Old Feb 07, 2010, 08:35 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Video
6mm profile f22 with lighting
Some led afterburners, blue intake, and red/green/strobe lighting on my depron f22.
The "afterburners" and blue intake leds are controlled from the AUX 1 switch on the TX and the red/green wingtips lights and nose strobe on the gear channel so I can do several combos.
Sorry for the extremely poor video quality.
Bombay is offline Find More Posts by Bombay
Old Feb 08, 2010, 04:49 AM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Very nice! They certainly add dramatic effect to the plane.
The only suggestion I have is regarding the placement of the green & red LED's - wouldn't it make more sense to have them along the wing edges, or facing the lower surface, considering usual pilot/plane orientation during flight. As they are, seems you'd only see them when you're flying inverted.
fredmdbud is offline Find More Posts by fredmdbud
Old Feb 08, 2010, 06:02 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Thanks, Fred. I put lights on the majority of my planes. True, having them point forward on the wingtips (depending on the directionality of the leds) might allow better visibility at altitude. This will not be a night flyer. I often fly at or below eye-level with these profile planes (I often fly off the bank of a low retention pond) so the top placement should not be a problem. They actually light up the top surface of the wing and vertical stabs. In this instance, they were easier to secure in the foam by going up thru the wing. For what it is worth, and while my raptor is certainly not scale, my scale resources (mainly Hyerscale.com) show them to be on top (although probably pointing forward). Check out the site below...a very good resource.
http://hyperscale.com/2007/galleries/f22a72dw_1.htm
Old Feb 09, 2010, 10:02 AM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
OK, LED lens "spotlights" gave me pause.
Old Feb 11, 2010, 10:58 AM
AhLian is offline
Find More Posts by AhLian
Joined Dec 2008
awesome lights! where u get those?! ^^ and GREAT job on the mods, including the paintjob! i tink this is by far the best profile scratchbuild plane i seen!
AhLian is offline Find More Posts by AhLian
Old Feb 11, 2010, 12:30 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Thanks for the kind comments. The LEDs are strip leds from hobbyking. you can cut them up. I used approx 3 yellow cut sections for each "thrust tube" and about 3-4 blue sections for the intakes. The red/green/strobe lighting is a small kit also from hobbyking. I put the strip leds on an electronic switch...also from hobbyking. I guess you know where I do my rc shopping.
Old Feb 11, 2010, 10:26 PM
Sl0flyer is offline
Find More Posts by Sl0flyer
Sl0flyer's Avatar
Traverse City, Michigan
Joined Nov 2008
very nice... do you have any flight vids?
Sl0flyer is offline Find More Posts by Sl0flyer
Old Feb 12, 2010, 06:56 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
No. But I have 2 night flyers, this lighted f22, and I am building a 60" night flyer wing with lights...so I really do need to get some video up. In the meantime, maybe I can get some "dusk" in-flight photos and a short vid from the movie function on the camera this weekend.
Build Log Mini/Micro 15" F22 Pusher Profile Bowerz Scratchbuilt Indoor and Micro Models 11 Dec 12, 2009 03:14 PM
Discussion 6mm depron profile plane ?? scousethief Scratchbuilt Indoor and Micro Models 2 Oct 31, 2009 12:30 PM
Discussion trying again......7.5"ws Semi Profile F22 customminatures Scratchbuilt Indoor and Micro Models 10 Feb 16, 2008 07:30 PM
Discussion will 6mm f22 pusher be a good candidate for edf FASTBEN Foamy EDFs 6 Nov 29, 2007 12:34 PM
Discussion profile raptor f22 plans Stephen Shioi Foamies (Scratchbuilt) 8 Jul 28, 2007 02:38 PM
