Old Feb 09, 2010, 09:05 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Yippee!
Doppler me Don!
If you guys need a video dopplered I will gladly take a stab at what you have, post a link to the video and also post the air temperature and i will see what I can get.
Don
The Don is offline Find More Posts by The Don
Old Feb 09, 2010, 09:06 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
How to make a good doppler pass:
To make a good doppler pass you need a few things, here are some pointers on how to make good doppler passes.
1) First you want to keep the background noises as low as possible. Flying with a loud gas engine in the background, or adding music to a soundtrack, or talking close to the recording camera can make it difficult to extract the audio needed for doppler.
2) You must fly at a constant throttle setting. For doppler to work, the "source" frequency must remain constant. This means your rpm must be constant during the doppler pass. If you rpm drops (due to voltage sag or moving the throttle stick) then your "source" frequency changes as well and you will not get a valid doppler reading.
3) You MUST fly in each direction at least 5 to 8 times the distance from the microphone to the plane. If your plane passes 100 feet from the microphone, then you must fly at least 500-800 feet towards the microphone and 500-800 feet past the microphone. So the closer you are the better. I shoot for 50 feet and I often place an MP3 player in the flying field, set it to record audio, then fly over it as low as I can. This way you are not flying too close to your camera man. If you do not fly the required distance ratios, then you do not get a complete doppler shift, and you will rob yourself of speed.
4) Fly in a straight line coming to and going from the microphone. Do not pull up or turn. Always fly in a straight line.
5) Do not gun the throttle, you need to be at full throttle as you enter your doppler pass, reach the microphone, then go past the microphone.
6) Use the "rule of 3". This means your approach should be about 3 seconds and your depart should be about 3 seconds. Count in your head each way.
7) Know the outside air temperature. The speed of you model depends on the frequency shift and the local speed of sound. The speed of sounds varies with air temperature so make sure you know the air temp within a few degrees.
When you follow these guidelines you will get fast and complete doppler shift and the reading will be very easy to do.
Old Feb 10, 2010, 05:12 AM
vvV FANG Vvv is online now
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Harden
Joined Aug 2008
Hi Don, I tried another few speed runs with the Funjet, not sure if they are usable due to another plane making some noise in the background.
I wonder if the flight patterns look better.
Funjet Speed test 3s (2 min 21 sec)
And you say you had a similar wing to the windrider ele bee i had, what extra carbon did you put in it? Mine ended up folding~
vvV FANG Vvv is online now Find More Posts by vvV FANG Vvv
Old Feb 11, 2010, 10:54 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I am getting about 86 mph consistently. However I do believe it is going faster and am willing to bet if you had the camera a little closer the speeds would go up to about 90 mph.
I did have the same Elebee wing. I ran a carbon rod along the leading edge and then a carbon strip along the trailing edge. I also replaced the elevons with balsa wood elevons, I got rid of the canopy and made a recess in the front that helped the lipo so about half of the lipo was in the wing and the other was sticking out.
Don
Old Feb 19, 2010, 03:40 PM
JIMBAKER is offline
Find More Posts by JIMBAKER
called into work, I'm AIRSICK!
JIMBAKER's Avatar
United States, OR, Klamath Falls
Joined Jan 2009
Try # 2, Orange Crush
Hi Don,
Here is another run at it with my racer, Orange Crush. The wind was blowing and I recorded a lot of wind noise, so I don't know if the sound quality is good enough. I think I have a couple of usable passes? If it is faster than the average of 88.3 mph I did before, I'll post it on your speed challenge and make it official. I think I know what is going on now, I believe the horizontal stabilizer is flexing at the higher speeds. It becomes overly sensitive, more so than just what the speed difference should make. I will retire this one and finish OC II; it has a full 5mm spar in the stabilizer. It is all a learning experience!
jb
JIMBAKER is offline Find More Posts by JIMBAKER
Old Feb 19, 2010, 03:56 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Where is the file????
Old Feb 20, 2010, 02:40 AM
JIMBAKER is offline
JIMBAKER's Avatar
Joined Jan 2009
Here it is, sorry about that
Orange Crush_Feb 19_2010 (2 min 27 sec)
Old Feb 20, 2010, 05:16 PM
Formerly bUd~Fokker
Joined Aug 2008
Don i forgot to thank you for dopplering this for me. Im keen to try and crack the 100mph mark on 3s, and maybe 200kmh on 4s. I will post another video once i get used to the sped and a closer better video.
And thanks for the info on your wing, it looks like the cf spars are about an inch back from the leading edge? I did wonder what size tubes you used.
Cheers man~
Old Feb 20, 2010, 06:37 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
http://www.youtube.com/watch?v=RC5zo0m2iHg
I need to work on the video as the background noise is messing it up a little. I will post what I get.
Old Feb 20, 2010, 06:42 PM
JIMBAKER is offline
JIMBAKER's Avatar
Joined Jan 2009
Thanks Don, I am guessing the wind noise.
Old Feb 23, 2010, 07:26 PM
JIMBAKER is offline
JIMBAKER's Avatar
Joined Jan 2009
Doppler Please
Hi Don,
I took my regular camera (Canon PowerShot) with me on this outing the 22nd setup the tripod and got these. This was the Orange Crush racer, to post on the 2010 challenge do I need the whole video? If so I can up load it to youtube.
Thanks, jb
Old Feb 23, 2010, 07:46 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
These doppler VERY well, can you post the whole thing on YT?
Don
Old Feb 23, 2010, 07:49 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Hey Don,
Not sure if you can pull anything out of this but there is a fairly decent pass from 2:04 to about 2:09
temps were 68 F
Starmax A-4 55mm edf (3 min 3 sec)
Possible?
Joe 1320 is offline Find More Posts by Joe 1320
Old Feb 23, 2010, 08:01 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Jim,
I have tried my best on this video and the background wind noise is just loud enough that it drounds out the sound of you coming and going.
Don
Old Feb 23, 2010, 08:04 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Originally Posted by Joe 1320 View Post
Hey Don,
That pass was ~76 mph.
Don
Question could someone doppler this file for me please? pulsar110 Electric Ducted Fan Jet Talk 0 Nov 02, 2009 02:49 AM
Video Can someone Doppler this for me? Bugman Jeff Electric Plane Talk 5 Feb 04, 2008 09:18 PM
Discussion Can somone doppler this for me? CCDR Sabre metroidrc Foamy EDFs 6 Nov 02, 2007 10:28 PM
Video My 650 Watt TwinJet w/ 2X Mega 16/15/3's can someone doppler for me? MailOrderGuy Electric Plane Talk 9 Sep 20, 2007 09:21 AM
Discussion Can someone doppler this for me? Bugman Jeff High Performance 2 May 27, 2007 11:51 PM
