Old Mar 15, 2010, 04:30 PM
Silent-AV8R is offline
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
United States, CA, Ladera Ranch
Joined Aug 2004
I am constantly fascinated by our fixation on speed and torque. The only thing I have ever flown where servo speed was a clear issue was helicopters. I have never flown a fixed wing plane, including precision aerobatic pattern planes or IMAC, where servo speed was an issue for me.
Torque can be interesting. 95% of the time I think we modelers overestimate what we need. In gliders the two most important things are flaps staying put on launch and if needed in a steep dive to come down fast, and elevator, especially is steep dives (high speed). Both issues were real with analog servos, but digitals went a long ways since early on we learned that moving torque and holding torque were two different things. And digital servos were vast improvements on both fronts over analog servos.
I know I still sometimes get amazed thinking that I have 2 tiny JR 241 servos on the V-tail of the molded Graphite. I can do full speed dives and pull out with never an issue. But every time I see those servos I shudder to think what I ask of them!!
But I guess if we can get faster stronger servos in the same size and weight package, then why not?? I've got big planes with servos that do 425 in-oz of torque so I guess I should shut up about torque!!
Silent-AV8R is offline Find More Posts by Silent-AV8R
Old Mar 15, 2010, 04:35 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
You see? If you type long enough, you end up answering your own questions, lol!
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Mar 15, 2010, 04:45 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Tuomo, you know, your comments above are why guys have asked me why I did this build thread. Guys said that everyone will question every detail, and even when you respond with exact figures, that may not be good enough for folks.
Well, I have enjoyed the banter here on stuff, but when you asked that question and brought up specific data, I do my research, I know what is going into the ship and why. My rationale may have flaws, but I am using top of the line equipment on a top of the line ship. And you do too it sounds like.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Mar 15, 2010, 04:47 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Wouldn't the elevators of our all flying stabs, if designed and pivots in the correct place, put minimal requirements on ele servo torque?
Servo speed is a different issue, faster is really better. Mostly in dip/zoom. Depending on speed and dive angle it could translate to a few meters if everything else were equal. This is figured on a 40m/s terminal speed at 60 degrees, diving for .2-.4 secs.
I think it's even more important in a F3B zoom where speeds are reported at about 70m/s.
fnnwizard is offline Find More Posts by fnnwizard
Old Mar 15, 2010, 05:08 PM
Joined Nov 2005
That is my understanding too Wiz, but it may not always be the case.
Marc
Old Mar 15, 2010, 05:34 PM
Daryl Perkins is offline
Find More Posts by Daryl Perkins
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Ahhh... yes. Even a full flying stab is counter-balanced reducing the required torque. But there lies the problem... Don't assume the designer of your model did it correctly. It's not always an aero guy doing the structure....
D
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Mar 15, 2010, 05:48 PM
Team Futaba
Joined Aug 2004
Honestly Tuan, you are telling me that if I gave you a plane with a 0.2 second elevator servo and then one with a 0.16 second servo you would be able to discern a verifiable improvement?
Old Mar 15, 2010, 05:57 PM
SHVentus is offline
Find More Posts by SHVentus
Hawaii
Joined Feb 2009
I know that I couldn't, but I'm sure not a DP (just received & read your interview in AMA last night. Thanks, but too short. )
SHVentus is offline Find More Posts by SHVentus
Old Mar 15, 2010, 07:06 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
No, of course I wouldn't be able to. Sometimes, I wouldn't even be able to tell if I was +- 3ft from the nail in the landing zone. Daryl would know as I over flew the "nail" at SWC, even when I was right over it .
But, how I got the "few meters" is simple math in a not so simple equation.
In a dive at 40m/s (some good launchers do 50m/s). Assume your servo is .20 sec to 60 degrees.
In the zoom, you need to move say 30 degrees for the dive and another 30 the other way for the pull out all else being the same, the.20 sec servo would cost you 3.46 meters in height on the downside if you were to dive at 60deg. (.10sec*40m/sec*sin 60) when you .think you need to pull out vs. a .10 sec speed servo.
This assumes you move the servo 60 total which probably you don't. It depends on how short your arm is and the linkage of the ele, ect. I just use a total of 60 to keep it simple.
By over diving it would also cost some speed so the zoom would not be optimal as well. But that's much harder to calculate since we don't have drag numbers.
Radio response time will add to this. It all adds up.
Of course the top guys would probably know how to correct for the "slop" and they anticipate... flying ahead of the curve.
Now, given a .20 sec vs .16 sec, I would say few if anyone can tell, but from .20 to .10, even I can tell. Of course underload, it could be well that the .20 servo may end up being faster, I don't know, but that's my next step in testing these suckers.
Old Mar 15, 2010, 07:18 PM
Team Futaba
Joined Aug 2004
Which is my point. Of course there is a absurd reductionist point at which anyone could tell, but for the range of servo that we commonly use I doubt that most of us can really feel any difference. Some of the top pilots perhaps.
Just because a thing can be measured or calculated does not mean it will have a real world effect.
Human reaction time for college age people averages around 160 milliseconds (0.160 seconds). Keep that in mind when we are thinking about the differences in servo speed of 0.0015 seconds per degree of rotation. (0.1 sec/60 degree = 0.00167 sec/degree 0.20 sec/60 degrees = 0.00333 sec/deg)
This is sort of a fun site. It lets you test your reaction time. Of course there are some other factors like computer speed and Internet connection speed, but still sort of fun:
http://www.humanbenchmark.com/tests/...time/index.php
My 5 test average was 227.6 ms (0.2276 seconds). Just a bit slower than the servos I use need to go a full 60 degrees. Perhaps this explains a lot!!
Here is another with 4 different tests: http://www.reactiq.com/index.php
Old Mar 15, 2010, 07:45 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Without getting too far into this discussion. If you have equipment that makes you feel more confident, then you will fly better. Having said that, I really doubt that any zoom mechanics that can be attributed to a faster servo will net a higher launch. You are trying to get spring-back from the line and a smooth technique will get you a higher launch every time. Some jerky "oops" maneuver will scrub off speed and result in less altitude.
Avaldes is offline Find More Posts by Avaldes
Old Mar 15, 2010, 07:48 PM
Joined Nov 2005
And thank you Mr. Valdes for that great comment. May wear B/O, but I go with the aero-engineer everytime!
Marc
Old Mar 15, 2010, 08:02 PM
Team Futaba
Joined Aug 2004
Originally Posted by Avaldes View Post
Some jerky "oops" maneuver......
Aaron has seen me fly so he speaks with absolute authority with this statement!!!
I'm pretty sure I could use a reed radio and not really feel much of a difference But as long as it had a big screen TV on it and lots of bells and whistles I'd be a happy camper for sure!!!
Old Mar 15, 2010, 08:16 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Hey, Marc... If you think folks second guess you on a radio install... try posting a build thread for a model you designed... I can't tell you how many PMs I answered as to "why" this was this way or that was that way... I had one insinuate that I was stupid and the Journey would never fly correctly... I didn't bother to answer that one...
Keep up the good work. Pay no attention to those behind the curtain...
Jack
schrederman is offline Find More Posts by schrederman
Old Mar 15, 2010, 08:35 PM
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
Jack,
you need to add winglets on your X that will start something
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Build Log Speed 2.0M from F3x.com paladindg Slope 32 Jun 08, 2007 11:15 AM
Discussion V2 from f3x.com - Opinions. hanknmorgan Slope 40 Feb 07, 2006 05:43 PM
Mini NYX at F3X.com banknyank Electric Sailplanes 6 Sep 23, 2002 02:35 AM
Anyone else having problems getting to F3X.com? GregG Electric Sailplanes 5 Jun 22, 2001 02:17 AM
F3X.com Introduction F3X Electric Sailplanes 6 Jun 16, 2001 12:03 AM
