Old Sep 26, 2012, 03:05 PM
takeoff2 is offline
Find More Posts by takeoff2
takeoff2's Avatar
Romania, CL, Călărași
Joined Jan 2009
I made 12 flights with HC500 and SK720 is performing well,there were 8 flights with 200% SL and 4 flight with 140% SL all is OK.
takeoff2 is offline Find More Posts by takeoff2
Old Sep 26, 2012, 03:18 PM
GetToDaChopper is offline
Find More Posts by GetToDaChopper
Aviation Technician
GetToDaChopper's Avatar
Joined Feb 2012
didn't you use to have a dif name taleoff2 ?
GetToDaChopper is offline Find More Posts by GetToDaChopper
Old Sep 27, 2012, 03:35 AM
takeoff2 is offline
takeoff2's Avatar
Joined Jan 2009
Too late now!
Old Sep 27, 2012, 04:56 AM
Aviation Technician
Joined Feb 2012
your name was "Too late now!" ???
Old Sep 27, 2012, 10:30 AM
takeoff2 is offline
takeoff2's Avatar
Joined Jan 2009
Not currently speak English and I think I'am not understand the question.
However, someone flies with SL 200% and loggers ON?
Old Sep 27, 2012, 11:56 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Yes. I do.
Rickn816 is offline Find More Posts by Rickn816
Old Sep 27, 2012, 03:01 PM
Aviation Technician
Joined Feb 2012
I'm asking wasn't you user name something other than "takeoff2" before ?
did you change your user name to "takeoff2" ? or has it always been "takeoff2" ?
Old Sep 28, 2012, 03:22 AM
takeoff2 is offline
takeoff2's Avatar
Joined Jan 2009
On this forum my name always was takeoff2.
Thanks Rick.
Old Sep 29, 2012, 07:29 PM
jamesppp is offline
Find More Posts by jamesppp
jamesppp's Avatar
Georgia, USA
I just flew with logging on and SL at 100 and all was well.
I when I tried to look at the file all I had was 999 and it will not open.
I unplugged the battery before the gyro initialized because I had to go get my neck strap
I was going back for another quick flight but the sun has fully set so maybe tomorrow
I love my Pyro 700-52L but I have a new gen 3 Compass 4926 that has a lot more power just sitting in the box..I dont need more power but I will have to try it when I get some 60C packs
jamesppp is offline Find More Posts by jamesppp
Old Oct 05, 2012, 02:28 PM
takeoff2 is offline
takeoff2's Avatar
Joined Jan 2009
I have a question, after how many flights can be disabled Auto Trim and I may use the TX trim?
Old Oct 05, 2012, 03:27 PM
Aviation Technician
Joined Feb 2012
When the "Bell Gains" setting levels out and stops changing, how ever many flights that takes, just make sure you don't "baby" the heli, just fly it as hard is you normaly would.......
Old Oct 06, 2012, 03:50 AM
takeoff2 is offline
takeoff2's Avatar
Joined Jan 2009
Well,I asked exactly for that, I noticed that there are large variations in the values of the bell gain.So I shake as much the helicopter and then turn off Auto Trim.
thanks
Old Oct 06, 2012, 05:07 AM
georgi UK is offline
Find More Posts by georgi UK
Joined Apr 2012
thanks
=] these are completely 2 different things,
auto trim is reading the Tx sticks centres at start-up, turn this off allows the use of Tx trims, but they will need to be re-centred each time the heli is powered back up again,
self-tune is the bell gain function, found in the cyclic tab.
georgi UK is offline Find More Posts by georgi UK
Old Oct 06, 2012, 08:13 AM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
thanks
As Georgi stated, you are mixing up two functions that have nothing to do with each other. Bell gains have nothing to do with any trim on your TX, and having the auto trim at init box checked doesn't prevent you from using the trim on your TX and has nothing to do with self tuning Bell gains.
The Bell gains will "tune" themselves in after several flights from the default values set by Skookum. They tune to your particular flyng style, and once you notice the values no longer changing, you can disable the "auto tune Bell gains" box if you wish. Also notice that they only tune to the cyclic tab that you are flying, so once finalized, you should copy the same values to your second bank, then save the file to your PC since reloading another file you may have saved earlier will set the gains back to pre tuned values again.
The auto trim at init function sets the neutral position of the sticks at startup and accounts for any small stick centering discrepancy. There is no real reason that I see to disable this. You may have to trim the heli for every flight if you do.
You shouldn't be using any trim or subtrim on your TX with any FBL gyro. If you are needing to do this, then you need to adjust out the drift mechanically following the instructions in the Skookum Wikii page under the Advanced tuning for 3D section, step #4. http://www.skookumrobotics.com/wiki/...720_%26_SK_540
Xrayted is offline Find More Posts by Xrayted
Old Oct 06, 2012, 02:33 PM
takeoff2 is offline
takeoff2's Avatar
Joined Jan 2009
Ok gentlemen, I followed your advice, I reread the manual and is a day without wind and I flew.
After mechanical adjustment for perfect horizontal flight, look what position reached the swash:
Pretty big deviation about 7/8 degrees.What do you think?
For Sale CSM SL 720 gyro $150 Shipped Giovanni Day Aircraft - Electric - Helis (FS/W) 1 Jul 02, 2011 08:18 PM
Discussion Skookum 720 Rickn816 Electric Plane Talk 2 Feb 07, 2010 10:01 AM
Sold NIB Extremeflight Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 2 Jan 15, 2010 10:36 AM
Sold NIB Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:00 PM
Sold Torque 2812/720 Brushless motor RichR Aircraft - Electric - Power Systems (FS/W) 2 Aug 27, 2009 10:19 PM
