Old Nov 07, 2013, 10:20 AM
Guard-Officer is online now
Find More Posts by Guard-Officer
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
The propagation of radio waves through water is not the problem, its the propagation of radio waves through the surface of the water that is a major problem. your range is so limited because you loose a significant amount of the signal and its strength when it bounces off the surface of the water. The ultimate solution would be to have instead of an antenna, a transmitter buoy with an umbilical up to your transmitter in your hands. then the radio wave is being generated under the water already and there is no need to penetrate the waters surface. The same holds true for your submarine, if you mount the antenna on the exterior of the hull, the transmitted waves do not have to enter the air filled compartment of the submarine, which would further reflect the waves. as an experiment, put a transmitter in a water proof bag and use it under water (obviously a cheap transmitter...) I would bet that if the entire antenna were submerged, with no air around it, you would have pretty great signal back and forth. I believe you can get frequency modules, if you run wires from the transmitter to the module under water and generate the frequency there, you would have great success.
But keep in mind this is just a theory.
Good Luck!
Cheers
G-O
Guard-Officer is online now Find More Posts by Guard-Officer
Old Nov 14, 2013, 08:52 PM
MiG29Fulcrum is offline
Find More Posts by MiG29Fulcrum
Joined Apr 2012
It may not be legal, but 72 works underwater fine. When I lived in L.A. a guy I knew out there had a sub he ran in a local park lake using a 72 aircraft radio. No problems. (Hopefully he didn`t shoot anybody down in the area.)
MiG29Fulcrum is offline Find More Posts by MiG29Fulcrum
Old Nov 15, 2013, 09:46 AM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
I don't think it's just the radio bouncing off the water surface, UHF just doesn't propagate through water very well.
I guess it' a bit like wading through water, take it slow, and you get along okay, start trying to run, and you fall flat on your face.
Sub culture is offline Find More Posts by Sub culture
Old Dec 12, 2013, 09:34 AM
dirtybird is online now
Find More Posts by dirtybird
United States, AZ, Queen Creek
Joined Aug 2004
The lower the frequency, the better the RF penetrates water. The US Navy uses very long waves to communicate with their submarines. I would think 27MHZ would be better than 72
dirtybird is online now Find More Posts by dirtybird
Old Dec 12, 2013, 01:16 PM
Roedj is offline
Find More Posts by Roedj
Michigan, USA
Roedj's Avatar
Joined Apr 2008
You're right.
There are three sources of signal strength for RC subs:
1) Transmitter antenna to surface of water (loss in air),
2) Signal going from air to water (surface of the water), and
3) Signal loss through the water.
All three makes it darn near a miracle that this works at all at 75MHz, let alone 2.4GHz - 2400MHz, but the greatest individual loss is #2 - going from air to water.
Dan
Roedj is offline Find More Posts by Roedj
Old Dec 13, 2013, 08:26 PM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
The difference is negligable between the various R/C Mhz frequencies.
The Navy uses Khz range signals transmitted at 1 Mega watt or more, , takes 30 seconds for 1 character to be transmitted, though it does have 10000 Klm range basically calls the sub to antenna depth to receive the full message. I visited the trannsmitting station in Exmouth
http://en.wikipedia.org/wiki/Naval_C...Harold_E._Holt
I think this might be somewhat out of the scope of what we want to do LOL
nick_75au is offline Find More Posts by nick_75au
Old Dec 14, 2013, 11:08 PM
Smokeyr67 is offline
Find More Posts by Smokeyr67
Joined Mar 2010
Come on mate, don't be defeatist Sure it might be more of a club rather than individual project, but never underestimate the resourcefulness of an RC modeller!
Smokeyr67 is offline Find More Posts by Smokeyr67
Old Sep 16, 2015, 07:16 PM
Ridge_Lift is offline
Find More Posts by Ridge_Lift
SlopeAsoarUs
Joined Jul 2015
2.4GHz Submarine; Salt Water
One solution is to use a tether to a bouy.
A thin coax cable leading the 2.4GHz signal up to a bouy which would house the normal antenna in an elevated waterproof column (PVC for example).
Match the cable and antenna inpeadances correctly and you're good.
Then the transmitter and reciever wouldn't know the difference.
For depths greater than 10ft, a signal booster would be needed.
Can anyone say FPV ROV!?
Ridge_Lift is offline Find More Posts by Ridge_Lift
Old Sep 16, 2015, 07:46 PM
sunworksco is offline
Find More Posts by sunworksco
BabyBootLegger
sunworksco's Avatar
United States, CA, Alameda
Joined Nov 2010
It is possible to add a 75MHz transceiver to the radio....
sunworksco is offline Find More Posts by sunworksco
Old Sep 18, 2015, 04:27 AM
NX-687 is offline
Find More Posts by NX-687
Joined Aug 2007
Yo
Just run at a foot deep ,
use a 1 foot long antenna, that loses signal when you dive the antenna all the way under ,
and fail safes
to surface the boat
NX-687 is offline Find More Posts by NX-687
Discussion Underwater FPV, how would you approach it? Freakazoid FPV Talk 17 Feb 04, 2010 11:40 AM
Discussion 2.4 Futaba Tx/Rx w/ FAST, can i also do 2.4 Tx/Rx Video ?? cpostier FPV Talk 2 Feb 03, 2010 03:16 PM
Discussion Using 2.4 TX & 2.4 Video Sid3ways FPV Talk 27 Jan 28, 2010 06:30 PM
Found Trade 4 RC4WD Lawless 2.2 Custom Aluminum Wheels (Black)for a 4 door F350 body kuatto Cars - Trucks and Parts (FS/W) 1 Jan 07, 2010 09:11 AM
