Old Mar 09, 2010, 10:11 AM
Keith Kindrick is offline
Find More Posts by Keith Kindrick
United States, CA, La Verne
Joined Feb 2007
Keith Kindrick is offline Find More Posts by Keith Kindrick
Old Mar 09, 2010, 05:15 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Thanks DP, nothing much till servos show, Kieth, do you like Orville's or Showtime brands???
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Mar 10, 2010, 09:10 AM
Joined Feb 2007
Too much sodium
Old Mar 10, 2010, 09:52 AM
F3X is offline
F3X
Find More Posts by F3X
F3X
F3X's Avatar
Joined Jun 2001
I have a white blue and white/carbon in stock.
The next batch is in the works for a July delivery.
F3X is offline Find More Posts by F3X
Old Mar 11, 2010, 02:51 PM
Joined Nov 2005
Good news, a birdy let me know that servos are on their way here. Not sure if they make it Saturday or will not have them till I can work on it next weekend. But I am stoked, ready to finish the ship.
Marc
Old Mar 13, 2010, 01:23 PM
Joined Nov 2005
Rainy Saturday
Well, the birdy was right, servos arrived this morning while I was out running errands. Four JRDS 378 High Voltage servos for the wing and two JRDS 388 High Voltage servos for the fuse. So, got the servo tray fitted exactly for the servos and the bind and logger/voltage check plugs (so I do not have to dig the RX out when wanting to function with these ports). I also got the wire harness strapped down to the right longeron via eltronic safe silicone.
One thing I did do with the 388's for the fuse, I actually glued them together. They do have beefy mounting lugs, but there is only one per end and that is all that could fit on this thin a servo. I thought it would lock in the servo more securely to have them secured to each other and basically giving four mounting lugs to the entire tray. I used Devcon Plastic Weld per recommendations of Bill, set quick, has a thick viscosity so stays where you put it before you make the bond.
Calling it quits for now, leg officially is out of the cast, but standing on it for a good while has a price to pay, I give...
Marc
Thanks JD and MA for expiditing, great help!
Old Mar 13, 2010, 01:26 PM
Joined Nov 2005
Hey, soft cast now!!!
Old Mar 13, 2010, 01:36 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Go, Marc!
T
target is offline Find More Posts by target
Old Mar 13, 2010, 03:48 PM
nuevo is offline
Find More Posts by nuevo
nuevo's Avatar
United States, AL, Madison
Joined May 2002
nice idea gluing the servos together. I agree that should make a stronger mount.
nuevo is offline Find More Posts by nuevo
Old Mar 13, 2010, 03:54 PM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
Hey, no fair! You get Darth Vader to help you!
Wing-span is offline Find More Posts by Wing-span
Old Mar 13, 2010, 03:56 PM
SHVentus is offline
Find More Posts by SHVentus
Hawaii
Joined Feb 2009
What about over heating issues, if one fails, strips gears, or has other problems, etc.? How about sticking them together with servo tape?
SHVentus is offline Find More Posts by SHVentus
Old Mar 13, 2010, 04:42 PM
Joined Nov 2005
There is not much glue there and I can seperate if necessary. I would guess that the fuse has more air available than the wings. Servo tape is the enemy, I have never used it but once and it failed and have not owned any since.
Marc
Old Mar 13, 2010, 04:48 PM
SHVentus is offline
Hawaii
Joined Feb 2009
Marc,
I didn't mean to mount the servos with ST, but rather just to stick servo 1 to servo 2, as you did with the glue. Even less movement possible between them with the glue though. Hope they can separate easily if needed.
Old Mar 13, 2010, 07:42 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
I'm not helping... I offered to help but Marc hasn't sent the model, yet...
Jack... er... Darth
schrederman is offline Find More Posts by schrederman
Old Mar 13, 2010, 08:42 PM
Silent-AV8R is offline
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
United States, CA, Ladera Ranch
Joined Aug 2004
It is especially a great idea when the servo has the single centerline mount like these servos and the Futaba 3150s have. I use a tiny dollop of Goop when I glue servos like this. Strong, flexible, and yet comes right off if you need it to do so.
Silent-AV8R is offline Find More Posts by Silent-AV8R
Build Log Speed 2.0M from F3x.com paladindg Slope 32 Jun 08, 2007 11:15 AM
Discussion V2 from f3x.com - Opinions. hanknmorgan Slope 40 Feb 07, 2006 05:43 PM
Mini NYX at F3X.com banknyank Electric Sailplanes 6 Sep 23, 2002 02:35 AM
Anyone else having problems getting to F3X.com? GregG Electric Sailplanes 5 Jun 22, 2001 02:17 AM
F3X.com Introduction F3X Electric Sailplanes 6 Jun 16, 2001 12:03 AM
