Old Feb 09, 2010, 05:54 PM
marcwv is offline
Find More Posts by marcwv
United States, CA, Northridge
Joined Apr 2004
DX7,How do you program throttle off switch?
A friend had programed my gear sw to disable the throttle.Lost the setting.
Any of you know how to set this up? Airplane version of the DX7.
Marc
marcwv is offline Find More Posts by marcwv
Old Feb 11, 2010, 05:40 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Not 100% sure about the DX7 but if its anything like the DX6i then Spektrum did not program the radio to be able to disable the throttle channel in acro or airplane mode
freechip is offline Find More Posts by freechip
Old Feb 11, 2010, 10:47 AM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
A friend of mine programmed his DX7 so a switch disables the electric motor. There is no way the motor can run unless the switch is in the correct position. No, I do not know how he did it, but obviously it can be done......
You didn't say electric powered, but it read that way to these ole "eyes".
Marion is offline Find More Posts by Marion
Old Feb 11, 2010, 10:22 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
See if this is what you are looking for. The topic has been covered many times, so you will find other examples with a quick search.
http://www.rcgroups.com/forums/showt...+throttle+lock
EDIT: Same idea is covered by Dan777. You may still want to view the thread as it gives a bit of explanation.
Daedalus66 is offline Find More Posts by Daedalus66
Dan777 is offline
Find More Posts by Dan777
Shakopee, MN
Joined Aug 2004
I have the Heli DX7 and here is how I have mine set. I don't know where I found the settings but it works for me
-Use one of the program mix's
-Set Thro-Thro
-Rate -100%
-SW:Mix (Hold-Rudder D/R switch on mine) (other options Flap 0, Flap 2)
-OFFSET: -125
Dan777 is offline Find More Posts by Dan777
Discussion How do you cut tail feathers off , to repair. eng30 The Builders Workshop 1 Nov 18, 2009 08:22 PM
Question After how many charge cycles do you give a new lipo "full throttle" arukum17 Batteries and Chargers 1 Oct 31, 2009 09:11 AM
Discussion DX7 - how to program a throttle on/off switch? Jim_Marconnet Electric Plane Talk 25 Apr 04, 2007 03:29 PM
Discussion Can you program a "Throttle Lockout Switch" for a Futaba 9C Howemd Radios 2 Oct 24, 2006 10:32 AM
Flash 5x- how do you program throttle to a switch ? Al P Radios 5 Sep 10, 2004 11:25 AM
