Old Apr 13, 2012, 02:00 PM
Amugames is offline
Find More Posts by Amugames
Belgium, Flemish Region, Malle
Joined Apr 2012
I just got answer from the service and it works perfect:
Hi Marc,
This is a problem with the GUI giving a false "Update Failed" warning. Try the update again, and leave the LCD connected to the SK 720 until the 720's LED stops flashing red and green. This will take one or two minutes.
Brandon Taylor
Skookum Robotics
www.skookumrobotics.com
Amugames is offline Find More Posts by Amugames
Old Apr 13, 2012, 02:03 PM
jamesppp is offline
Find More Posts by jamesppp
jamesppp's Avatar
Georgia, USA
EDIT; too late. Took me a minute to copy and paste from heli freak on my iPhone
I posted a link to the LCD. Fix but the link didn't work
jamesppp is offline Find More Posts by jamesppp
Old Apr 13, 2012, 11:35 PM
GetToDaChopper is offline
Find More Posts by GetToDaChopper
Aviation Technician
GetToDaChopper's Avatar
Joined Feb 2012
This worked with mine ! From the man him self......
Try starting the update without the LCD plugged in, then just as it first flashes red/green, plug in the LCD. It has to be done within about 1/2 second, and it may take a few tries to catch it. Be sure to wait until the SK720's LED stops flashing red/green before unplugging it again.
Best Regards
Art
GetToDaChopper is offline Find More Posts by GetToDaChopper
Old Apr 14, 2012, 08:02 PM
Aviation Technician
Joined Feb 2012
So with firmware ver 3.10 out who has updated and how much does the "Re-level Accelerometer" help the self-leveling with the 720, also what kind of improvements if any have you seen using firmware ver 3.10 ?
Old Apr 14, 2012, 09:30 PM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Have not re-leveled yet.
Major change is support for quad copters.
Self-leveling up to 200 percent, so the heli turns level twice as fast.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Apr 14, 2012, 10:37 PM
jamesppp is offline
jamesppp's Avatar
Georgia, USA
Rick,
I have not updated yet. I really want to try SL at 200% just for the heck of it.I havent updated because I didnt want to take a chance that I would mess something up and it would interfere with my flying tomorrow
I dont have the pay for view log reading upgrade key yet but will get it it as soon as I update firmware and software. Just wish I could put it on a desktop and a notebook or tablet without buying 2 licenses.
Built my Beam FBL head tonight so I just need my Sk540 to show up and Ill have the littlebuzz bomb hooked up.Im trying to decide on a head for my Outrage 550 now.
From Skookum;
3.10 Details
Details of the 3.10 Update:
* Allows for 2x faster bail out self-level
* The high-vibration warning is only enabled if self-leveling is active on at least one bank
* Users can re-level the accelerometer themselves (The center-point can drift over the long term. This feature is meant to be used rarely).
* Quad copter mode (See wiki)
* JR DMSS mode (requires simple adapter cable, see wiki)
* Better vibration filter on the tail
* Option to disable the governor while in tail bank 2, for nitro engine tuning.
* Improved PPM receiver signal capture
* RPM capture enabled in PPM receiver mode
* Accelerometer is more static-electricity resistant
* Fixed a bug in Graupner mode channel mapping
* Fixed a bug in fail-safes for the aux servo outputs
* Several minor bug fixes
Changes to the Setup Software, rev 3.10:
* Supports the SK540
* Support for upgrades as described above
Changes to the LCD Firmware, rev 3.10:
* Several bug fixes
Changes to the Data Viewer, rev 3.10:
* Fixed bug that prevented some users from registering without help
Old Apr 15, 2012, 06:49 AM
Aviation Technician
Joined Feb 2012
jamesppp i think you have the anti rotation pin on backwards on that Beam E4 FBL head ?
all three balls should be equal distance from the center line of the main shaft i believe.....
Old Apr 15, 2012, 07:37 AM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
JImmy,
It is really hard to mess up the firmware update. I've tried. . .
Even if you lose connection, the setup will start again, transparent to you.
Rick
Old Apr 15, 2012, 10:24 AM
Aviation Technician
Joined Feb 2012
just make sure if you have the LCD term and if updating it that you ignor the "firmware update failed" popup and be sure to wait until the SK720's LED stops flashing red/green before unplugging it again
Old Apr 16, 2012, 01:03 PM
jamesppp is offline
jamesppp's Avatar
Georgia, USA
I'm just going to wait on ver. 3.11
Old Apr 16, 2012, 06:56 PM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Firmware Updates
1. Connect your unit to your PC. Save settings as a file on you PC. Disconnect the unit from the USB cable.
2. Go to Skookum and download the new installer package.
3. Run the installer.
4. Start the new installer (3.10). Connect your unit to the USB cable.
5. Click on Utilities, select upgrade.
6. Read the instructions on the screen. When complete, the PC setup software should indicate that you now have firmware version 3.10.
Rick
Old Apr 18, 2012, 07:40 AM
jamesppp is offline
jamesppp's Avatar
Georgia, USA
Thanks Rick,
Everything worked perfectly following your instructions.
When updating the field terminal I got false DID NOT INSTALL pop up, ignored it, and a minute later it was updated
The weather is not looking good for a test spin today
Old Apr 18, 2012, 03:52 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Do you still need an internet connection to upgrade the SK720 firware. I don't have internet in my shop. So always was a hastle.
Roto Rob is offline Find More Posts by Roto Rob
Old Apr 18, 2012, 05:23 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
Yep, the download for the update and installer package and firmware update are all done online.
Xrayted is offline Find More Posts by Xrayted
Old Apr 19, 2012, 05:49 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The update is very quick and easy I had no problems. Skookum has one of the easiest to use update programs that I have seen. You only need an Internet connection for a very short time so itís no big deal to use it in your house or office.
RC Man is offline Find More Posts by RC Man
For Sale CSM SL 720 gyro $150 Shipped Giovanni Day Aircraft - Electric - Helis (FS/W) 1 Jul 02, 2011 08:18 PM
Discussion Skookum 720 Rickn816 Electric Plane Talk 2 Feb 07, 2010 10:01 AM
Sold NIB Extremeflight Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 2 Jan 15, 2010 10:36 AM
Sold NIB Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 01:00 PM
Sold Torque 2812/720 Brushless motor RichR Aircraft - Electric - Power Systems (FS/W) 2 Aug 27, 2009 10:19 PM
