much! i think the kv is around 4000. 4s....so, say 15v loaded. hmm. it is a big heavy motor forsomething this size...but i guess it works...next step would be to try one of your 4800's in it...i think it only weighs another 10g or so....whats another 10g? just keeps adding up.... this motor is accualy bigger than a dons in diameter, just a little shorter. alot of the weight is in the adapter.
Old Jan 07, 2011, 11:41 PM
tehachapi, CA
Joined Jan 2006
FriFal.wmv (2 min 43 sec)
can u dopler this for lee liddle? 58 deg i thnk. rpm would be cool too...5 blades...thanks don!
Old Jan 10, 2011, 09:55 PM
tehachapi, CA
Joined Jan 2006
heres some more electrolyte video, this was my first time flying at sea level with the new packs/esc. was scooting pretty good, but i cant tell if it was better than at 4,000 asl or not. temp was about 60 deg.
Electrolyte 40mm EDF Sport Jet (3 min 34 sec)
Old Jan 10, 2011, 10:11 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Holy cow!
I got 160, 160, and 160! RPM = 32.5k-32.8k
Don
Old Jan 10, 2011, 11:07 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
No video link
Old Jan 10, 2011, 11:14 PM
tehachapi, CA
Joined Jan 2006
fixed! and thanks! ill tell lee!
Question could someone doppler this file for me please? pulsar110 Electric Ducted Fan Jet Talk 0 Nov 02, 2009 02:49 AM
Video Can someone Doppler this for me? Bugman Jeff Electric Plane Talk 5 Feb 04, 2008 09:18 PM
Discussion Can somone doppler this for me? CCDR Sabre metroidrc Foamy EDFs 6 Nov 02, 2007 10:28 PM
Video My 650 Watt TwinJet w/ 2X Mega 16/15/3's can someone doppler for me? MailOrderGuy Electric Plane Talk 9 Sep 20, 2007 09:21 AM
Discussion Can someone doppler this for me? Bugman Jeff High Performance 2 May 27, 2007 11:51 PM
