Old May 20, 2003, 03:34 PM
Captain Carlton is offline
Find More Posts by Captain Carlton
Captain Carlton's Avatar
Fairfield, CA
Joined Apr 2002
New 16/15/5, do I grind a flat spot on the shaft?
I got my first Mega. Do I grind a flat spot on the shaft for the set screw for the prop adapter, or do i leave the shaft perfectly round?
Thanks, Rick
Captain Carlton is offline Find More Posts by Captain Carlton
Old May 20, 2003, 03:43 PM
flipnidaho is offline
Find More Posts by flipnidaho
Boise
Joined Sep 2002
I left mine alone...
the friction of the grub screw should be enough...
flipnidaho is offline Find More Posts by flipnidaho
Old May 20, 2003, 03:44 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Same here.
William A is offline Find More Posts by William A
Old May 20, 2003, 03:51 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I just use friction and have not had any issues.
Old May 20, 2003, 04:21 PM
uscra112 is offline
Find More Posts by uscra112
Mid-Michigan
Joined Aug 2002
Mmmmm, can't agree about just counting on the friction of the grub screw. My hayfield is littered with props and adaptors that came off in flight. 99% of which I've never found. At least use a little Loctite, not on the screw but on the shaft. Helps keep the adaptor from creeping on the shaft, which loosens the screw.
Better yet use a collet-type adaptor.
uscra112 is offline Find More Posts by uscra112
Old May 20, 2003, 04:24 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
True - I did loctite the screw - but I have 60 or so flights with no issues.
Old May 20, 2003, 06:27 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Collet adaptor
I second uscra112 - I'll never use a grub-screw adaptor again after having a prop fly off my Phasor and another off my AXI during bench-testing. I had tightened them fully, and put Loctite on, but they still tried to go through me, then the wall. I have no idea why the machining of a flat on the shaft is not standard practice among manufacturers of these potent motors.
Be careful out there! Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 21, 2003, 03:49 AM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
CC,
I use a Graupner collet type adpator on my 16/15/6 to mount APC props which effectively grips the whole shaft, not just a single spot where a set screw contacts it. Once you tighten the bolt then there's absolutely no way that prop adpator is coming off there.
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old May 21, 2003, 07:01 AM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
I gave up on prop adaptors with screws before I went brushless. The collet type that tighten with a nut in front don't wobble or come loose, and no shaft grinding.
Al P is offline Find More Posts by Al P
Old May 21, 2003, 07:23 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Collett is always better, but even 27-cell F5B setups can have a screw-type adapter stay on a round shaft when properly installed. Dieter has posted the procedure here a few times..
..a
For Sale New Kontronik Fun 600-17 ($100 shipped USA) milled flat spot on shaft macaria Aircraft - Electric - Power Systems (FS/W) 1 Mar 03, 2007 07:49 PM
F/S: New 16/15/5 Mega Lv2Fly Aircraft - Electric - Airplanes (FS/W) 2 Oct 25, 2003 02:16 PM
mega 16/15/5 bent shaft? tomlescal Power Systems 3 Oct 10, 2003 10:37 AM
need advice on mega 16/15/5 and rz2500 tomlescal Parkflyers 0 Sep 15, 2003 09:13 AM
Tangent ROCKS on mega 16/15/5 buzzsaw 46 Sport Planes 37 Dec 19, 2002 10:14 PM
