This thread is privately moderated by tking2097, who may elect to delete unwanted replies.
Old Feb 07, 2010, 11:06 AM
tking2097 is offline
Find More Posts by tking2097
'Sky' King
tking2097's Avatar
Watauga, Texas
Joined Jul 2007
Turnigy Servo Speed & Direction Regulator Information & Diagram
Hobby City now has a small servo speed and direction regulator circuit for about $7.50USD. This is the perfect device to add realism to flap and landing gear operation of RC aircraft. At this price, the addition of realistic flap and landing gear operations for RC aircraft is a real "no-brainer"!
The device takes 1 channel from your receiver as input (usually flaps or gear), and provides 3 identical slow-speed outputs for servos, CH1, CH2 and CH3. The servo speed for all 3 outputs is adjustable for each direction of servo movement. So it is possible to have flaps retract faster than they deploy, for example. The CH3 servo output direction is reversible.
Features
Input: Single channel from receiver, usually Flaps or Landing Gear.
Outputs: 3 slow speed servo outputs, CH1, CH2 and CH3.
CH3 servo direction is reversible.
Independent servo speed adjustment for each direction of servo travel.
(SW1 sets Direction A speed adjust, SW2 sets Direction B speed adjust).
Regulator adjustments
SW1: Sets servo direction A speed for all 3 servo outputs, CH1, CH2 and CH3.
SW2: Sets servo direction B speed for all 3 servo outputs, CH1, CH2 and CH3.
SW3: Sets Normal or Reverses direction for CH3 output ONLY.
Note that the device does not provide for servo end-point adjustments. So if you wish to use your transmitter to adjust individual endpoints for 2 flap servos, for example, you need to use two regulator devices, one for each servo.
The input connections for the regulator consist of three pins, similar to the connection for each channel of a typical receiver (see diagram below). So, to connect the Turnigy regulator to the receiver, you can plug one end of a servo extension wire of the required length into the receiver. The other end of the servo extension cable will need to be soldered to the regulator board input pins, or a 3-pin Female servo connector can to be added to the regulator input end of the extension cable. Personally, I find it easiest and fastest to simply cut one connector off the end of a servo extension cable, prepare the end for soldering, and solder the 3 wires to the regulator input pins.
That all there is to it! Like me, you may wish to keep a couple of the Turnigy devices handy for the next build!
The diagram below provides:
1. Block diagram
2. Readable size for front and back labels.
3. Illustrates SW1, SW2 and SW3 settings
4. Receiver and Servo connections example for slowing down flaps.
tking2097 is offline Find More Posts by tking2097
Old Mar 17, 2010, 05:02 PM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
Thanks for this, I'm about to set up landing gear speed on a new scale model I'm working on. The instructions were very sparse, a quick search revealed your blog post, thanks so much!
Matt
Matt Halton is offline Find More Posts by Matt Halton
Old May 01, 2010, 02:45 AM
alex.guzun is offline
Find More Posts by alex.guzun
iCharger 106B user
Lab, Slovak Republic
Joined Jun 2008
great
and if i want to have two servos, both should be slowed down and one of them should be reversed, what to do?
alex.guzun is offline Find More Posts by alex.guzun
Old Sep 15, 2010, 12:25 AM
'Sky' King
tking2097's Avatar
Watauga, Texas
Joined Jul 2007
Originally Posted by alex.guzun View Post
great
Connect 1st servo to channel 1.
Connect 2nd servo to channel 3, and set channel 3 to the reverse direction.
Channel 3 is the only output channel that can be set to either normal or reverse direction.
Old Sep 22, 2010, 02:24 AM
Coenraad is offline
Find More Posts by Coenraad
Coenraad's Avatar
Norway, Akershus, Frogner
Joined Jun 2010
Nice work. How does she fly with the cockpit open, does it not blow off, or increase the drag allot?
Coenraad is offline Find More Posts by Coenraad
Old Sep 26, 2010, 10:33 AM
'Sky' King
tking2097's Avatar
Watauga, Texas
Joined Jul 2007
Thanks, it is really nice to have the mods. People at the flying field really take more notice of the T-28 these days!
I have not noticed additional drag from the open cockpit, but I do have a bit of extra top-end available on the throttle, since I upgraded the stock motor to a Turnigy 3536C 1100kv brushless motor. I may be compensating for a bit of extra drag without taking notice of it. The motor upgrade also gives a much needed boost to the vertical climb capability, which I found very lacking with the stock version. A vertical corkscrew maneuver sure looks good now!
The canopy does not blow off. This canopy has a snug fit which helps, but the rare-earth magnet does a good job of holding the rear of the canopy down. If this became an issue, I would likely just put in a larger rare-earth magnet.
Old Oct 15, 2010, 04:07 PM
Fidy$Trainer is offline
Find More Posts by Fidy$Trainer
USA, GA, Atlanta
Joined Sep 2008
End point adjustments would be a new feature to stop the retract servo's from binding.
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Old Dec 27, 2010, 12:57 AM
G-Man is offline
Find More Posts by G-Man
I've reached my critical AoA
G-Man's Avatar
United States, VA, Winchester
Joined Dec 2005
I read in a post somewhere that this is not reccomended for a dx6i. Does anyone know why? I have a DX7 and a Parkzone Stinson Reliant SR-10 I want to use it on to make the flaps more realistic.
G-Man is offline Find More Posts by G-Man
Old Apr 22, 2011, 08:14 PM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
This gadget kicks ass on my DX7 and electric retracts. staggers them up and down.
mike early is offline Find More Posts by mike early
Old Jun 01, 2011, 05:37 PM
jmscott31 is offline
Find More Posts by jmscott31
United States, CA, Pomona
Joined Mar 2008
If i'm not mistaken, the DX7 has speed regulation built in, doesn't it? This means you do not have to use the servo regulator.
jmscott31 is offline Find More Posts by jmscott31
Old Jun 02, 2011, 07:57 AM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
you are mistaken.
Old Mar 11, 2016, 07:54 PM
Appallo is offline
Find More Posts by Appallo
Scott
Joined Aug 2015
Features
1. Block diagram
Thanks much for this, trying to install this thing was kicking my but till I found this post. I couldn't find the input and the little napkin that came with it didn't help much.
Appallo is offline Find More Posts by Appallo
Sold Turnigy Servo Speed Regulator rccrazee Aircraft - General - Radio Equipment (FS/W) 0 Jan 09, 2010 06:24 AM
Sold Turnigy slow down servo regulator fnlrun Aircraft - General - Radio Equipment (FS/W) 2 Jan 07, 2010 11:16 PM
Discussion Servo Direction / Reversing FlynFoam Radios 2 Sep 25, 2009 05:06 PM
Help! Servo direction dilemma FIXXIN2FLY Radios 0 Sep 24, 2009 09:31 PM
