Old May 19, 2003, 09:57 PM
funhaving is offline
Find More Posts by funhaving
San Diego
Joined May 2003
Help!
duralite plus Lith Ions destroying servos
Brand new Duralite Plus 950mah pack w/5.1v regulator reads correct voltage but strips Hitec servo gears every time! Does anyone have any ideas why?
funhaving is offline Find More Posts by funhaving
Old May 19, 2003, 10:03 PM
DaveA95131 is offline
Find More Posts by DaveA95131
DaveA95131's Avatar
Long Beach, California, United States
Joined Jan 2002
This may be obvious, but you are turning on the Transmitter prior to putting power to the Receiver/ESC/Servos, right?? I am not sure how a battery would strip a servo under any circumstances.
Just a thought!
DaveA95131
DaveA95131 is offline Find More Posts by DaveA95131
Old May 19, 2003, 10:36 PM
Jason M is offline
Find More Posts by Jason M
20 years on RCG!
United States, IL, Champaign
Joined Dec 1996
I agree - a battery pack will not strip servo gears.
Something is wrong with your horn, linkages, etc. You must have a binding control to get stripped gears.
Jason
Jason M is offline Find More Posts by Jason M
Old May 19, 2003, 11:47 PM
San Diego
Joined May 2003
Guys,
I know this sounds crazy. The transmitter is on. I tested voltage
from the battery (8.4v) and from the regulator (5.9v unloaded).
I checked polarity. I plugged in a nicad pack and it worked fine.
I tried a larger Hitec servo, it turned to its limit and locked up!
I called Duralite and Hitec, nobody knows. Duralite: Voltage is voltage, Call Hitec... Hitec: Call Duralite, maybe regulator. I need
at least 3 new gear sets! How do regulators work? I'm thinking
about checking it on a scope at work. Nicads are too big for my
glider. Anyway, thanks for the replies. I don't think I'm smart anymore.
Old May 20, 2003, 08:24 AM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Mabey the regulator is putting out a noisey signal. Sending the servo to full travel, not sensing it is at the usual end of rotation, stripping the gears ???
Dosn't think it is a battery problem.
Kevin Murray is offline Find More Posts by Kevin Murray
Old May 20, 2003, 06:09 PM
San Diego
Joined May 2003
Correct!
I checked regulator on a scope. It's putting out a sawtooth AC!
Maybe somebody left out a capacitor on mine or something (?).
Duralite is checking and will call me tomorrow.
Old May 20, 2003, 10:27 PM
USA, NC, Greenville
Joined Dec 1999
Did the regulator come with the Duralite pack ?
Old May 20, 2003, 10:52 PM
San Diego
Joined May 2003
Kevin,
Yes, the regulator came with the battery pack. I hope my receiver
is OK.
Any Info using 18650 Lith ions w/ Speed 400 Etonic Batteries and Chargers 4 Dec 11, 2002 12:05 AM
Question Lith-Ions and A Gear Speed 280 putt_13 Batteries and Chargers 8 Oct 29, 2002 03:40 PM
For Sale Jr Quattro Radio & Receiver Plus 2 Sub Micro Servos wats Aircraft - Electric - Airplanes (FS/W) 8 Sep 20, 2002 06:26 AM
charging lith-ions with maha charger rcsheriff Beginner Training Area (Aircraft-Electric) 1 May 10, 2002 07:16 PM
looking for lith-ions for micro use jhas Scratchbuilt Indoor and Micro Models 1 May 05, 2002 09:10 PM
