Old Feb 22, 2010, 04:48 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Just a bit of dust on the digits, but worth it...
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Feb 22, 2010, 05:28 PM
isoaritfirst is offline
Find More Posts by isoaritfirst
isoaritfirst
isoaritfirst's Avatar
Not a Brummie/but close
Joined Sep 2005
To be fair the last few models I have built
(RaceMX, Cyril, Ascot, Freestyler,Sigma, Typhoon, Vector, I could go on - Have been 2 piece wings so 2 x MPX greenies have been used.
Come to think of it I think the last 3 piece wing I installed was my Sting probably 5 years ago, and my Tragi 702 about 10 years ago and still a great model).
The Tragi has a db12 although I built that a long time ago well before I had considered what I was doing!
isoaritfirst is offline Find More Posts by isoaritfirst
Old Feb 23, 2010, 02:43 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
my 704 came with the loom. I can't remember how it was solder to be honest. Very well though IIRC.
satinet is offline Find More Posts by satinet
Old Feb 25, 2010, 01:09 PM
F3X is offline
F3X
Find More Posts by F3X
F3X
F3X's Avatar
Joined Jun 2001
Lookin' good guys!
Lets here the flight reports!!
F3X is offline Find More Posts by F3X
Old Feb 25, 2010, 04:34 PM
belouder is offline
Find More Posts by belouder
belouder's Avatar
Seattle
Joined Aug 2005
Did a bit of flying this past Sunday at our cow patty field. Wind 4-6 knots from the NW. Clear skies-crisp. After adding a couple of grams to the nose to get the CG at 117 (or thereabouts), I did a hand toss to check elevator. Seemed good.
Up the winch and a sort of ping at the top-underestimated how much line stretch there was and had TONS of energy when it rotated and it went up and up and up-very nice energy retention. Headed out over the valley and found a bump immediately. Switched into Thermal mode, dropped the camber slider and started turns and up it went. Seemed kinda easy. Stayed in the lift for a while till my eyes got worried and went to Reflex and boy did it scoot. Went from one end to the other in what seemed like no time and was still at eye worried alltitude. Dropped the flaps all the way to see how elevator comp was set and it just stopped. Didn't really come down, just stopped. Nice.
Brought it down and started think about landing. We're at a new field now and today we set up close to a tree line so the landing area felt cramped. Ended up doing a very short approach and turn to final and dropped the flaps-oh yeah it stops-flaps back up and extend the final to somewhere near me. Flaps back down and it stopped again-right in my hand. Very nice.
A couple of more flights told me I needed to mellow out elevator throw in Thermal mode, add more camber in launch and figure out how to throw a plane-I was doing the "almost stall" throw and it would yaw sideways and need correction. Still puckering when launching-this thing set me back!! When I finally developed enough line tension and threw it right-it tracked very nicely.
First real impressions-aircraft is very nimble-roll rate is very crisp and elevator stays active all the way down to near-stall speed. I like this as it gives me confidence "close in" to work low lift. Camber in as per instructions seemed to let me slow the craft down in turns nicely. Getting the turns flat seemd a chore so I let it hold bank more than usual and it didn't seem to affect the float-just went round and round. At 68 oz it seems to be just right-the breeze came up a bit and it didn't seem to be fazed by it-just dropped into reflex and away it went right through the breeze.
The plane really slows down in landing approach-I'll need to work on landings to get used to this. But when I was short, pulling flaps back up just allowed the plane to speed up-didn't mush and drop. I dialed out all the crow (ailerons up when flaps go down) as I found I really like the plane to just slow down with flaps rather than slow down and drop. Just found a line to the spot and regulated airspeed with flaps to make time. Very cool.
No bad habits other than my own nervousness with a new aircraft. Nice.
BK
belouder is offline Find More Posts by belouder
Old Feb 25, 2010, 06:23 PM
Joined Nov 2005
Big evening, got the wiring harness finished in the fuse, all plugs, all terminations, and continuity testing in the fuse and with the center panel attached. Also, started making a skeg for TD, see below.
Marc
Old Feb 25, 2010, 06:59 PM
SHVentus is offline
Find More Posts by SHVentus
Hawaii
Joined Feb 2009
Looks very nice, but aren't 2 red/black pair of 16ga from battery to the saddle heavy & overkill? Can't imagine why one would fail & not the other without something cutting one of the wires. Very nice work though. Want too build mine?
SHVentus is offline Find More Posts by SHVentus
Old Feb 25, 2010, 07:02 PM
SHVentus is offline
Hawaii
Joined Feb 2009
Also noticed that you only have the signal wires for 2 servos, yet have all 3 wires to the other two wing servos.
Old Feb 25, 2010, 07:36 PM
Joined Nov 2005
SHV
There was some discussin earlier about redundancy, whichI would love to tell I had in mind in setting this up, but just being symetric here. The power feeds are 18 gauge, and actually, I removed 3/4oz from the wire harness from stock by doing this versus the Tragi harness (which was first class as is). Their harness was three wires each servo in the fuse, twelve 22 gauge wires which I replaced with eight wires, four, 18 gauge power leads and four, 28 gauge signal wires. I also replaced all the signal wires in the wing with 28 gauge too.
The actual RX wire hookups are as such. I talked some with Rob Glover, he is the one that gave me the direction to head this way. The plugs with only signal wires are the aileron servos, that is all I need for them since power is fed via the 18 gauge power leads to each wing. The flap leads to the RX are fully wired to supply dual feed energy to the RX to feed the elevator and rudder servos in the fuse.
I have never done this intricate a wiring harness, first to admit. But Rob knows his stuff when it comes to energy management in about anything, he made missles work for a living under some really wicked conditions. So I took his lead and not only have I got redundancy, but I also am feeding a power supply to the wing and RX with the least amount of impedance to effecient power flow possible. It really was not hard to do and I think that it will make the ship TE position more accurate.
Marc
Old Feb 25, 2010, 08:19 PM
SHVentus is offline
Hawaii
Joined Feb 2009
Thanks Marc,
I (wrongfully) assumed that you split the power feed coming from the battery - with the 18ga wires to the fuse saddle for the 4 wing servos, & also a short feed from the battery to the Rx which would power the bus for the rudder/elev servos. (That would be a shorter & more direct power feed to the Rx bus than having to go to the flaps & back to the Rx). That's what Paul Naton shows in his DVD's.
I read the above discussion about redundancy, but assumed that it was talking about the runs from the wing saddle to the 4 wing servos. I've seen where some people run single power leads out the wing to power both the flap & aileron servos. I can see the logic on this doubling redundancy, but still can't follow the logic of a double red & double black from the battery to the fuse saddle. Please help me out here. It seems that any/most failures would occur at the plug/solder junction, not the wire itself (unless you got rodents getting in & chewing the wires )
edit: By running the power to the Rx via the flaps, in addition to the longer run & potential voltage drop, you're also increasing the number of connections that the power has to traverse. To me, thus increasing the risk of power failure to the RX, than by just running a short wire from your Dean's Ultra to the Rx directly.
Old Feb 25, 2010, 08:33 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Nice clever wiring Marc. Doing it this way, you avoid stressing the 22g like you would if it was attached directly to the deans. The silicone 18g wire can handle a lot more physical abuse than the cheap 22g.
The only thing I would do to bullet proof even more is maybe tie all the wire together near where they plug into the rx. Make it so they act like one "snake". Perhaps a large heatshrink tubing over the ends would do.
Nice build for sure! Thanks for sharing.
TL
fnnwizard is offline Find More Posts by fnnwizard
Old Feb 26, 2010, 04:31 AM
Joined Nov 2005
SHV,
Basically, I have isolated each side of the wing, all the way to the battery. You cannot see it because of the heat shrink, but each side's feed goes all the way from the DUP to the DB9. Please do not take it that I have some grand scheme here, was just one way to catch the mouse.
Marc
Old Feb 26, 2010, 06:12 AM
tigroot is offline
Find More Posts by tigroot
Bob W
Rock Hill, SC
Joined Jul 2003
Mark, Dang nice ride. Assembly looking good, hope to see it soon.
Bob
tigroot is offline Find More Posts by tigroot
Old Feb 26, 2010, 06:49 AM
liukku is offline
Find More Posts by liukku
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
Smart wiring :-)
Marc
Hello
I have struggled to understand the wiring diagram, but think I understand now. As I see it, it is also a smart solution when using a 6 Channel receiver because you also avoid all the Y-connections.
Good job Marc, and even better if you can provide a simple wiring diagram; I mean, I get a headache when I have to think so much.
/Ville
liukku is offline Find More Posts by liukku
Build Log Speed 2.0M from F3x.com paladindg Slope 32 Jun 08, 2007 11:15 AM
Discussion V2 from f3x.com - Opinions. hanknmorgan Slope 40 Feb 07, 2006 05:43 PM
Mini NYX at F3X.com banknyank Electric Sailplanes 6 Sep 23, 2002 02:35 AM
Anyone else having problems getting to F3X.com? GregG Electric Sailplanes 5 Jun 22, 2001 02:17 AM
F3X.com Introduction F3X Electric Sailplanes 6 Jun 16, 2001 12:03 AM
