This thread is privately moderated by RS Rogers, who may elect to delete unwanted replies.
Old Jan 03, 2013, 05:34 PM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Originally Posted by I-FELN View Post
Please :
'm having problem setting up the CC ICE2 60HV (new), somehow the throttle endpoint setup is not succeeding and I've done this to my others CC ESC without any problems! I spent 1 day and + to try it: nothing to do. Again The ICE2 would not enter in manual program mode by Throttle, seem not receive the chanel signal.
The ICE2 setup by computer sofware is all default set with Type Helicopter and throttle fixed endpoint.
TX SPEKTRUM DX8 - RX AR8000 DSMX with TM1000 - frame rate is 11ms, also tried to bind with another new RX AR8000 without TM1000 still nothing to find endpoint. Also tried reload firmware and reset to default.
Thanks in advance for some suggestion.
B.Regards
PS: Than I will contact CC technical support.
With a Graupner MX12 PCMS: the same. I think this is a faulty unit.....
Now I'm unhappy CC customer cause this unit was send to me in substitution of an ICE HV 60 recalled from them for service advisory. The old ICE HV60 had also the same problem. Now I split to buy a new Himodel ESC: tired to waste my time on bad CC units.
Make sure the center wire is not disconnected in the servo lead from the TX and ESC.
Clintstone is offline Find More Posts by Clintstone
Old Jan 04, 2013, 01:26 PM
I-FELN is offline
Find More Posts by I-FELN
T-REX 250 -450-500-600-700G
I-FELN's Avatar
ITALY, PAVIA
Joined Mar 2009
with the center wire connected the CC unit became very very HOT so I switch all OFF: fear to burn!
I-FELN is offline Find More Posts by I-FELN
Old Mar 17, 2013, 05:51 AM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
Can I extend the motor wires 12"? I fly Jets and usually put caps and extend the battery wires. I thought I read somewhere that you can extend the motor wires without using the caps.
I have been following the Ron van Sommeren thread for a long time and can't get a answer there. I am running Castle 120HV and 160HV's. I haven't launched the new Jet yet I hate dead stick landings so I thought I better ask for help.
By the way, I have owned probably 15....or more of your speed controls, for my application (Jets) they are perfect. NOT one failure over the last 5 years....I can't say that about the other esc's I've run. Great product! Hey it's time for some new decals.lol
keithtsr is offline Find More Posts by keithtsr
Old Jun 12, 2013, 08:14 PM
Pelicanbrigade is offline
Find More Posts by Pelicanbrigade
Joined May 2013
Just bought a Phoenix Edge Lite 50A to replace the burned up stock ESC on my Blade 450X. I think I understand everything, but what do I use for PWM and motor timing settings? The stock motor is the E-flite 440H and it's a 6 pole motor, 4200Kv, 136T aftermarket Lynx main gear and 9T (or maybe 10T in the future) pinion. I've searched and cannot find the other specs. 3S 2200mAh 35C batteries. Thanks in advance!
Pelicanbrigade is offline Find More Posts by Pelicanbrigade
Reply With Quote  (Disabled)
Old Jun 13, 2013, 04:48 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
A PWM of 12 KHz should be good. PWM of 8 may make the ESC run a little cooler. Either one should be ok for the motor. If you use the governor mode I have found that PWM of 12 is sometimes smoother so start with 12 but it won’t hurt anything to try both and see what you like best.
The EDGE has dynamic motor timing. It adjusts timing as it is running. For the best efficiency and longest flight time use LOW timing. Medium is less efficient and sometimes makes a little more power but the motor will run hotter and the flight times will be a little shorter.
RC Man is online now Find More Posts by RC Man
Old Jun 13, 2013, 07:43 AM
Joined May 2013
Thanks for the help, RC Man! Between servos dying in flight and this latest ESC burning up, the last thing I want to do is smoke something else.
Old Jun 14, 2013, 11:04 AM
SteveCC is offline
Find More Posts by SteveCC
KS
Joined May 2007
Hi RC Man,
Curious where you got the "Dynamic Timing" from??
SteveCC is offline Find More Posts by SteveCC
Old Jun 14, 2013, 02:41 PM
United States
Joined Feb 2001
Originally Posted by SteveCC View Post
Hi RC Man,
Not sure if thatís the exact term that CC uses but it was discussed some time back on this forum. They have had this feature for quite a few years. Maybe someone from CC could give a more exact description.
Old Jun 14, 2013, 06:51 PM
Joined May 2013
Originally Posted by RC Man View Post
Not sure if that’s the exact term that CC uses but it was discussed some time back on this forum. They have had this feature for quite a few years. Maybe someone from CC could give a more exact description.
If you run the actual CC set-up program and click on the help tab under motor timing, that is exactly what it says about the ESC and automatically setting the timing.
"Castle Creations controllers automatically determine the correct and best range of timing advance for any motor they are plugged into when running in sensorless mode."
Old Jun 16, 2013, 12:39 PM
Joined May 2013
I want to thank the guys who helped me in this thread. Just flew the Phoenix Edge Lite 50 this morning. Heli flew better than ever and the setup was so easy. Just put in your motor/battery/gearing parameters and chuck in some head speeds (well, ones that are deemed okay for governing by the CC program) and go fly! I only needed some minor tweaking. I ended up with the governor gain lower than the low default setting. 10 versus 15. I had some minor motor pulsing and, while the heli was smooth, I could hear it. I guess the governor gain needed to be so low because 450 blades are so light and really responsive to motor RPM changes, unlike larger, heavier blades that take longer to overshoot/undershoot the selected RPM in flight. I also ran low for the motor timing and changed the overcurrent protection to "insensitive", as recommended for helis.
So, overall a great first time out experience with this ESC. Thanks again! Now, just praying for durability and many, many flights without smoking like the last junk (definitely not Castle) ESC. LOL
Old Jun 16, 2013, 02:06 PM
Joined May 2013
Edited: Posted a question, but I figured it out myself.
Old Jul 31, 2013, 06:47 AM
enzozhan is offline
Find More Posts by enzozhan
Joined May 2013
Hi guys. got a little problem with my ICE50 on a T REX450. I'm using the DX7s Tx.
I got the heli from its last owner, so its all built up, and the ESC is set as set RPM governor mode, only thing I need to do is to calibrate the end points my self, said the last owner.
so I did, as the tutorial, 0-100 linear throttle curve, 30% both high and low, plug in, increase travel till the beep comes up, same with the low range. I ended up as 74 high, and 60 low. then the ESC is armed, motor runs if i gave throttle up.
just a little unconfident with the 74 and 60 number, seems a bit low though, have read some guys in other thread said it looks like in airplane mode not heli, but I don't even have a castle link, not to mention change setting in software. the last owner said as long as its not reset in the computer nothing should have changed.
is that a accept result about the end point?
enzozhan is offline Find More Posts by enzozhan
Old Jul 31, 2013, 02:55 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Does not seem right. On my DX8 (same programming like on the DX7s) my lower limit is 123%, the upper is 102%. Even if there is some variance caused by different RXs (I use an AR8000), that should only be around 2-3%. So you did something wrong.
I have Set RPM mode active. 3 different RPMs defined in CC link. You should really get a castle link device....
Mukenukem is offline Find More Posts by Mukenukem
Old Nov 04, 2014, 08:05 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
It sounds like the settings in the ESC are for fixed endpoint instead of GOV mode... If you are getting the TX to calibrate the 100% and the ESC is arming... then it should be fine... Plugging in the Castle Link to the ESC will reveal the settings and this will tell us if the throttle value is about right. Thanks for posting.
Old Jun 13, 2015, 01:27 AM
Steve Graham is online now
Find More Posts by Steve Graham
AMA L897187
Steve Graham's Avatar
NE Denver, CO
Joined Sep 2007
I'm hoping someone can provide a simple answer to this. I have been using a CC Edge 160 with a Vbar Silverline for a couple years now on a Rush 750. Looking back I think I've had some of these issues before but it's been long enough that I can't remember them all or what I might have done to resolve things? I moved all my gear over to a new Synergy E7-SE. I spent about 3 days chasing setup. When I would test on the bench at times the RPM would work. At other times it would be sort of random with the current RPM readout on the Vbar control panel wandering around as if the it weren't reading the RPM signal reliably. I wrongly assumed, I think, that the RPM out signal had finally failed completely when it went to zero and stayed there in the Vbar control panel. I swapped the Vbar main unit with a known good one from another heli. Same results so I again assumed the problem was in the RPM output. I was able to get the internal governor working on the Edge but I want to use the Vbar external governor to avoid the dreaded CC RPM sag after overspeeds. At this point I bit the bullet and had the LHS order me a new Edge 160. I spent several hours tonight soldering up a power harness for the new controller only to find I still have random and intermittent RPM readings on the Vbar control panel along with the same actual rpm's on the head.
Question 1. Am I doing something painfully and obviously wrong?
Question 2. Is the RPM output from the Edge weak and subject to RF noise as it passes close to the motor on it's way back to the vbar? Somewhere I read that CC's and Mikado worked together when developing the Edge?
Question 3. Is the vbar known to have trouble reading the CC RPM signal?
Question 4. Should I give up and go to a phase sensor? Which one?
Question 5. Should I give up and go to a YGE controller? I've already spent around 5 bills trying to get one functioning system and I'm really not sure where the problem actually lies so I'm hesitant to just throw any MORE money at the problem.
Question 6. I have a KDE 700XF-495 Kv motor which has 8 poles. Should I tell vbar software this is a 4 or 8 pole motor in the governor setup? Changing between these two numbers seems at times to have an effect on RPM. In both cases the current RPM readout on the software is inconsistent and unreliable.
Someone somewhere must have struggled with these same issues I hope?
Steve Graham is online now Find More Posts by Steve Graham
