The tail is in fine working order. I know it is a gov issue because I can hear the motor let off for a split second and then recover, slightly overshooting as it does so. Besides a gov change fixed it once again and nothing else was changed. I am starting to believe that the gov has issues if things line up just right. Kind of like resonance frequencies when talking about sound. By changing the head speed just a little, I think it solves the problem. That is just a theory I have thought up. |
What you are talking about is planned for a future release of the ICE software. We call it a "circular buffer." Basically, when the log gets full, the oldest data will be continuously overwritten by newer data. Thanx! Patrick |
Joined Dec 2009
Question on new set-up for CC
Working on upgrading my 450SE V2 to an IceLite 50 and a NEU 1107H-1.5Y and wanted to make sure I got it right.
1) I’m looking to run a 12T pinion (150T main gear) and target 2900-3000 rpm headspeed (3S). Using the Set RPM Governor mode that would put me around 94-97.5 %. Is this correct? Is it recommended that I move to the 13T pinion? 2) If I use Governor Simple (instead) do I just set my throttle curves flat for the percent I would like to operate the motor? (i.e. flat 80% = 80% max motor rpm) This would be the same or similar to a Kontronik. 3) For a NEU motor run 12 kHz PMW Rate? Set Current limiting to “insensitive”? 4) What is recommended for Motor Timing? Here is my CC config file. But the above really addresses the questions I have at this point. Greatly appreciate the help! ################################################## ##### # Castle Link Data File # Created: Tuesday, May 11, 2010 # Do Not Edit This File By Hand ################################################## ##### Brake Ramp: Immediate (*) Brake Delay: .6 sec (Delayed) (*) Sample Frequency: 5 Sample / Sec (*) Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*) Power-On Beep: Enabled (*) BEC Voltage: 5 Hex55: 85 Vehicle Type: Helicopter Throttle Type: Governor Mode Throttle Response: 5 Governor Gain: 14 Initial Spool-Up Rate: 2 Head Speed Change Rate: 5 Auto Rotate Enabled: False Governor Mode Type: Fixed Vehicle Setup - Battery Type: LiPo Vehicle Setup - Number of Cells: 3 Vehicle Setup - Battery Voltage: 11.10 Vehicle Setup - Gear Ratio: 12.5000 Vehicle Setup - Pinion: 12 Vehicle Setup - Spur: 150 Vehicle Setup - Motor Kv: 3850 Vehicle Setup - Motor Number of Poles: 4 Desired Head Speed 1: 2800 Desired Head Speed 2: 2900 Desired Head Speed 3: 3000 Data Log Enabled: 255 Motor Timing: 5 PWM Rate: 12 Khz Brake Strength: 0 Direction: Reverse Current Limiting: Insensitive (80A) Motor Start Power: 59 Cutoff Type: Soft Cutoff Cutoff Voltage: 90 |
12 PWM Current Limiting - Insensitive "Simple Governor Mode Simple governor mode is designed to be the easiest to use out of the box. You simply throttle up as if you were in ‘Heli-Fixed’ mode. The throttle stick is directly controlling the power to the motor, and NOT specifying rpm. Once you get to your desired rpm, leave the stick at that position for 1.5 seconds and the ESC will ‘lock’ onto that RPM. If you move the throttle, the head-speed will change accordingly. The only drawback to this mode is you do not know your exact head-speed." Where ever you set the HS it looks at the the throttle power for 1.5 seconds and then it locks in if you change the throttle it will lock in again in 1.5 seconds. You can put the curves in or the flat throttle and use a tach to determine the Head Speed you want. Set Rpm Mode is a great improvement over Simple mode as you just enter the information on the motor, Battery and gearing, set the Head Speed and go fly. The GOV Gain is the only thing to adjust after that. The Set Rpm Mode will even advise you of the recommend Head Speed. |
United States
Joined Feb 2001
Joined Jun 2010
ICE HV 80 power down
I have a question about the ICE HV 80.
When I use the "Throttle Hold" switch to power down the heli, the ESC keeps the motor running for about 1 second before it powers down. Is the a setting to do this immediately? In case of emergency, it's good when it stops right at the moment you flip the switch, not a second (or maybe 2) after that. Is that possible? By the way, I use the Set RPM governor mode. Regards Guido |
United States
Joined Feb 2001
| Thread Tools | |
| Mini-HowTo Setup Instructions for CC Controllers. | RS Rogers | Castle Creations | 152 | Mar 17, 2013 05:51 AM |
| Discussion CC Ice 75A and HK-3026-1600kV need help for setup | Radomer | Castle Creations | 6 | Aug 07, 2011 02:43 AM |
| Discussion CC ICE controllers | Chris True | Electric Ducted Fan Jet Talk | 21 | Jan 19, 2010 02:11 PM |
| Please list the RPM / Pole in Governor Mode for CC controllers | CustomPC | Castle Creations | 1 | Jun 21, 2005 09:23 AM |
| CC controllers - procedure for software upgrading? | simingx | Castle Creations | 8 | Aug 17, 2004 03:19 PM |
