Old Feb 07, 2010, 10:43 PM
happyflyer is offline
Find More Posts by happyflyer
NOT YOU!!
Joined Feb 2009
2.4 underwater
is 2.4 underwater better than 72?
happyflyer is offline Find More Posts by happyflyer
Old Feb 08, 2010, 07:39 AM
Subdave is offline
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
Short answer, No
2.4 will not work under water, and 72 is for aircraft. 75MHZ is the one. Dave.
Subdave is offline Find More Posts by Subdave
Old Feb 08, 2010, 07:30 PM
NOT YOU!!
Joined Feb 2009
why
won.t 2.4 work under water?? anyone know. has anyone tried??
Old Feb 08, 2010, 07:37 PM
ThorDesign is offline
Find More Posts by ThorDesign
Wichita, Kansas
Joined Jan 2004
Yes, it has been tried. No, it does not work!
ThorDesign is offline Find More Posts by ThorDesign
Old Feb 08, 2010, 08:57 PM
3prongcoolness is offline
Find More Posts by 3prongcoolness
Michigan
Joined Nov 2009
i heard the reason it does not work is because of the way the wave length of the frequency does not penetrate the water it just bounces off of it or something to do with the flux capacitor one or the other.
3prongcoolness is offline Find More Posts by 3prongcoolness
Old Feb 09, 2010, 05:51 AM
Albion is offline
Find More Posts by Albion
singapore
Joined Jan 2005
I could tell you why, but its top secret and would have to kill you after
Albion is offline Find More Posts by Albion
Old Feb 09, 2010, 01:00 PM
CG Bob is online now
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
The resonant frequency of water is 2.5 GHz, close enough to 2.4 GHz to cause reception problems with a submerged object - and possible reception problems for skimmers.
CG Bob is online now Find More Posts by CG Bob
Old Feb 09, 2010, 01:21 PM
Subdave is offline
Subdave's Avatar
Rochester NY
Joined Mar 2005
My advice, for what it is worth would be for anyone serious about model boating be it target or sub.
Is to find yourself a nice 75MHZ radio that you like, treat it nice, kiss it before you go to bed at night, maybe even a bedtime story of two!
Because you will be friends for a long,long,long,long,long time!!Dave.
Old Feb 09, 2010, 04:32 PM
abnormal is offline
Find More Posts by abnormal
Joined Aug 2006
Definitely NO! Water 'rotates' at the 2.4 GHz frequency, which is why microwaves work... and interfere with WiFi internet. It's also the same reason Bluetooth doesn't work so well through your body... the 2.4 GHz spectrum is effectively 'absorbed' by water.
abnormal is offline Find More Posts by abnormal
Old Feb 09, 2010, 05:04 PM
gpzy is online now
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
No go for subs. Works above water just fine.
gpzy is online now Find More Posts by gpzy
Old Feb 09, 2010, 06:18 PM
junglelord is offline
Find More Posts by junglelord
Joined Jan 2005
We must see this question, once a month, at least.
Why not make a sticky?
junglelord is offline Find More Posts by junglelord
Old Feb 09, 2010, 10:20 PM
SilentHunter is offline
Find More Posts by SilentHunter
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Yeah really.
I WISH it did work for underwater. And the good mhz systems are getting fewer and fewer...
SilentHunter is offline Find More Posts by SilentHunter
Old Jul 28, 2013, 03:03 PM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
has anyone tried with 35mhz ?
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Jul 28, 2013, 04:47 PM
Aeroengineer1 is offline
Find More Posts by Aeroengineer1
Mesa Falcon Fld, Arizona, United States
Joined Sep 2004
35MHz will work, though I am not sure of the legalities of using it in different parts of the world. It does physically work. Anything should work in the 100kHz range to the 100MHz range. If you could find a transmitter that had a lower frequency, it would probably still work, though at sometime, you would start to get bandwidth limited, though, I think that you would have to get pretty far down before that became an issue.
Aeroengineer1 is offline Find More Posts by Aeroengineer1
Old Jul 28, 2013, 04:49 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
thanks. I'm in Italy, we use 35/40/2,4 legally. Thanks for your reply
Discussion Underwater FPV, how would you approach it? Freakazoid FPV Talk 17 Feb 04, 2010 11:40 AM
Discussion 2.4 Futaba Tx/Rx w/ FAST, can i also do 2.4 Tx/Rx Video ?? cpostier FPV Talk 2 Feb 03, 2010 03:16 PM
Discussion Using 2.4 TX & 2.4 Video Sid3ways FPV Talk 27 Jan 28, 2010 06:30 PM
Found Trade 4 RC4WD Lawless 2.2 Custom Aluminum Wheels (Black)for a 4 door F350 body kuatto Cars - Trucks and Parts (FS/W) 1 Jan 07, 2010 09:11 AM
