Old May 04, 2010, 03:13 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
My Sk720 shipping notice arrived today, looks like my wait is almost over. Now need to pull the gyro, receiver, and Sk360 out of the helicopter its going in.
Roto Rob is offline Find More Posts by Roto Rob
Old May 04, 2010, 05:32 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
When you hook it up to your PC, note the firmware revision. I'm curious.
Thanks.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old May 04, 2010, 08:04 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Ok, will do that. Its from the second preorder batch from Helidirect.
Old May 06, 2010, 03:37 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
My firmware rev is 1.00
Old May 06, 2010, 06:22 AM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
That is what I thought. The self-leveling upgrade should be available in a few weeks. Apparently Skookum took this week off - the e-mail messages state they wil be back on May 10.
Rick
Old May 07, 2010, 02:57 PM
badbill is online now
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Well, Just had my first crash w/ the 720, and it appears it was a failure of the unit? I've flown it about 20 times. Plugged in the lipo and got the usual up down of the swash, then checked for a solid green light and proper control movement. Sat the heli down, and did like I always do, switched into idle up one. Picked it up into a nice stable hover, it banked to the right and wouldn't correct. All it did was take out the blades, but I am worried- the flight log is just wild, take a look.. I only took off the heli once, but it shows it taking off twice, first time w/ the stick at idle?? Afterwards the unit appears to function normally, but heck it did before also
Bill Davenport
AMA 28141
badbill is online now Find More Posts by badbill
Old May 07, 2010, 03:50 PM
Chomper_Boom is offline
Find More Posts by Chomper_Boom
Hooked on Heli's!
Chomper_Boom's Avatar
USA, NJ, Voorhees
Joined Aug 2005
Sry to hear that Bill - just curious: what version of the firmware are you running - 1.0? Are you using a satelite receive with the unit or a standalone receiver?
I've had about the same number of flights as you, probably 15 or so with a 2 bladed head and the last 5 or so I've switched over to my 4 bladed head on a CopterX 450.
I had only one problem with my unit after updating the firmware from the Beta version to 1.0 where the "Rotate 90 Deg" checkbox engaged and I didn't notice or test before the next flight and ended up doing in a set of blades. Otherwise haven't had any issues.
Chomper_Boom is offline Find More Posts by Chomper_Boom
Old May 07, 2010, 04:39 PM
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
Gotta say I don't know what firmware, but I have not updated it. I'm running two satellites.
This is the first problem I've had, don't know whether to try it again or what.
Bill Davenport
AMA 28141
Old May 07, 2010, 06:58 PM
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
Firmware is 1.00
Bill Davenport
AMA 28141
Old May 07, 2010, 07:12 PM
blade strike is online now
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Are you sure a servo didnt fail or stall?
blade strike is online now Find More Posts by blade strike
Site Sponsor
Latest blog entry: Phantom 4 Tutorials
Old May 07, 2010, 07:14 PM
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
Uh... yeah. The dead simple first thing I checked.
Bill Davenport
AMA 28141
Old May 07, 2010, 07:19 PM
Joined Jan 2006
The firts time it lefts off is when you went to carry the heli over to take off.. No vibs!
Did you recheck to make sure the gyro knows the correct direction?
Edit:
I also see a little right input on take off, 2 stick movements to the right. Was the heli still on the ground at this point.. ?
Site Sponsor
Old May 07, 2010, 08:07 PM
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
Edit:
Yes, it was still on the ground. If the first "flight" was me carrying the heli over to set it on the ground, why doesn't this show on my other 19 flight logs ( some posted on this thread ) ? The tail was/is responding correctly, but even if it wasn't it wouldn't cause cyclic input.
Bill Davenport
AMA 28141
Old May 07, 2010, 08:41 PM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
You carried the heli.
Is this the way you always start up?
The gyro needs to be quiet - unmoving for a few seconds before it arms.
When I start mine, the heli is in place before I turn on the power, then I don't touch the sticks or the heli until the head bumps and the LED turns green.
On the other hand, do you get the correct responses from the PC Setup software?
Blade uploaded your file for Skookum. They should get back with us next week. They can tell a lot about the heli from those files.
Rick
Old May 07, 2010, 08:46 PM
Habitual Freeloader
badbill's Avatar
Joined Dec 2002
Rick, there was a LOT wrong w/ the flight log- Including the fact that I only took off once and it shows twice. I'm not a great heli flyer, but believe me when I tell you that when it started to the right I started giving it left. And a Trex 450 pro is NOT a slow to respond heli.
There was nuthin' there.
Bill Davenport
AMA 28141
For Sale CSM SL 720 gyro $150 Shipped Giovanni Day Aircraft - Electric - Helis (FS/W) 1 Jul 02, 2011 07:18 PM
Discussion Skookum 720 Rickn816 Electric Plane Talk 2 Feb 07, 2010 09:01 AM
Sold NIB Extremeflight Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 2 Jan 15, 2010 09:36 AM
Sold NIB Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 12:00 PM
Sold Torque 2812/720 Brushless motor RichR Aircraft - Electric - Power Systems (FS/W) 2 Aug 27, 2009 09:19 PM
